Question about Boating
Where is the thermostat on a 1998 9.9 Gamefisher Outboard
2 Suggested Answers
  • 65 Answers
SOURCE: where is the thermostat and waterpump located on a sears 9.9hp gamefisher outboard motor
water pump is in the lower end of out drive and there is no t-stat
Posted on May 08, 2009
Serial where is the serial number for Gamefisher outboard motor I cannot find it for Gamefisher outboard motor where is it
Hello, Ron -
According to information in an owner's manual for a Gamefisher model # 225.581508 15" Transom and a model # 225.581498 20" Transom . . .
(Quote)
The model and serial numbers will be found on a decal attached to the port stern bracket.
(End quote)
Best wishes.
May 07, 2018 | Boating
Install ignition points on 9.9 gamefisher
remove flywheel remove old points and install new set. set gap ,replace flywheel,
Oct 21, 2014 | Light Outboard Motor Boat Bass Fishing...
How to disconnect gear shift lever on a 1996 gamefisher 15hp outboard
usually where the lower unit splits midway if you look inside you will see a couple screws or bolts remove one then it can be pulled apart.
Oct 06, 2014 | Boating
My 1982 9.9 gamefisher outboard will run but dies when put into gear
have you tried increasing the idle speed to see if that helps.
Jul 28, 2014 | Boating
I have an old 15hp gamefisher that's not getting fire
Have u got spark ? Put new fuel in flushed carb and fuel lines ?
Mar 18, 2014 | Light Outboard Motor Boat Bass Fishing...
Does my 1997 gamefisher 9.9 require a thermostat ?
You have this in the wrong section, this is car and truck problems.
Jun 14, 2012 | Cars & Trucks
I have a 1988 gamefisher outboard motor I need to put a water pump on other than taking the bolts out at the bottom is there any thing else that need to be disconnected before pulling the lower unit thanks...
yes!! there will be a cover in the back of the upper part of unit. you will need to remove this and disconnect the shifter from the lower end.
Jun 20, 2009 | Boating
Where is the thermostat and waterpump located on a sears 9.9hp gamefisher outboard motor
May 05, 2009 | Boating
Water circulation (coolant) thru outboard motor
Common problem is the thermostats staying closed. If i remember correctly they should be replaced every year. Water should be spitting out on the upper part of the shaft. Good luck on that fishin'
Apr 25, 2009 | Boating
Boating Logo
129 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
