Question about HP LaserJet Pro 400 M451dn Workgroup Color Laser Printer
REMOVE SHIPPING LOCK M451 PRINTER PRO 400 - HP LaserJet Pro 400 M451dn Workgroup Color Laser Printer
3 Suggested Answers
SOURCE: Hi, my printer just keep
Have you removed the clear tape that seals the unit for shipping? If not - with the cartridge in the printer, find the tape (LHS) and pull it directly up. If you have already removed it - take out the cartridge, manually wind the rollers a little and then replace it. (THis worked for me!)
Posted on Dec 14, 2010
TerryTown
  • 292 Answers
SOURCE: how to remove shipping lock
Thank you for contacting FixYa for your printer inquiry.
Here is a link that will give you step by step solutions to solving this issue:
http://bizsupport1.austin.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=115&prodSeriesId=2512319&prodTypeId=18972&prodSeriesId=2512319&objectID=c00819256
You will also find useful information in the startup guide that comes with your printer.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00727305/c00727305.pdf
Hope this helps. Please keep us updated and remember to rate this answer.
TF
Posted on Jun 14, 2011
HP LaserJet Pro 400 MFP showing offline when printing
My computer says that the printer is offline and my printer will not print idk what to do... suggestions????
Oct 10, 2012 | HP Laserjet Pro 400 Mfp M425dn...
Does the office jet 8500 have a power reset button ? paper jamed, i removed the paper but now nothing happens
Check the following Steps to fix HP Printer Carriage Jam :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Oct 11, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Our HP Office Jet Pro 8500 printer has a message stating there is a paper jam when there is no paper jam. How can this be fixed?
Check the following Steps for fix Hp printer carriage Jam :
  • Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
  • Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
  • Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
  • Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Oct 05, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
False paper jam reading.keeps say to clear paperjam. called HP and they said its a common problem,too expensive to fix,buya new one from us for 300 bucks
Check the following Steps for fix HP printer carriage Jam :
Sep 14, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Carriage jam. what should I do i can not problem
Check the following steps for solve Hp paper jam :
Sep 13, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Hp cm2330 remove shipping lock
HP Color LaserJet CM 1312 Series MFP customers may experience a failure during initial printer startup. After installing the print cartridges and powering on the printer they may receive an error condition or error message on the printer’s display. The printer’s orange Attention LED will flash and a Remove shipping lock from XX cartridge message will appear on the printer’s display; where XX represents the black, cyan, magenta or yellow print cartridge or any combination.
SOLUTION: First, verify the print cartridge shipping locks (orange ring attached to the toner as shown below) have been removed from the print cartridge(s) in question. Second, verify the front and back doors of the printer are properly closed. If the shipping lock has been removed, all doors are closed, and the Remove shipping lock from XX cartridge error remains a unit exchange is the recommended solution.
Contact Hewlett-Packard Customer Support. Refer to your warranty/ support documentation for the number to call in your area. Refer to this document’s number (c01677135) with your customer service representative.
Hp tech support phone for this model # : 1 800 334 51 44
Or you can take the printer to an HP Authorized Repair Center, heres a link will help you find one near your location:
http://h20465.www2.hp.com/GPL/search.aspx?language_code=en&country_code=us&SearchType=SSP
You can contact me directly on:
eliteprintersolutions@gmail.com
Jul 15, 2010 | HP Laserjet CM2320nf All-In-One Color...
HP LaserJet Pro 400 M451dn Workgroup Color Laser Printer Logo
466 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
