Question about Neff K3965XO Side by Side Refrigerator
What is the likely cause to make the fridge freezer trip the electrics
Hi my samsung fridge/freezer suddenly started to trip my electricity,I changed the plug but still is tripping the electricity,also checked the socket,definitly the fridge
First you must isolate the problem. remove the rear service cover(unit unplugged) disconnect the wire plug to the compressor. replug the fridge. If the circuit doesn't trip ,then the compressor or relay is defective.
May 04, 2018 | Samsung Refrigerators
Our Westinghouse RS662V fridge is tripping the power. Has done it twice in the past 2 months. Any suggestions?
This solution is one possible answer if it applies to you. My fridge did the same and i thought the fridge was dead. The fridges freezer compartment's door was being left open and the freezer would thaw out and produce lots of water which would accumulate in the rear in a container which overflowed causing the fridge to trip the power. Closing the door and drying the rear container solved the problem. There are other causes too but if this applies to you it is worth giving it a try. Good Luck!
Jul 20, 2014 | Westinghouse WHITE Fridge Freezer Bottom...
Samsung fridge not working freezer is?
sounds like you removed the defrost tstat.you need to replace it.if your evap coil ices up it will block the cold air flow to the frige section.replace your bad part so your defrost system willwork
Nov 27, 2012 | Samsung Refrigerators
Hotpoint FFM71 fridge freezer tripping
Replace the breaker. It may be out of tolerance.
Nov 26, 2012 | Hotpoint Refrigerators
My Hoover Nextra fridge freezer is 9 years old in perfect condition. Fridge has stopped cooling but freezer is working ok. I have turned up temp control to super, motor is warm but silent. What could have...
Hi, I have a Hoover Nextra Fridge Freezer and last night it tripped all my electric. When I plugged it back in, it sounds like it is starting, but then after a couple of seconds clicks off again. Any ideas?
Dec 26, 2010 | Refrigerators
Fridge freezer shorting out electrics
The cause of this situation could simply be an overloaded circuit. Homes are built with dedicated circuit for fridge only now because of this. If you notice power outage in other rooms or other appliances in kitchen then the circuit affected,I.E. other outlets affected need the load lightened. If it is a dedicated circuit then could be faulty breaker or possibly altered wiring could be cause.These have to be ruled out before you will know for sure. If it isn,t dedicated outlet for fridge only, just plugging in a light could overload loaded circuit.
Apr 21, 2009 | Refrigerators
Fridge keeps tripping electricity
I assume by "earth leakage" you mean it is on a GFI circuit? Some older GFI outlets are sensitive to and do not work well with motors or other inductive loads like your refridgerator compressor. As for the compressor feeling hot, this is usually normal.
If this is a GFI outlet, try replacing it with new unit. If it is a GFI breaker, try replacing that.
Dec 27, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Whirlpool fridge freezer tripping the electric
PLEASE CALL PENINSULA ENGINEERING & SERVICES
9224699796 , BASED IN MUMBAI 24 HRS SERVICES 100 % JOB SATISFACTORY
Sep 03, 2008 | Freezers
Zanussi frost free fridge freezer
if problem happens every fewhours it is possibly the defrost element
Mar 20, 2007 | Zanussi ZEBF277W Bottom Freezer...
Neff K3965XO Side by Side Refrigerator Logo
37 people viewed this question
Top Neff Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Neff Refrigerator Expert? Answer questions, earn points and help others
