Hotpoint aquarius WDL540 washing machine won't pump out the water during cycle...all lights flashing...
tborn6
  • 700 Answers
SOURCE: WMA54 Hotpoint Aquarius drum does not turn during wash or spin
sound like the contact points on the timer are probebly dirty or arched to where they are not making good contact. you can take and clean them with a piece of emery cloth if you are mechanically inclined and can take the timer apart. Also there's a set of contacts down by the motor ti check too.
Good Luck,
Posted on Jan 06, 2009
localwonder
  • 6784 Answers
SOURCE: lights flashing / flickering on face on controls-machine not work
This is normally a signal that is for a control fault. you will need to pull the power and shut this unit down for 5 minute.. if the unit continues to flash after this reset, you will need to replace the control board/timer in this case. it has failed.
Posted on May 22, 2009
GodBlessU
  • 3513 Answers
SOURCE: Hi, there i a knocking noise during the spin cycle
I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. Also another way to check is to move the inner durm up and down to see if there is any play in it
Check for bearing failure by seeing if there is any vertical movement between the moving stainless drum and the fixed outer drum. There should be no vertical movement between them - if there is the bearings have failed and will soon collapse. Check for rusty spray around where the pulley shaft enters the outer drum - early indication of seal and bearing failure. Another method of checking is to remove the drive belt and rotate the drum by hand - there should be no noise, roughness or resistance to rotation. Changing bearings is an involved job, only attempt if you are mechanically competent.
As for changing the bearings.
Power off, remove covers. Disconnect drive belt, remove drive pulley. Remove heater, thermostat and pressure switch. Check if drum splits at front, rear or the middle. If the drum is a plastic welded one- ie one which doesn't split, then its game over. If it splits at front or middle, drum will prob. need removal from machine. This involves dismantling the suspension and damping system and removal of door seal and concrete weights. Undo the drum fixing system - either a clamping ring or a series of peripheral bolts and split the drum. If the drum splits at the rear, removal from machine probably not required. Remove the clamping system and pull off the rear plate. Seal and bearings will come away with the plate. Seal needs to be dug out with a suitable lever and the old bearings hammered out with a punch from opposing sides of the backplate. Refitting is, as they say, a reversal of the above process.
However Unplug the appliance and take the top off.
Check the weight on the top to see if it's slack.
Open the door and with your palm upward put it on the edge of the drum.
Lift it until the weight comes on. Is there a lot of movement?
Press down on the inner drum and swing it side to side, does it sound/feel rough?
Finally, tip the machine rearward a little and from underneath check to see if the front weight is loose.
If all of the above are ok then it's likely the drum support spider has broken one of it's legs and the inner drum is knocking as it spins.
To sort this out you would need to strip the appliance down and remove the inner drum to try and change the bearings and the inner drum support.
This is a major strip down of the appliance.
Hope this helps
Thanks for contacting fixya.com
Posted on Nov 12, 2009
barkencoa
  • 3463 Answers
SOURCE: my hotpoint aquarius washing machine wont pump out
HI.
You need to check the pump filter.
Remove lower rear panel of washer.
Remove large black hose fastehed to bottom of drum
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Check drain out let hose is not blocked.
Please rate my solution/.
Thankyou.
Posted on Jan 28, 2010
SOURCE: control panel lights ALL flashing on hotpoint aquarius washing ma
my lights are all flashing on my control panel, its takes water in then pumps out straighaway doesnt wash or spin i have changed the brushes so i know it isnt that please help it only about 3 years old
Posted on Feb 16, 2010
How do I find what the problem is with my hotpoint aquarius wdl540
DOES IT AGITATE? CHECK THE DOOR SWITCH, THE MOTOR COUPLER, THE BELT, THE CLUTCH WHICH EVER IS APPLICABLE? DIRECT OR BELT DRIVEN?
Aug 31, 2014 | Hotpoint Washing Machines
Hotpoint Aquarius wdl540 wont pump out water
!. Check for water drips/leaks onto the wiring after removing the rear&or the side covers.This may sometimes not be visible to the naked eye -- a torch.
2.Check for loose connections to the pump.If all o k then remove the & test by connecting to the Mains.If it runs switch it off -- do not run it dry for more than a few seconds.If o k then it can only be the main board or timer.
Jan 26, 2014 | Washing Machines
Hotpoint aquarius WF541 won't finish a cycle
What is the model number? Look inside the door area.
Oct 18, 2012 | Hotpoint Aquarius WMA42 Front Load Washer
Instruction manual for hotpoint aquarius WDL540 7kg Washer/dryer
My washing machine's indicator flashing after 5 minutes,what should i do?
May 13, 2012 | Washing Machines
Wdl540 clothes go through drying cycle but come
If there is no heat at all then the heater or the temp sensor or the thermal fuses are defective and need replacing.
Also check that the lint filter is clear of debris and lint. Rinse it if necessary in some mild washing up liquid in warm water and dry thoroughly. Check that the air outlet hose is clear if you have one fitted. Check that the condenser is empty of water and the case is free from dust and lint. Vacuum / brush or wash the outside of the collector in washing up liquid and warm water and dry.
Nov 06, 2009 | Hotpoint Aquarius WD640 Front Load...
I have a hotpoint aquarius WF250 1500 spin. The
I've just had this exact same problem. Can you tell me if you have had any success with fixing it please?
Thanks!
Dan
Sep 17, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wma34 stops and prewash light flashes
I would check the water pump for a blockage a button or other debris may be lodged in there preventing it for operating properly eric
Jan 15, 2018 | Hotpoint Aquarius WMA42 Front Load Washer
My hotpoint aquarius wd440 washing machine - flashing lights ?
I have a fairly new Hotpoint Aquarius machine (out of guarantee).
When it is switched on, all of the red lights flash and it will not operate.
Can you help please ??
Oct 18, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WMA56 wont drain properly water leaking onto floor
pump is working water is only a trickle coming out so wont final spin
Nov 07, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Washing Machines Logo
218 people viewed this question
Top Washing Machines Experts
