Question about Windchaser PAC8 Air Conditioner
Manual find hose #
1992 Kawasaki ZZR 600 fuel valve hose diagram
Hi, Lee for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1992 Kawasaki ZZR 600 fuel valve hose diagram Google Search
How are the fuel tank hoses arranged
Kawasaki ZZR600 ZZ R600 1990 2000 Service Repair Manual Download Manuals... $10
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
Jun 19, 2017 | 1992 kawasaki ZZR 600
When i try to use it on manual the green light will flash then turn off, but works on automatic
The hose button will only work if the hose is unplugged from the side. Sounds like it thinks the hose is still in it. There is a small magnet in the end of the hose. Over time they rust and come apart. Bits may be stuck to sensor where hose clicks in on the side.
May 22, 2012 | Bissell SpotBot Robotic Wet/Dry Vacuum
HLP021-wm fills with water, goes thru wash cycle, then rinse and spin lights keep blinking and the water stays in the tub. It stayed that way for several hours until I unplugged it,tipped it over and...
Hi.
A common reason for long or no drain for blockage at the drain hose and check setting of the drain hose. If the hose is blocked or incorrectly set drain may not complete. See page ten of user manual about hose setting. Here the user manual.
If the hose is OK the problem is either water level switch or blockage at drain pump.Water level switch is located in control panel assembly. the part is a plastic disk connected to a long thin rubber hose that goes inside the tub. If the hose is dirty the switch will not detect drain is complete and drain will not finish. The pump is located at the bottom of the appliance. The hose connected to the pump may be blocked. In some case the pump itself may be defective.In that case the pump must be replaced. The parts for this unit are not expensive.
Parts can be ordered from Haier. Here the US website: Welcome to Haier America
Parts for this washer are also available here
Haier also makes available a service manual. Exploded view is not included.
The exploded view and part list are shown in the manual available here (Please download the manual and check pages 16-17 - a free subscription is required).
Regards.
Ginko.
Nov 21, 2011 | Haier Washing Machines
Where does the grey hose connect? I'm not sure if
First we need to know what diameter said Grey Hose is? I assume you are speaking of a Washing Machine?? If so, typically they are equipped with 3 hoses as follows: One for Hot Water Supply and a Matching hose for Cold Water Supply. Both of these hoses are equipped with 3/4 Inch Female Housse Thread connectors identical to a Garden Hose. So that delegates the Third Hose to DRAIN. It is LARGER and usually is attached inside the Washing Machine to the Water Pump and passes through the rear cover and ultimately must be formed into a "U" bend and inserted into the Drain. It is necessary to secure this hose to the Drain and Supply device so that it cannot blow out of the Drain while the Washing Machine is Pumping Out. All Washing Machines come with User Manuals and Installation Instruction Sheets. Like Automobile Owners Manuals, they should be read cover to cover and stored for future reference. You can find most Washer and Dryer Manuals online. Use Google Search to find them.
Nov 18, 2011 | Health & Beauty
How do I get the suction over to the hand held hose?
Once you detach the hose from the power head, the suction is at the end of the hose.
User's manual:
http://www.eureka.com/service/manuals/80238.pdf
Dec 24, 2010 | Eureka Capture Upright Vacuum Vacuum
Bosch SRS4302GB Replacement Inlet hose - which type?
it should have and is delivered with the narrow bore high pressure hose
if your water flow rate is high more than 20 ltrs p min you could get away with a standard low preessure hose
you can download the instruction manual from the bosch web site or from the bsh home appliances web site
good luck
Mar 06, 2009 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
My hoover5134-900 there is no suction from the hose when I attach
Here is a link to an online manual at fixya. You do have to attach the hose and the diagram in the top right corner tells you how.
http://www.fixya.com/support/p40671-hoover_u5134_900_bagged_upright_vacuum/manual-4450/page-8
Dec 14, 2008 | Hoover U5134-900 Bagged Upright Vacuum
Tear in Eureka Upright "The Boss" 4870
http://geeksquad.fixya.com/ThreadView.aspx?prdid=414813&thid=652524
Posted by kdunnett on Jun 07, 2008
I have a tear in the hose of an upright Eureka "The Boss" 4870 vacuum. I cannot find how to release the parts I need to get the hose out and put in a new hose (which I already have) I've searched the Eureka site and the owner's manual - nothing about how to replace the hose itself. Thanks in advance.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Eureka 431A Optima Bagless Upright Vacuum. In answer to your question, the owner’s manual may or may not give an example to install the hose only, but on most vacuums the hose sometimes will screw in to the hose cuff on both ends unless if it is a hose assm then it will then twist and turn. Check with the
Eureka website and have them send out a schematic and owner’s manual for you so that you can install your hose properly. Sometimes you have to place hose glue on the end of each side in order for the hose to screw in properly. the website address will be listed below and they certainly should supply you with the owners’ manual and maybe a schematic of the parts breakdown that also may help. If not; check with your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept for U.S.
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 07, 2008 | Eureka 431A Optima Bagless Upright Vacuum
Windchaser PAC8 Air Conditioner Logo
73 people viewed this question
Top Windchaser Heating & Cooling Experts
Jay Finke
Jay Finke
Jake's Auto Care...
Steve
Are you a Windchaser Heating and Cooling Expert? Answer questions, earn points and help others
