Diagram samson mpl1502 mixer - Audio Players & Recorders
  • 3,382 Answers
No sound to my headphones with Samson mdr624
First be sue the headphones are good. The C/ROOM + PHONES control is used to set the level sent to the control room outputs, and also to the head-phone jack.
Nov 20, 2014 | Samson MDR624 Mixer
How to connect a samson s mix 5 channel mixer
It depends on what you are trying to connect. The XLR would be a professional type microphone, it does not have phantom so a condenser mic will not work. The other inputs should match your stereo equipment. The output goes to your amp.
The Samson S-Mix is a miniature, rugged 5-channel audio mixer with 4-line inputs and a single XLR microphone input. The line inputs are comprised of two 1/4" phone and stereo RCA phono connections. Each input channel has a rotary volume control and the outputs include stereo RCA phono connectors and 1/4" TRS phone headphone output. The S-Mix is powered with an 18 volt AC adapter.
Mar 28, 2014 | Samson S-Mix Miniature Audio Mixer
Hum from Samson XM610 Powered mixer
hi, my samson xm610 have a problem even i tern off the voluem of each chanel still have a sounds be fore is not just like that.. can you help me
Aug 27, 2012 | Samson Xm610 Powered Mixer
Power mixer to a power amp.
You have two aux sends on that mixer so quite easy to use one of those to feed the external power amp. You could have one set of spkrs connected to that amp and another connected to the powered mixer. This would give you full independent control over each set.
Aug 09, 2012 | Samson Xm910 8Channel Powered Mixer...
How do i hook up my mixer to a samson s.com plus compressor
Use INSERT cables to insert into the MAIN's. This will compress the whole level going to the mains.
Aug 04, 2011 | Samson TXM16 16 Channel Powered Mixer,...
How do I connect my samson amp to my samson MDR10 mixer?
on the mixxer, use the "mix" "L" and "R" outputs. use 1/4 inch instrument cables, and connect the mox L and R to the amp's "channel 1" and "channel 2 inputs". always turn the mixing board on first, and the amp second- when turning off turn off the amp first, and turn off the mixer second. start with the mixer levels at the lowest, with the amp levels about 1/2 to 3/4 up. slowly raise the mixer channels first and then the mixer main volume until you have an adequate volume.
Mar 09, 2011 | Samson SX1200 Amplifier
How do i connect dis mixer to another mixer?
First of all a link to the manual:http://s3.amazonaws.com/samsontech/related_docs/XM910_ownman_v1.pdf Have a look at page 14, 9. Go out of MixOut ( line level ) into any line level auxiliary inputs left and right on the other mixer. You didn't say what the other mixer is so this is the easiest. What you will have is a sub mix of everything plugged into the Samson controllable by the controls for the line in you are using on your second mixer. There are other options which you should be able to discover by reading your manual for the Samson and the manual for the other mixer.
Nov 07, 2010 | Samson Xm910 8Channel Powered Mixer...
HOw do you plug the Samson M15 into a stereo? Or
You need a small mixer to boos the level of the mic to line level.
We here at Pro Line Music have small mixers that can do this.
215-736-8055
Dec 25, 2009 | Samson Dynamic Vocal Microphone
SETTING LEVELS ON MY POWER MIXER FOR MICING DRUM SET
Go check out these pictures, and there is some good info about micing up your drums. :) Recording it is then a case of getting levels good for a start by worling your way around the kit one drum at a time setting the level for that drum. a bit of nice reverb in the mix and out come you drums.... whoooohhooooo
May 12, 2008 | Samson SX1200 Amplifier
148 people viewed this question
 Grubhead
Grubhead
