Question about Refrigerators
GD27DF how old is this refridgerator?
Newly installed ice maker two days old, not dropping ice, frididaire refridgerator
Ice maker under warranty have them look at it will not cost you anything.
Aug 29, 2014 | Kitchen Appliances - Others
Chattering of new refridgerator
new fridge should have warranty.place of purchase where you bought refridgerator should replace it with another one.
Apr 14, 2013 | Cars & Trucks
Ac has been recharged and the compressor is working fine but it still isn't blowing cold air. i replaced the discharge line because the old one had little pin holes in it and it still doesn't work.
If you didn't do a recovery process, and recover the oil, and refridgerant, then possibly you have too much oil in the system. The kits that you buy at local parts stores contain oil mixed with the refridgerant. your gauge may read full, but the system may not have enough refridgerant. This is just a suggestion, ,hope this helps.
Aug 02, 2010 | 1999 Dodge Intrepid
Our refridgerator is old
in the toe kick
or in the upper right corner of the fridge
Oct 03, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Refridgerator door sags
Its a two person job. One person has to looses up the two hidges holding the door just slightly while the other person holds the door in place. Once in place tighten the screw/bolts for the hidges back up and check. If not aligned, redo it again until it is aligned and seals properly..
Good Luck!
Sep 15, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Gfi outlet keeps tripping
try running an extension cord to the old outlet and see if the fridge works then you'll know if it's the fridge or outlet. good luck
Dec 03, 2008 | Whirlpool ED2FHEXN Side by Side...
Refridgerator
Does freezer back wall have ice build up ? if so a defective heater is the most likely problem
Oct 15, 2008 | GE GSS25JEMWW Side by Side
REfridgerator Failure
Refridgerator is 5 years old. Simply went out of cooling and freezing. Still makes operating sounds and lights work but losing our freezer full of food is disturbing on a refer only 5 years old.What could be wrong?
Mar 17, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
