Question about IBM pSeries p655 Server
Debian on p655
Hello there! We are trying to install debian on a p655 over yaboot but encountered the following problem: first we set up a dhcpserver and a tftp server, the filename points to the yaboot binary in the tftp root. over the openfirmware prompt we see its getting the proper ip via dhcp, the gateway and stuff and the yaboot file, then the error occurs and it says something about unknown or corrupt filesystem. we thought it was because of a malformed device string to the tftp server but after trying almost all combinations quit trying. Has anyone ever installed debian on a p655 and knows how to setup the correct files? i used the files from: http://ftp.de.debian.org/debian/dists/etch/main/installer-powerpc/current/images/powerpc64/netboot/ I think those are the right ones, but i think something within the configuration files is broken. greetings
    Novelist:
    Scholar:
  • 114 Answers
Are you over thinking this? Have you checked the source and target media's file systems for 1: errors and 2: suitability of file system format? Have you confirmed the integrity of the source files? Questions like this can seem simplistic but when diagnosing any problem always start at the beginning. You are using an distro installer that is suitable for an IBM p655's architecture.
Posted on Aug 30, 2007
SOURCE:
SATA on dell dimension 4550 with Debian
look in the devicemanager what does it say.
update thrue the deviemanager or search the internet
May 26, 2013 | Dell Dimension 4550 PC Desktop
How do i download missing firmware for ubuntu
Loading Missing Firmware As described in the section called "Devices Requiring Firmware", some devices require firmware to be loaded. In most cases the device will not work at all if the firmware is not available; sometimes basic functionality is not impaired if it is missing and the firmware is only needed to enable additional features.
If a device driver requests firmware that is not available, debian-installer will display a dialog offering to load the missing firmware. If this option is selected, debian-installer will scan available devices for either loose firmware files or packages containing firmware. If found, the firmware will be copied to the correct location (/lib/firmware) and the driver module will be reloaded.
note.png Which devices are scanned and which file systems are supported depends on the architecture, the installation method and the stage of the installation. Especially during the early stages of the installation, loading the firmware is most likely to succeed from a FAT-formatted floppy disk or USB stick.
Note that it is possible to skip loading the firmware if you know the device will also function without it, or if the device is not needed during the installation.
warning.png Support for loading firmware is still relatively basic and is likely to be improved in future releases of the installer. Currently debian-installer will for example not display any warning if you choose to load missing firmware, but the requested firmware is not found. Please report any issues you encounter by filing an installation report (see the section called "Submitting Installation Reports").
Preparing a medium Although in some cases the firmware can also be loaded from a partition on a hard disk, the most common method to load firmware will be from some removable medium such as a floppy disk or a USB stick. The firmware files or packages must be placed in either the root directory or a directory named /firmware of the file system on the medium. The recommended file system to use is FAT as that is most certain to be supported during the early stages of the installation.
Tarballs containing current packages for the most common firmware are available from:
Just download the tarball for the correct release and unpack it to the file system on the medium.
If the firmware you need is not included in the tarball, you can also download specific firmware packages from the (non-free section of the) archive. The following overview should list most available firmware packages but is not guaranteed to be complete and may also contain non-firmware packages:
It is also possible to copy individual firmware files to the medium. Loose firmware could be obtained for example from an already installed system or from a hardware vendor.
Firmware and the Installed System Any firmware loaded during the installation will be copied automatically to the installed system. In most cases this will ensure that the device that requires the firmware will also work correctly after the system is rebooted into the installed system. However, if the installed system runs a different kernel version from the installer there is a slight chance that the firmware cannot be loaded due to version skew.
If the firmware was loaded from a firmware package, debian-installer will also install this package for the installed system and will automatically add the non-free section of the package archive in APT's sources.list. This has the advantage that the firmware should be updated automatically if a new version becomes available.
If loading the firmware was skipped during the installation, the relevant device will probably not work with the installed system until the firmware (package) is installed manually.
note.png If the firmware was loaded from loose firmware files, the firmware copied to the installed system will not be automatically updated unless the corresponding firmware package (if available) is installed after the installation is completed.
hope this helps
Jul 17, 2012 | Computers & Internet
Un able to install HP 2410 Scanner in Ubuntu 10.4
Here is the site where you can download Iscan program:
AVASYS Corporation web site to download Iscan http://www.avasys.jp/lx-bin2/linux_e/scan/DL1.do
Once you download it and try to run it, it might ask you for a missing library that needs to be installed. It depends on your destripution or Ubuntu release version. I am using 10.04 on my computer. If you get that message, here is the link to go and download this library from Debian site
Debian web site download page http://packages.debian.org/lenny/i386/libltdl3/download
Install the library then re-run the iscan program and you are done, enjoy. Just one more thing when you run the Iscan for the first time you will need to run it as root, to be able to search and find your scanner.
Feb 28, 2011 | Computers & Internet
How we can install Linux ? please easy method write down here
Just download and install any lightweight Linux distribution, and then write it to a CD or DVD with a CD writer program. If you don't have one and use Windows, you should try ImgBurn.
http://www.imgburn.com/
Some Linux distributions that should run well on this laptop are:
http://www.xubuntu.org/
http://lubuntu.net/
http://www.dreamlinux.net/download.html (XFCE)
http://cdimage.debian.org/debian-cd/6.0.1a/i386/iso-cd/debian-6.0.1a-i386-xfce+lxde-CD-1.iso
Oct 11, 2010 | HP Compaq Evo n400c Notebook
Cannot re-install Windows on corrupt debian OS
best way to kill this off and start fresh would be to make a windows 98 bootdisk (can be found on bootdisk.com) put the floppy in and it will boot to dos. In dos type fdisk and hit enter and it will bring you to a partition menu. In that menu delete the non dos partitions, reboot the computer and run windows setup again.
Jun 22, 2009 | Acer Aspire 5735 Notebook
Wiped harddrive
You need to have a bootable disc with the OS boot from it and install.
Dec 18, 2008 | Compaq AlphaServer DS10
Debian install failed
You might try running one of the live cd distributions to see if the machine hardware is supported that way. You do need a minimum of 128 MB of ram, might be 192 for a live system. It could just be that the system doesn't have enough ram to run Debian, that would explain why it wouldn't finish installation, and why it fails to load now. Check the readme and release notes for minimum system requirements. Maybe you would do better with a leaner distro like DSL?
Dec 17, 2008 | IBM POWER SUPPLY 8565/80 64F3693 Power...
Toshiba Satellite A35-S1592 Sound
You might try browsing a few of these sites at the link bellow. It might help with the sound issue for the Debian Sarge install.
http://www.google.com/search?hl=en&q=Toshiba+AC%2797+Audio+Controller+drivers+for+Debian+Sarge
Aug 25, 2008 | Toshiba Satellite A135-S4527 Notebook
I cant open bluetooth and webcam in my toshiba laptop. this problem is only for linux debian operating system
hello sir
try opening windows device manager
and see if they bluetooth and webcam is working correct
if not try and take it to a tech they should be able to fix it for ya
cheers mate
Jul 11, 2008 | Toshiba Satellite A100-S8111TD Notebook
While installing debian on IBM Xseries 306m it can't detect HDD
Have you initialized the disk from within the BIOS ? if not when you boot the server it says there are no hard disks.
May 07, 2008 | IBM eServer xSeries 306m 8849 (8849E5U)
Open Questions:
See all IBM pSeries p655 Server Questions
Computers & Internet Logo
121 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
