Question about Hotpoint RGB745 Gas Kitchen Range
Fumes My new range is wonderful, however, after careful installation,the oven shoots very high flames and puts off an awful eye burning
  • kushrsk Jan 08, 2008
    burners fine, but flame in stove too high and makes eye-burning fumes ...help!
The adjusting nut needs to be tightened; it works like a carburator jet by tightening to a snall needle. This nut is just below the "window" that adjusts for the amount of air
Posted on Jan 09, 2008
  • 63 Answers
Are you using propane or natural gas you may need to change the setting for what one your using in the back it will have a bag filled with new orifices you may need to change them out plus on the regalator you can switch to natural / propane
Posted on Aug 29, 2007
  • Ronald  Rousseau
    Ronald Rousseau Jun 10, 2008
    I was right I have no ieda why you would give me a bad rating
SOURCE:
My new gas range smells like fumes preheating and turns pans in oven black?
That means the gas to air ratio is wrong by the sounds of it. Are the flames blue or white?
The other possibility is oil or grease used in storage which is burning off.
If it continues, you need the gas fitter back. Also make sure you have a working Carbon Monoxide detector on each level of your dwelling, and especially on landings where you sleep.
Aug 26, 2018 | Kitchen Ranges
Why does my fan oven smell of fumes when switched on
could be a couple of reasons. if it is a new oven, it will smell for the first few times, they all do. If you have cleaned the oven recently it could be the residue burning off.
Oct 17, 2014 | Microwave Ovens
The pilot went out in the oven how do i light it manually
use a wooden tapper , burning and put flame by the pilot light in oven should work. If not you could always light oven this way but you must take great care if you do
Dec 19, 2012 | Frigidare FEF366DB Electric Range
When i increase the temperature control the oven soots excessive
Check your oven for flame color; what you are describing could be deadly. It is possible that you have an air vent clogged or blocked causing the flame to burn yellow indicating incomplete combustion and possible source of carbon monoxide. This is very dangerous and I would strongly recommend you purchase a carbon monoxide detector. We have one on the main floor and one in our basement.
A defective gas floor furnace in a home in a neighboring town 2 days ago put three children and two adults to sleep during the day and a 64 year-old man died of the fumes. The others are recovering but are all hospitalized. The family moved to Clay, WV from New Mexico only a week ago.
Dec 28, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Flames in oven are WAY too high! Having trouble lowering them.
Hi! melisrus
If you are using LP, even if you change the regulator settings from Natural Gas to LP Gas, the orifices all need to be changed. The Orifices should have come with the new unit, if not contact Hotpoint.
www.hotpoint.com
Make sure you order the instruruction manual and this is an Oven with Range Top, you will need orifices for all the burners on the range top.
InMrFixIt
Nov 18, 2008 | Kitchen Ranges
I have recently had a corgi registered plumber remove a gas fire with back boiler from my living room and he blanked off the supply as we no longer require a fire in its place. we also have installed a new...
IMMEDIATELY ISOLATE THE OVEN AND DO NOT USE. GET PLUMBER BACK - HE SHOULD BE ABLE TO CHECK THE APPLIANCE ITSELF FOR LEAKS BUT THE MOST LIKELY CAUSE IS THE JUNCTION OF THE CONNECTION HOSE WITH THE HOB
Sep 09, 2008 | Kitchen Ranges
Gas Oven, lights and terrable smell, and flame shoot out
yea sounds like you have a stive set for natural gas hooked up to propane gasm you need to convert that thing instructions are simple to follow in installation manual, or if you paid someone for installation id get them back
Feb 28, 2008 | Kitchen Ranges
Oven flame is too high
the flame should be app 2" from each side of the burner. be very careful with lp conversions.
Feb 09, 2008 | Frigidaire GLGF382D Gas Kitchen Range
High flames
you need to convert your oven!!!! sounds like you have LP or tank gas, nad your oven is set for naturla gas. theres instructions on how to convert in installation guide, not hard !!!!!
Jan 16, 2008 | Frigidaire FEF376 Electric Kitchen Range
Hotpoint RGB745 Gas Kitchen Range Logo
249 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Archie Ferrarini
Archie Ferrarini
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
