Question about Air Tools & Compressors
Compair compressor 6000e how many liters of oil?
3 Suggested Answers
  • 54 Answers
SOURCE: I've got a compair 660A
I didn't think this was a pressure lubed machine. Is it leaking around the shaft seal, behind the flywheel? If it's just the oil leak, and the unit runs/sounds fine otherwise, you could put a gasket and seal kit in it.
You can search online for parts, but probably have better luck calling it a LeRoi 660A. Compair bought them years ago, and let the piston compressor business slowly die.
Posted on Mar 15, 2011
  • 1212 Answers
SOURCE: COMPAIR 6000E COMPRESSOR
Pressure switch may set too high. Reducing tension on the pressure switch spring should reduce pressure for cycling compressor motor off
Posted on Feb 11, 2012
CompAir Hydrovane 830 running but no air in tank
It must have a leak somewhere or be rotating in the wrong direction? Is it wired up correctly.Hyrovane compressors usually run quickly is the motor spinning well.
Jun 08, 2015 | Air Tools & Compressors
After placing my Haier 7 cu. ft. / 198 liter Chest Freezer HCM070LA in a horizontal or tilted position it doesn't want to freeze
If you have run it in a tilted position, the oil has migrated from the compressor to the evaporator. You need a technician to flush the oil back to the compressor. Only run equipment like this on a flat level surface. and always allow to stand a few hours after moving before switching on.
May 01, 2014 | Haier 7 cu. ft. / 198 liter Chest Freezer...
What oil do i put in a compressor (I have a Stanley 50 liter unit) ?
Compressor oil is different than engine oil. Compressor oil can be found in places like Harbor Freight or any place that sells air compressors
Aug 25, 2013 | Stanley Air Tools & Compressors
Feb 10, 2012 | Air Tools & Compressors
I've got a compair 660A air compressor and have oil leaking out of the body of the oil pump cover.
Mar 15, 2011 | Air Tools & Compressors
Ive got a compair c42 compressor and oil is coming out with the air.i have alredy replaced the seperator filter and all pipes and valves have been cleaned and are fine but the oil is still coming out.the...
sounds like the scavenge line is plugged or not installed correctly, this is something you may want to contact me on, as it could be a number of problems besides this also that could affect this problem. please check out my web site, www.morrismachineservicesllc.com
Dec 08, 2009 | Air Tools & Compressors
A\C compressor replacement
THERE IS NO SET AMOUNT, U DRAIN THE OIL OUT OF THE OLD COMPRESSOR AND THEN ADD THAT SAME AMOUNT TO THE NEW ONE PLUS ONE OUNCE
Jul 06, 2009 | 2000 Mercury Cougar
Air Tools & Compressors Logo
21 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
