Question about Dell E176FP 17" LCD Monitor
NEC mutisync LCD 1700m Flashing/Blinking
The LCD monitor keeps on Flashing/Blinking. The connection with the CPU is OK. I can see the Window screen between the flash. It is working OK with other monitor. Can somebody hepl me. I have already unscrewed the monitor and I don't see any capicitor burn out
  • Palla Jan 24, 2008
    Thank you for the help. I have found the problem. The two capicitor were bulged up. I replaced them and it is working now.
  • 108 Answers
You have an intermittent problem. That means a component is going bad in all probability. If it was a capacitor that burned up you would not have any picture. Your problem requires a schematic plus an tester. You would need to check values for all components. If you have not done this (and assuming you can follow an electrical schematic) and if new to diagnosing these types of problems plan on spending many hours at the task. The question you need to ask yourself perhaps is is it worth it.....particularly since even if you find the problem it may require ordering parts...and you might need some basic soldering skills, etc.....If it was me...I would probably either send it in for repair (deifnitely if under warranty) or buy another.
Posted on Jan 24, 2008
Monitor Not Powering On
Did you tried changing the lcd settings to default?
Feb 24, 2014 | Acer S231hl Bid 23" 1080p 5ms Widescreen...
NEC 17"1700M Works fine most
Either an overheating video-card, or a loose connection between the video-card and the monitor.
Jun 25, 2011 | NEC MultiSync LCD1700M (White) 17 in. Flat...
First check your monitor light is blinking or not. If it is then--
Check your monitor cable which is connected your CPU. If it is ok then
Open your CPU and unplug *********** board power cable and re-install it.
And also remove RAM and clean with a brush softly and re-install it.
Best of Luck
May 13, 2011 | Dell E173FP 17" LCD Monitor
I have a NEC Mutisync LCD 2070NX monitor & the On-Off switch is "loose" making it difficult to turn the monitor off & on. Where can I go to get it fixed or would the cost of the repair be too...
it should be possible to take the cover off and fix your self with some contact adhesive like no more nails (etc) as the switch itself does not appear faulty this should work fine..
Aug 03, 2010 | Computers & Internet
My acer lcd monitor has no display and the power button keeps blinking. is there a way to fix this myself.
that may be the problem of cpu disconnect the signal cable and observe the massage that "no signal check the signal cable "if that massege appears then monitor is ok problem lies in the cpu
Mar 15, 2010 | Acer AL1511 15" LCD Monitor
Hp l1906 LCD MONITOR SCREEN WONT DISPLAY. power lcd green light keep blinking. Any solution? thx
It is possible that the video card in cpu is bad, try hooking up another monitor to the cpu (computer) if you have one that will let you know if it is the monitor or the computer video card, Could be as simple as the driver is missing.
Feb 01, 2010 | HP L1906 19" LCD Monitor
Hi, my monitor does not display anything but the lid light just keep blinking.
You should check your display cable from CPU to Monitor. If it just blinking then problem with you connection bitween CPU and Monitor So just check and keep enjoy.
Nov 11, 2009 | Samsung SyncMaster 710N 17 in. Flat Panel...
Hi I just bought 7 NEC Multisync LCD1550v monitors and they all have the same problem. when plugged in all i get is a blinking power light. 1 of them showed signs of life for just a second but that was it....
You buy a new LCD Monitors, now still not working., if that new LCD Monitor is OK, then check your VGA Card, its inside the CPU maybe its broke or not connect properly inside. This are the cause of not displaying in your LCD Monitors.
If you here some beeps of your CPU then find out how many beeps and tell us here immediately.
Aug 03, 2009 | NEC-Mitsubishi MultiSync LCD2170NX (Black)...
Dell flat screen started flashing, green light was blinking then screen went blank and green light is on. Tried unplugging etc...time for a new one?
No. It is not a Flat Screen issue. It is a CPU issue. You CPU is not sending signal to your flat screen so the green light is flashing. Try to:
1. Reset OR
2. Unplug the CPU case, Open the CPU, the interchange the RAM modules, OR
3. Same with step 2 but unplug and then plug back in all expansion cards like audio, video cards, etc.
It seems that your system needs discharging from a frozen state.
Jul 26, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
Hello there !
First things Frist:
1) Test the switching on keyboard for external monitor and see if work, or you disable the laptop monitor.
2) install the driver for select external monitor. depending the video card, you may have 2 display panels, to select, on that driver. NVIDIA or RADEON
Mar 07, 2008 | Computers & Internet
Dell E176FP 17" LCD Monitor Logo
110 people viewed this question
Alun Cox
