Question about Garden
Weedeater xt 125 kt
Fuel to oil mixture?
SOURCE: gas/oil mixture for ryobi weedeater
It is 2.6 fl oz of oil per 1 gal of gasoline.
Posted on Apr 29, 2009
  • 3600 Answers
SOURCE: Weedeater XT 85T trimmer fuel lines rotted
it's in the fuel tank it goes from the carburator into the fuel tank and replace the fuel filter while you have the tank off.
Posted on Jun 21, 2009
canbruce75
  • 1776 Answers
SOURCE: Gas/oil mixture for my Homelite Trimlite weedeater 25 cc
50:1
Posted on Jul 12, 2009
bbreton
  • 437 Answers
SOURCE: whats the mixture of oil/gas for a homelite
3.2 oz of 2 cycle oil to 1 gallon of regular gasoline, 40:1 ratio.
Posted on Jul 13, 2009
  • 3600 Answers
SOURCE: oil / gas mixture
it's 32;1 but here is a web site that you can call to be sure. http://www.yardpartswarehouse.com/pages/parts/viewbybrand/20/Homelite.aspx
Posted on Apr 11, 2010
Testimonial: "thanks, i appreciate the quick response"
Oil petrol mixture for Rockwell 26cc weedeater
Two cycle engines run on a mixture of gasoline and oil. Each engine type is designed to run on a specific gas-to-oil mix ratio.
IMPORTANT: Use only oil that is labeled for use in "Two-cycle" or "Two-stroke" engines. Home Depot and other stores now have "premixed fuel" of gas and 2 cycle oil.
To mix two-cycle fuel, start by putting correct amount of oil in gas can. Then slowly add correct amount of gasoline. Do not try to mix gas and oil directly in gas tank of equipment.
IMPORTANT: Do not use any fuel that is over 30 days old. Do not mix more fuel than you are likely to use in a month. Old fuel can gum carburetors and prevent starting. Always use fresh fuel.
The chart below shows correct amount of oil per gallon that each mixing ratio requires. Expect that yours will be between 32 gas to1 oil and 50 to 1. 32:1 and 50:1 are most popular.
Ratio GAS:OIL UNITED STATES OIL per 1 U.S. GALLON Gasoline
(128 oz.)
*INTERNATIONAL OIL per 1 IMPERIAL GALLON Gasoline
(160 oz.)
*INTERNATIONAL OIL per 1 LITER Gasoline
(metric)
32:1 4 oz. 5 oz. 31.25 mL 40:1 3.2 oz. 4 oz. 25 mL 50:1 2.6 oz. 3.2 oz. 20 mL
Jan 01, 2015 | Weedeater Garden
Why is my yamaha xt 125 burning hot after just a few km?
If it's running too hot, your fuel mixture may be too lean. Check the spark plug -- if the electrode is white rather than tan, the carb needs adjustment to a richer mixture.
Also, kinda obvious, but are you sure there's enough engine oil and it's circulating properly?
If the fuel mixture is OK, better get a mechanic to check the oil system before you sieze the motor.
Oct 12, 2014 | Yamaha XT 125 X Motorcycles
Correct fuel mixture for homelite zip start weedeater.25cc,ut20785..
50:1 five liters unleaded petrol and 100ml 2 stroke oil
Sep 09, 2014 | Homelite Garden
Location of air/fuel mixture screw on Yamaha xt 125 r
Hi, Tom for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Location of air fuel mixture screw on Yamaha xt 125 Google Search
Yamaha XT125 Carb Tips Mikuni 3D6
http://gigi600.altervista.org/immagini/xt125r/XT%20125%202005_service.pdf
OEM parts for Yamaha
http://www.yamaha-motor.com/assets/service/manuals/2010/lit-11626-23-37_xt250_2010_1680.pdf
Jan 20, 2013 | Yamaha XT 125 R Motorcycles
Yamaha xt 125 fork oil quantity
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
https://yamahaclub.com/forums/topic/36359-fork-oil-capacity-and-spec-for-xt-125-r-2007
xt125r
Yamaha xt 125 service manual
http://mybikemanuals.com/yamaha/yamaha-xt-owners-manuals
Aug 23, 2012 | 2007 Yamaha XT 125 R
XT 125 R carburetor diagram
Hi, Anonymous and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on blue links below. Good luck and have a wonderful day.
XT 125 carburetor diagram Google Search
Jun 14, 2012 | Yamaha XT 125 R Motorcycles
Idle screw adjustment Yamaha 2005 XT 125 R
Hi, Anonymous the carburetor throttle shaft wheel has two cables the cable closest to the right side of the bike is the throttle cable and the one closest to the left side is the idle cable. Right about the middle between the two is the idle adjustment bolt it faces out towards the air filter end of the carb. The engine should be at operating temperature with the enrichener off to set the idle between 950-1050 rpm. Turn the idle adjustment bolt clockwise to increases idle speed and counterclockwise to decrease idle speed. If you have access to your air fuel mixture bolt you may adjust it as well if not there is a video below on how to gain access, make sure you start with clean or new spark plugs. Gently turn the air fuel mixture bolt clockwise until it starts to bottom out "STOP" do not over tighten as it will damage the taper on the end, now back it out 2 full turns to establish a starting point start the engine and check the idle rpm's and adjust the idle adjustment bolt accordingly for 950-1050 rpm if necessary, adjust the air fuel mixture bolt 1/4 turn at a time and let the engine settle for about 10 seconds, clockwise for a leaner mixture and counterclockwise for a richer mixture you are seeking the highest rpm your air fuel mixture bolt can acquire without going past 3 full turns from bottom then readjusting the idle adjustment bolt back down to 950-1050 rpm If you can not detect any rpm change and can not stall the engine by turning the air-fuel mixture bolt all the way in then your pilot/low-speed jet is too big. Final adjustment should be made with a clean air filter mounted to the carburetor. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have wonderful a day.
XT125x misfires lot and will not idle
YAMAHA XT125R XT125X FULL SERVICE REPAIR MANUAL 2005 2011 Download Manuals... $9
May 28, 2012 | 2005 Yamaha XT 125 R
What is the fuel to oil mixture ratio for my gas featherlight weedeater?
That oil/fuel mixture would be 50-1 or 2.8 ounces per gallon...
heatman101
Sep 08, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
Won't stay running for more than 10 min
Not true. It is important to read the package and fuel/oil mixture ratio ie: 40:1, 50:1, 32:1, as long as the mixtures are the same, you can use one tank for all of the 40:1 tools, one can for all the 50:1 mixtures, one can for all the 32:1 mixtures. essentially all the 2 stroke oils are the same, the numbers just designate parts of oil(quantity) to parts of gas.
Aug 02, 2009 | Garden
Jun 21, 2009 | Garden
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
