Question about Sony Sound Forge Pro 10 for PC
Serial number If you have already purchased the application, enter your serial number here and click Submit
I cannot find a place to put code to link my roku to flickr
  1. Visit roku.com/link to enter the link code, then click Submit.
  2. Chose Already have one.
  3. Enter Roku email and password. (Help reset my password)
  4. Enter a payment method or scroll down to skip for later.
  5. Add some channels and scroll down to click Continue. If you are linking a Roku player and need to create a new Roku account:
  6. isit roku.com/link to enter the link code, then click Submit.
  7. Chose the create new account
  8. Enter your details, check the confirmation items, and click Continue.
  9. Select a PIN option and click Continue. (What is a PIN?)
  10. Enter a payment method details, then scroll down to click Submit info. (Why is payment method required?)
  11. Add some channels and scroll down to click Continue.
  12. In either case, after the last step, the Roku player is now linked to your Roku account and will sync any new or previously installed channels. The web page shows that the Roku player has been successfully linked, but the link code is still showing on my TV.
  1. Log into your Roku account from a browser (roku.com) to see if it is already linked. (look for the Roku player serial number under My linked devices.)
  2. If the serial number does not appear as a linked player, go back to your TV and select Help, then Get a new code. Enter the new code at roku.com/link.
  3. If the serial number does appear as a linked player, wait a few minutes to let the update appear on the Roku player.
  4. If the player does not update, even after waiting, restart your Roku player, begin the setup process again, and see if that resolves the problem.
There may be a delay between the time it takes to update your Roku player and the message you see on the TV. Please wait a few minutes before getting a new code.
Occasionally, the Roku service may be under maintenance, or experiencing a service interruption, resulting in slower or no response.
In this case, you can check the Support.roku.com home page for any alerts.
No link code is displayed on my TV. (Just a retrieving message)
Select Help then Get a new code. Enter the new code at roku.com/link.
I get a link code but the web page will not accept it.
If a new code does not work:
Reset the Roku player to factory defaults. (show me how)
Note: The link code will expire after a period of time. If this happens, try the steps above to get a new code and attempt to re-link the Roku player first before resorting to factory resetting the Roku player.
Still no luck? Contact Roku Customer Support
Sep 28, 2016 | Roku Streaming Stick
I need a recovery disk for my Acer AT3-100-EF20. Can't access the hard drive
Purchase Recovery Media
If in the USA
(1) Visit the Acer Store, then select eRecovery (http://store.acer.com/store/acerna/en_US/home)
(2) Enter your serial number or SNID, then click Submit
(3) Follow the on-screen instructions to make your purchase
I’m happy to assist further over the phone at https://www.6ya.com/expert/kevin_c38b47f462e94458
Jan 29, 2015 | Acer Aspire Computers & Internet
Hello my scanner wont work for lexmark x852e. please help
Don't know if you have tried this, but it might help.
Create a scan to PC profile
1 Type the IP address of the MFP in the address line of your browser, and then press Enter.
If the Java applet screen appears, click Yes.
2 Click Scan Profile.
3 Click Create Scan Profile.
4 Select your scan settings, and then click Next.
5 Select a location for saving the scanned output file somewhere on your computer.
6 Enter a profile name.
The profile name is the name that will appear on the Scan Profile list on the MFP control panel.
7 Click Submit.
8 Review the instructions on the Scan to PC screen.
A shortcut number was automatically assigned when you clicked Submit. You can use this shortcut number when
you are ready to scan your documents.
a Go to the MFP, and place your original document in the ADF face up, long edge first.
b Press # followed by the shortcut number on the keypad, or touch Profiles on the home screen.
c After you enter the shortcut number, the scanner will scan and send the document to the directory or
application you specified. If you touch Profiles on the home screen, locate your shortcut on the list.
9 Return to your computer to view your file.
Your output file is saved in the location you specified or launched in the application you specified.
Good luck.
May 22, 2014 | Lexmark X3650 Printer
Garmin nuvi 50LM is frozen
Why won't my nuvi 30, 40, or 50 go past the Garmin logo screen when I turn it on?
We've discovered a problem with the nuvi 30, 40, and 50 products that in some cases will prevent them from booting up successfully. A software fix has been released that will resolve this issue, please follow the steps below.
Things you'll need
• A PC running Windows XP or newer
• Your nuvi 30, 40, or 50 device
• mini USB cable to connect your device to your computer
• Access to your vehicle and power cable once you have completed the recovery process
Update your Software
1. Download and install the Garmin USB Drivers
2. Download the Recovery Application and corresponding recovery file for your device, and save them some place easily found, like your Desktop:
o nuvi 30 Files:
nuvi 30 recovery file
o nuvi 40 and nuvi 50 Files:
nuvi 40 and nuvi 50 recovery file
3. Drag and drop the .rgn file on top of the Updater.exe Recovery Application. The application will launch.
4. With your device disconnected and turned off, use your thumb to apply pressure to the upper-left hand corner of the touchscreen.
5. While still holding the touchscreen, connect the device to your computer using the mini USB cable.
6. The Updater program will detect your device and will list the device in the "USB Device" drop-down menu.
7. Click OK and let go of the touchscreen
8. Your nuvi will now go through the process of updating software. It may power off and on during this process. Once complete, your device may display the following message:
The software on the device is newer than the software you are attempting to install. Installing the older software will erase all user data. Install the older Software?
If this message appears, please select No.
9. Disconnect your device from the computer and connect it to your vehicle power cable while plugged into a live power outlet in your vehicle.
Your device should now be recovered and updated.
Still having problems?
Customers living in the United States or the United Kingdom can follow the steps below to automatically set up a repair for your product. Customers living elsewhere can Contact Us for further assistance.
1. Visit the Garmin Repair Center
2. Click 'Go' to enter your device Serial Number
3. Enter your Serial Number twice in the pop-up menu
4. Confirm your model number and Click on your device
5. Select "Power or Battery" as the Problem Category
6. Select "Locks Up, Freezes or Turns Off Unexpectedly" as the Problem Subcategory
7. Select "Frozen on Start Screen"
8. Enter additional notes describing your problem
9. Click Continue
10. Click "Yes" to submit a request for a repair or replacement?
11. Sign in to your myGarmin Account
12. Confirm your shipping address and e-mail, click submit
You will receive an e-mail within 10-15 minutes after completing this process. Please follow the instructions in that e-mail to complete your RMA.
Apr 25, 2012 | Garmin GPS
My hardrive crashed and when fixed I lost all my applications. I cannot find my serial number for CS4 design premium student edition. I really need to use these programs immediately and do not want to...
If you have register your serial number with Adobe CS4, you can email or contact their customer support. I'm sure they'll provide you your serial number.
Sep 01, 2011 | Computers & Internet
I don't know Serial Number of Internet Download Manager Registration, please give me the serial number
Computer programs made available for retail purposes have identification numbers attached for content copy right protection purposes. Once acquired on the market, the serial numbers are inclusive with the purchase to accomplish user functionality requests. If the program software's were acquired on the internet in which instance would have had to be downloaded to a new computer from another computer requires serial numbers for achieving final unpacking decoding to attain operationality as an integrated application thereafter. The internet vender may allow as an attractive marketing technicaque a program download on to computer thereafter requesting code series only acquirable from vender of the software before opreationanilty is attainable. Once the program is already on the computer, deciding to acquire serial numbers would require purchasing the right to patent from the programmer's manufacturer however. Contact the a retailer in town as physical store location to acquire the CD DVD version of the program with serials for operationality or contact the internet vender of the program that has already been installed on the computer with details of attainable from the programs help button areas once malfunctions are encountered.
Jan 25, 2011 | Computers & Internet
I need a owners manuel for a troybilt lawn mower
For Troy-Built USA, use this link and submit your model number and serial number to find and download your manual:
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001
For Troy-Built Canada, use this link and submit your model and serial number to find and download your manual:
http://www.troybilt.ca/troybilt/troybilt_manual_search.asp
All other countries use this page and find the applicable website or email address then go to the applicable website or email the contact point:
http://www.troybilt.ca/troybilt/contact-world.asp
Thanks for choosing FixYa,
Kelly
Oct 04, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Updates for garmin c510 sat nav
Updates can be got from www.garmin.com To update the software you need to connect the satnav to your computer. Download webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27 and install it. Follow the prompts and it should take you through updating your software.
To update the map
  1. Click the link https://my.garmin.com/maps/updates.htm
  2. Click on All other devices
  3. Type in your Serial number
  4. Click Find
  5. Click Buy Disk (Please note if the message "No updates are found" then you already have the latest mapping)
  6. Click Add To Cart
  7. Click to Accept Trading Terms
  8. Click Checkout
  9. Enter your myGarmin Username and Password in the onscreen boxes (If you don't currently have a myGarmin account, click Create new Account)
  10. Click Sign In
  11. Enter your Shipping address
  12. Click Save & Continue
  13. Enter your Credit Card information
  14. Click Submit Order
  15. Write down your Order Number
It may take up to 4-6 weeks to receive the DVD depending on availability
Aug 04, 2010 | Garmin StreetPilot c510 Deluxe GPS...
Register product
  1. Step 1 Head to Nintendo's Registration website (see Resources below). New users and returning members can register their consoles from within this domain, as well as contact customer service with questions.
  2. Step 2 Click the "Click here to become a member of My Nintendo and register your newly purchased Wii" link to create a new My Nintendo account if you don't already have one. Click on the "click here to register your Wii now!" link if you are already a member of My Nintendo.
  3. Step 3 Enter your birth date and click the "Sign Up" button when starting the entire registration/account creation process. If you're already a member, then you can simply type in your username and password in the appropriate field and click the "Log In" button.
  4. Step 4 Enter your Wii console serial number into the "Wii" field once you have logged in or completed account creation. You can also register other consoles or handhelds on this page, as well as up to four games you currently own.
  5. Step 5 Click the "Submit" link once you have finished filling in all appropriate serial numbers. Double-check your typing to ensure that you haven't made a mistake (invalid numbers will be returned as such if you submit them, but you'll be able to go back and retype if you make a mistake).
Mar 14, 2009 | Nintendo Wii Console
Where can i get serial number?
You can purchase a serial from adobe here:
https://store3.adobe.com/cfusion/store/index.cfm?store=OLS-AP&view=ols_prod&category=/Applications/PhotoshopExtended&distributionMethod=FULL&promoid=121DJGPS_H_US_AC_PS_CS4E_B_1&tt=H_US_AC_PS_CS4E_B_1&nr=0#
Please do not use this site to phish for serials
Thanks
Sean
Dec 30, 2008 | Adobe Photoshop 7.0 for PC
Sony Sound Forge Pro 10 for PC Logo
59 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
