Question about Briggs & Stratton LawnBoy 20Inch 65 HP Gas Powered Variable Speed Rear Wheel Drive Self Propelled Lawn Mower With Electric Start
Throttle on lawn-boy self-propelled mower
How do I adjust the throttle?
  • 208 Answers
SOURCE: can't get my lawn boy started
check for a faulty wire to the engine kill switch it may be contacting the ground
Posted on Jun 22, 2009
  • 143 Answers
SOURCE: Briggs & Stratton Modle# 100000 will not stay started.
your engine is only running on the fuel you are pumping in, the carb. is not lifting the fuel on its own, maybe because of water in the bowl or dirty jets. You must take the bowl of and clean it out and depending on the type of carb. it might need a new diaphragm. Stephen.
Posted on Apr 25, 2010
Testimonial: "very helpful. will follow instructions. Thank you"
hunter19_46m
  • 7482 Answers
SOURCE: I can crank my murray gas lawn mower 6.5 quantum
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 15, 2010
  • 3 Answers
SOURCE: Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower: my engine will only stay running for about 3 secon...
Maybe the engine is running with the fuel from the primer bulb (about few seconds), the carburator is not working and need to be removed checked and cleaned, the most common fail is a jet clogged.
Posted on Dec 16, 2010
hunter19_46m
  • 7482 Answers
SOURCE: My Troy Built Self propelled
Hi smithjazzy8...
Check your oil level, it sounds like it has got too much oil in the crankcase.
The oil level should be to the last two threads on the fill plug threads of the engine.
This is the main cause of white smoke coming from the exaust of the engine.
Free Answer...Please take time to rate me.
Posted on May 31, 2011
Husqvarna Problems
adjust throttle controlso it will close
Apr 26, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
Toro self-propelled lawn mower: throttle doesn't work, I suspect I may have mis-connected the spring and rod connecting the swivel plate to the lever arm. Does that make sense to anyone?
Yes it makes sense. I was working on a throttleless one and it would not come up to speed, I had hooked it up to the wrong side of the shaft, or conceptually, the pivot point. It was doing the opposite of what it should have. I suggest taking a really close look at the attachment piece looking for wear or rub marks to indicate which hole it should be in.
I hope this gets you going.
Aug 09, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
Briggs and Stratton Troy Built 21inch 190cc 650 series Gas Powered self propelled Lawn Mower. I moved to new house and the movers lost the manual. I bought it last year so only one seasons use. How do I...
If how you described you unit is true you do not have an electric mower you have a gas powered mower, you DO NOT have a battery!!!??? Place the throttle lever to choke position and prime carb with primer bulb 3-5 times then pull cord. Wala!!!! It's running rite. That guy at Loews must have been smokin somthin. Good Luck...
Apr 22, 2011 | Briggs & Stratton Lawn-Boy Insight Series...
I can push the handle all the way in, but I get very little speed from the mower.
Your throttle cable likely needs adjusting.
It should be fastened on the engine with a screw. Loosen that screw and adjust while engine is running then tighten Keep fingers away from underneath while engine is running.
Oct 05, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Apr 25, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Briggs & Stratton LawnBoy 20Inch 65 HP Gas Powered Variable Speed Rear Wheel Drive Self Propelled Lawn Mower With Electric Start Logo
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
