Question about Polaris Pb4 - 60 Booster Pump
Polaris Booster Pump Brand New keeps shutting off
We bought a brand new booster pump pb4-60 last summer and it kept shutting off so we had all of our electral wiring checked and the company replaced the pump on the understanding that it was faulty. We now have the new pump hooked up and the polaris will run for about 5 minutes then shut off any ideas on what this could be?
    Top Expert:
  • Polaris Master
  • 5,080 Answers
If wired 120 check side of motor rewire for low voltage
Posted on May 22, 2016
5 Suggested Answers
  • 1114 Answers
SOURCE: Pump comes on for about a minute...then shuts off..
Has this pump worked at all -pumped water?
When it's running for about a minute, is it pumping water?
Is this a self priming pump or do you need to prime it?
Posted on Jun 28, 2009
john224
  • 1378 Answers
SOURCE: polaris booster pump runs for minute but quits. Tries to restart
The motors are usually dual voltage and factory connected for 230V. Are you sure it is properly wired and set for the correct incoming line voltage?
Posted on Aug 24, 2009
Coastsider
  • 331 Answers
SOURCE: Just bought a new polaris booster pump (PB4-60)
Have you checked for voltage at the pump motor? Did you wire it correctly? Is the motor 110V or 220V. Did you match the motor to your existing voltage?
Posted on Apr 14, 2010
john224
  • 1378 Answers
SOURCE: My brand new Polaris 380
Thank you for posting your question here on Fixya.com.
It is likely due to cavitation in the booster pump impeller. The easiest way to correct the issue is to slowly close a throttling valve on the booster discharge. If there is not one present install a ball or gate valve near the pump discharge line and slowly close it with everything running until the noise stops. Generally speaking closing the valve about a quarter of the way seems to be when most pumps run quietly but the setting is unique to each installation.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Posted on May 16, 2011
I have a panasonic split system in the kids bedroom its an ECONAVI indoor unit is CS-E9NKR we have not used this A/C since last summer, now the compressor will not start, only the indoor unit operates
Typically on a mini split the outdoor unit is powered and the indoor unit gets its power from the outdoor unit. If the unit is a year old you might have lost your charge. Look at the connections at the indoor unit and outdoor unit. You will typically see oil or a dirty area on your copper were there is a leak.
Nov 16, 2013 | Panasonic Heating & Cooling
1993 ford f150 shut off driving down the road at 60mph would turn over but not start until after beating on the gas tank and jiggling gas line hoses out of tank truck started and i got it home any ideas...
check the wires on the feed to the fuel pump ,,also check that it hasnt got the cut out thingy on top of the fuel tank like the ford explorer,unless this is only fitted on the europeon models .?
Aug 14, 2017 | 1993 Ford F150 SuperCab
Goes into overload and shuts down
Not very much information in your problem troy but you might be drawing more amps than your producing. I had bought a nice little Craftsman electric tire pump but my Yamaha kept dying. After reading the labels, my 2400IS puts out 15 amps and my tire pump needed 18 amps, my friend now has a nice tire pump for his home use. I've seen post that RVers have to add the "booster" kit to start their air conditioners, extra power is needed to start them after that the 2400 can run them. Just a thought, try reading the metal tag on what your trying to run and see how many amps it needs. Anything over 15 will shut you down and some will need that extra "boost" to get them started. I seem to think I read somewhere that it is about $75.00 for the Yamaha booster kit.
Aug 12, 2013 | Yamaha EF2400iS Portable Generator
Polaris Booster Pump PB4-60 Overheating
see side of motor make sure wiring correct if ok maybe you got a bad one
Aug 29, 2012 | Polaris Pb4 - 60 Booster Pump
New BP4-60 detects low amperage and shuts off-turns back on
check wiring if wired 120 volt must change wires inside motor see side of motor
Aug 24, 2012 | Polaris Pb4 - 60 Booster Pump
New polaris pb4-60 booster pump shuts off when polaris recycles, why?
sounds like weak motor the back pressure is overheating the motor replace
Jul 14, 2012 | Polaris Pb460 Polaris Booster Pump...
I have installed a new pb4 pump and it keeps blowing off the hoses on the top side out to pool. I have checked for obstrustions in lines, I have siliconed my connections, i have lowered my psi thru return...
I assume you are talking about the flexible hose that is connected with a threaded collar and clamp the hose to the fittings.This can be caused by vibration, warn parts, high pressure or collar not tightened sufficiently. If the parts were installed with the previous pump then they may be worn. If you tried replacing the the fittings then you may want to change the parts to PVC fittings and piping instead. About half of the booster pumps I have seen were connected using PVC piping. I hope this helps.
Aug 22, 2011 | Polaris Pb4 - 60 Booster Pump
My Polaris PB4-60 was installed last August brand new. It completed the season working fine. When the pool was opened in the spring the pump is dead, nothing happens when it is switched on. I checked the...
Sounds like it is popping a safety switch or the other issue is that it is getting wet internally from the moisture in the air and is causing the pump to fail, It should technically still be under warranty, I would call the company that replaced the pump or that you bought the pump from and let them know what is going on.
May 21, 2011 | Polaris Pb4 - 60 Booster Pump
My brand new Polaris 380 booster pump is noisy. What do I do?
John
May 14, 2011 | Polaris 380: Polaris Booster Pump
Polaris Pb4 - 60 Booster Pump Logo
176 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
