Question about Zebra ZM400 Thermal Label Printer - ZM400-3001-3000T
Print faded on my zebra printer i have installed new print head and roller , all settings are on max for print darkness but is still printing the entire label faded , please help .
SOURCE: Problem printing on Glossy Label [butterfly label] using Zebra TLP 2844 EPL
You must make sure that the ribbon is compatible with the label you are attempting to print on. It must be a permanent resin. We use the AXR7+ material. Try to avoid using such a high printer head temperature as this will reduce the life of the head.
Posted on Jan 21, 2008
jc2it
  • 58 Answers
SOURCE: zebra 105se printer is printing out of the label on the wright side
It would be best if we had more information, or a picture.
For instance if you told me as the label is printing it does not print on the label, and it appears shifted to the right or front, then I would say, you need to re-calibrate the printer for that label.
If you were saying that the printer is printing on the right side of the label as you face the printer and watch the label exit the printer, then I would say, that the label size in the software is wrong, or the transfer ribbon is loaded incorrectly, too far to the right as you face the label exit path, OR the labels are loaded too far to the left as you face the label exit path.
Here is a link to a manual that may help as well.
Posted on Feb 02, 2008
thesuperdude
  • 97 Answers
SOURCE: printer set up but will not print.
Are you using thermal paer or thermal transfer?
Get one label and place a cigarrette lighter next to it for less than one second. If the label turns dark like supermarket receipts, then is thermal paper. (In this case let me know and we will try to diagnose what the problem is)
If the label does not turn dark at all, then you have the wrong type of labels for this printer unless you have the option to use ribbon.
Posted on Mar 26, 2009
  • 62 Answers
SOURCE: Zebra Z4MPlus not printing dark enough
Problem is the temperature, printhead not hot enough. Download the zebra setup utility, you can use this utility to configure the print quality.
Heat setting can be found in the printer driver and easily adjusted there.
Posted on Nov 17, 2009
  • 1121 Answers
SOURCE: My Zebra Z4Mplus printer is skipping labels when I print
check the label margins, and label dimensions, and spacing , normaly is these problem, or is a printer driver problem, try reinstall driver
Posted on Jan 13, 2010
My TLP 2824 has been installed on another computer with the same operating system ie Win 98. Now when I print a label it prints the first line fine then the subsequent lines fade to becoming unreadable
If it's setting issue, you need to turn up the darkness to make it darker prints on lines.
It sounds like settings issue, remember darkness & speed combination is important.
Oct 14, 2013 | Zebra TLP 2824 Printer
Zebra 110Xi III Plus Printing Bar Codes too dark
if it is the least setting for print head then you may need to dry ribbon by putting in sunshine for few hours
Apr 23, 2013 | Zebra 110Xi III Plus Thermal Printer
Labels are "faded" looking when printed. looks like you need to change ink but obviously there is no ink
Is this unit in thermal transfer or thermal direct mode? Depending upon the usage of this machine, perhaps a new thermal head is required. If thermal direct, try a different roll of labels, it is possible to get a bad batch. In thermal transfer mode, the tape could be bad as well. Try a new one to test.
Let us know what you find.
Thanks,
Dan
May 12, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Zebra lp 2824 faded printing
Many factors affect print quality: Heat settings, speed setting and label face stock quality and type are a great place to start. How old is your printer? How many labels have been printed through it (there is an odometer that tells your this on the config label). Is the printhead dirty? Use > 90% isopropyl alcohol on a cotton ball or microfiber cloth to gently clean the printhead.
I would start by checking the heat and speed settings in the driver - crank up the darkness and crank down the speed a notch or two at a time until you get the print quality that you are looking for. If all of this fails, you may need a new printhead (not too easy to replace on this model). Printheads are made up of an array of resistors. These can loose their electrical resistance over time and require more energy (controlled by the darkness setting) to get the same results as a new printer. Printheads, like labels and car tires are considered a consumable commodity.
Jan 14, 2010 | Zebra Eltron LP 2824 Thermal Printer
Faded Printing
You can also go into your printing preferences and change the intensity or darkness of the printing. This fixed the problem for us. Good luck!
Dec 16, 2009 | Zebra LP 2844 Thermal Printer
Can't save the printer darkness in the printer
go to printer driver properties.. 1.click printing preferences set it to USE PRINTER CONFIGURATION 2.go to advance click Printing Defaults set it to USE PRINTER CONFIGURATION
you must set this two configuration note: fresh installed driver defaulth to software control
Oct 14, 2008 | Zebra Z4Mplus Label Printer
Zebra LP 2844 fuzzy print
1. Clean the print head with cleaning pen.
2. Adjust print speed/darkness in software.
3. Check the media and verify that print surface is facing up.
4. Check that correct thermal media is in use.
Apr 23, 2008 | Zebra LP 2844 Thermal Printer
Dec 26, 2007 | Zebra TLP 2844-Z Thermal Label Printer
Poor Quality (black line)
Check the temperature settings. If all of the text and barcode is clear and not fuzzy, check the platten roller for low areas, cuts, or other deformity.
Dec 12, 2007 | Zebra 170XiIIIPlus Thermal Label Printer
Zebra ZM400 Thermal Label Printer - ZM400-3001-3000T Logo
18 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
