Question about Danby DDR2504 Dehumidifier
Is there a recall for model DDR2504 dehumidifier.Had strong heat type smell and blew circuit breaker cleaned filter and tried again with same results.
LG label inside model LX72HACG. Serial number UQM2520042190870.Danby model number DDR2504, serial number 0404020701604. Is there a recall.
4 Suggested Answers
SOURCE: We lost the directions for
I had the same problem but was able to find a link from "Danby's" website. Hope it helps!!
http://www.danby.ca/cms/uploads/products/en_manual/DDR557HE.PDF
Posted on Jul 12, 2008
heatman101
  • 43501 Answers
SOURCE: fan runs, but compressor does not start
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 18, 2010
Sheikhtijani
  • 1284 Answers
SOURCE: Danby Dehumidifier Model # DDR557HE Serial #
If you are having problems with your dehumidifier freezing up them here are a few things that you can check and also a few things that may help you.
First check the ambient temperature of the room at the level of the dehumidifier. If it is below 65 degrees and you do not have a special low temperature dehumidifier then you are asking for trouble. Most units are only designed to work in temperature 65 or higher and will freeze if they are working at lower temperatures. Some even will not work well below 68 degrees F.
Many dehumidifiers will shut off when the coil starts to freeze to let them thaw, then they will restart when the coil is warm enough again. This can take an hour or so. Some will not shut down the compressor and when the dehumidifier coil starts to freeze it reduces the air flow and only compounds the problem.
Check the air flow over the coil. If the coil becomes dirty or the fan motor stops or even slows down a bit, you will get freezing. The dehumidifier is very dependent upon the proper amount of air going over the coil to keep the coil warm enough to not freeze. Any restriction will cause problems.
The final and worst thing that can happen is for your dehumidification unit is to develop a slight leak in the refrigeration system. This will cause the coils to run even colder then they would normally and this will create the same problems. If everything else check out then you may have to have the refrigeration system checked by a professional. The problem with this is that many of these units only cost a few hundred dollars and a service call can soon add up to more then the unit is worth.
Some things that you can do to help out a dehumidifier that is freezing up are:
Raise the temperature of the room and provide a bit of heat for the room as the dehumidifier is actually a very small A/C unit.
Raise the dehumidifier up off of the floor… the air is usually warmer when you go higher up in the room, hot air rises.
Clean the coils off so that the air can flow through them easier and keep them warmer.
Make sure that the fan motor bearings are oiled and that the fan is running freely. Even a tiny bit of resistance will slow the fan enough to make a difference.
By checking all these things out and making some small changes you maybe able to make your dehumidifier work much more effectively.
Take care
Posted on Jul 23, 2010
HE70ER-L Are there any recalls on this Haier Dehumidifier model?
Results
Dehumidifier Recalls - ConsumerAffairs.com
https://www.consumeraffairs.com/dehumidifier-recalls
  1. Cached
The recall is being conducted in cooperation with the U.S. Consumer Product Safety Commission (CPSC). December 30, 2009 LG Electronics is recalling about 98,000 portable dehumidifiers. The power connector for the dehumidifiers compressor can short circuit, posing fire and burn hazards to consumers.
Humidifiers & Dehumidifiers Recall List by WeMakeItSafer
wemakeitsafer.com > ... > Home & Garden > Temperature & Humidity Control
  1. Cached
  2. Similar
Danby, De'Longhi, Fedders, Fellini, Frigidaire, Gree, Kenmore, Norpole, Premiere, Seabreeze, SoleusAir and SuperClima Dehumidifiers. A recall was issued on 2013-09-12 due to a potential fire and burn hazard.
Dehumidifier Recall: How to Find Out if it Affects You
learn.compactappliance.com > A/C & Heating
  1. Cached
  2. Similar
Jun 12, 2014 - How to Find Out if Your Dehumidifier Was Recalled. ... Many popular brands known for having high quality dehumidifiers such as Danby, Frigidaire, and Soleus had models affected by this recall. ... Brands have taken different approaches to how they have responded to the Gree dehumidifier ...
Dehumidifiers recalled after overheating, fires - USA Today
www.usatoday.com/story/money/business/2014/.../dehumidifiers-recalled.../9145635/
  1. Cached
  2. Similar
May 15, 2014 - Appliance manufacturer Gree has issued another recall for a line of its ... .cpsc.gov/en/Recalls/2014/Gree-Reannounces-Dehumidifier-Recall.
Public Notices ' Haier America
https://www.haieramerica.com/public-notices
  1. Cached
Product Recalls. The latest public notices can be found here. Recall Date. Haier America Expands Recall of Chest Freezers Due to Fire Hazard, Sunday, May 12 ...
Nov 07, 2016 | Haier Dehumidifiers
I have a Danby which has the feature for heat on the left-hand side. I just bought it a month ago, but can't lay my hands on the instruction book right now. Can you tell me the proper procedure for...
Lori, the Danby Humidifier, Model # DDR2504 does not have a heating function. It's just a 25 pint dehumidifier. In fact, there are no Danby Dehumidifiers that have a heating function.
By, chance do you have Multifunction Air Conditioning unit, rather than a dehumidifier? If so, please provide the correct model number.
Thanks for choosing FixYa.
Sep 11, 2011 | Danby DDR2504 Dehumidifier
Ddr2504 i need a manuel book i lost the manuel book and i would like to get a book back
Here's a link to your Owner's Manual. Just click on the link and follow the instructions for the Free manual. You can download and print the manual for future reference. Take good care of it, as your model has been discontinued.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Jul 14, 2011 | Danby DDR2504 Dehumidifier
The amp blew in the DD50PC Delonghi and we need to replace it. What is the amp?
rmbm521 - I would like to help you, I have been offering solutions to humidifier problems for some time. But, I have never heard the term "amp", as would apply to a dehumidifier. In most general electrical terms "amp" or "amps" is the amount of electrical draw or use that an electrical appliance uses. It's short for "ampere".
I don't know where you heard it, read it or who told you that. But, they may have been referring to the circuit breaker , that's in your home's circuit breaker panel,. The one that feeds the outlet, the dehumidifier is plugged into. If that's the case, was your dehumidifier tripping one of the circuit breakers in you circuit breaker panel? If that's the case, they meant, the circuit breaker was not rated high enough to carry the load of dehumidifier, when it was in operation.
Hope this helped you. Please let me know. Thanks.
Jun 16, 2011 | DeLonghi DE50P Dehumidifier
DDR2504 dehumidifier has always worked well. Now the fan runs and all seems normal, but the humidity is not dropping and you can tell that the dehumidifier is not cutting in and out. I do not have it on...
derkfarm - It may simply be a case of the humidity extraction level being set to high and/or the air intake filter needs to be removed and cleaned.
Solution: Lower the humidity extraction level to 32 - 35% and clean the air filter.
If the unit is in a basement, the ambient air temperature at floor level is colder than at chest level. Dehumidifiers don't work well at temperatures between 40 - 60 degrees F.
Solution: Set the unit up off the floor on a sturdy table, cabinet, counter top, etc. It must be sturdy enough to handle the weight of the unit, plus a full tank of water and the vibration, while in operation.
Any or all the simple solutions above may solve the problem. But, we won't know, until you try them.
Please let me know if it helped or didn't solve the problem. Thanks.
Jun 15, 2011 | Danby DDR2504 Dehumidifier
I have a Whirlpool AD75UST humidifier that stopped running, almost like it blew a fuse or something. Does it have a fuse somewhere? Any other possibilities? Thank you!
Have you checked the receptacle it's plugged into, to see if it's still working? Use an electric lamp to check this. If the lamp doesn't work, the circuit breaker in the home's main panel has been tripped. Unplug the dehumidifier and reset the circuit breaker. Then plug the dehumidifier back in. If it trips the circuit breaker again, there's an electrical problem within the dehumidifier.
In answer to your direct question ... some dehumidifiers have a reset switch. It's probably on the back of the unit, above the water collection tub. if all else fails consult your Owners Manual's Trouble Shooting Guide. If you have misplaced it, you can download it from the Whirlpool Appliance starting at their home page.
Hope this helped head you in the right direction to solving your problem.
Mar 01, 2011 | Whirlpool 75-Pint Dehumidifier
Had dehumidifier for @ 2yrs...been working fine..all of a sudden tripping breaker...cleaned filter.. ...thankx..chris
compressor is more then likley locked up. it is probably cheaper to replce. Try another outlet first but if you have the same result then its time for a new on. sorry
Sep 15, 2009 | Dehumidifiers
Runs, but overheated, tripped outlet causing freezer full of rotten food
There was a recall on these - it depends on the age.  I bought mine in 2003 or 2004, and they sent a repairman out to replace a circuit board.  Call Maytag to see if yours was in the recall.
Aug 09, 2008 | Maytag M7DH65B2A Dehumidifier
Danby DDR2504 Dehumidifier Logo
139 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
