Question about EPoX EP-3PTA Motherboard
Pyramid 9 pcb ba41 00167a - EPoX EP-3PTA Motherboard
2 Suggested Answers
  • 13 Answers
SOURCE: where can i get pyramid-9 PCB No BA41-00167A
Hello, i was made a search in google, i guess you must look it too, and a don't get nothing, but, I think i've a solution for you, according my own experience, i've installed 2 kinds of different MB, and, althoug there are different brands, the connection pins are the same, ie, the front panel connector that connect HDD Led, Power Led, Reset and Power, is a 9 pin conectors (really have 10, but 1 pin is cut for reference) and commonly is called PANEL 1
Then, i guide you
2 8
. . . . this will be 2,4,6 and 8 pins (from left to right)
. . . . . this will be 1,3,5,7 and 9 pins
1 9
Power Led + in pin 2
Power Led - in pin 4
Power Button # or + in pin 6 (It's no critic the orientation, it have no polarity, is a push buttom)
Power Button GND or - in pin 8
HDD Led + in pin 1
HDD Led - in pin 3
GND from Reset Buttom in pin 5
# from Reset Buttom in pin 7
THE PIN 9 has no connection
Source: My own experience, and check this instalation manual, at 21st Page
http://download.asrock.com/manual/Wolfdale1333-D667%20R2.0.pdf
Posted on Jan 07, 2011
Testimonial: "thanks for sharing such a valuable information. i will check out right awway"
Is Plexus a pyramid scheme?
it is, except they prefer the term 'Multi-Level Marketing'.
About 38,900 results (0.45 seconds) Search Results
Is Plexus a Scam? - Lazy Man and Money
www.lazymanandmoney.com/plexus-scam/ Jun 8, 2016 - That's three separate places in the same document that the FTC makes it clear... the majority of the money can't be made from a downline or it is an ******* pyramid scheme... not a legitimate MLM. ... Plexus appears giving an example of someone running a pyramid scheme according to the FTC's guidelines.
The Plexus Scam From The Inside Out - Ethan Vanderbuilt
ethanvanderbuilt.com/2015/10/15/the-plexus-scam-from-the-inside-out/ Oct 15, 2015 - This is one distributors experience with the Plexus scam. ... Plexus Scam Presentation Video. Then she sent me ... Oh wait, isn't that a Pyramid?
Is Plexus a pyramid scheme? - Quora
https://www.quora.com/Is-Plexus-a-pyramid-scheme
The network marketing industry, including Plexus Worldwide, is monitored by the FTC (Federal Trade Commission). A pyramid scheme is ******* and would not comply with FTC standards. ... Plexus Ambassadors typically do not carry inventory for resale.
The Pink Drink Scam: Is Plexus a pyramid scheme or not?
thepinkdrinkscam.blogspot.com/p/is-plexus-pyramid-scheme-or-not.html pyramid scheme, tarl robinson, plexus worldwide, mlm scam, weight loss, pain relief, diet.
Plexus Slim Review - It Does NOT Work. Period. - Plexus Point
www.plexuspoint.com/plexus-slim-review/ These incorporate Plexus slim scam/accelerator Combo, Plexus Bio Cleanse, .... after learning this is one of those pyramid schemes, I have stopped it altogether.
Is Plexus pyramid scheme Google Search
Apr 03, 2017 | Pyramid Car Audio & Video
How do i adjust my hybrid A2400 amp from 8 ohm to 4 ohm step by step
FIRST TAKE A LOOK AT THE PCB YOU SHOULD FIND A PHASE SHIFTER OR MAYBE TWO ON OF THEM SHOULD SAY OHM LOAD
AND THE ATHER ONE STEREO OR BTL
FIND THE ONE WITH THE OHM LOAD AND TURN IT COUNTER CLOCKWISE TO FIND 4 OHMS
Jun 18, 2014 | Pyramid PR530A Amplifier
What is the pyramid total surface formula
Assuming the base of the pyramid is square ... of length B and the distance from the center of the base of the pyramid to the top of the pyramid is H
Surface area is: 2 x H x B
plus B-square (if you include the base of the pyramid)
May 23, 2014 | Encore Math Advantage Algebra II and...
Volume of triangular pyramid
Here is to get you started. To increase the size of the image do a CTRL Plus (+) in your browser.
You need to calculate the slant height of the pyramid for the formula of the lateral area. You should find a value of (1/2)*SQRT(203) or about 7.1239 cm
You need to calculate the altitude (height) of the pyramid from the apex (summit) to the center of the base triangle (center of inscribed circle, barycenter, orthocenter). The hypotenuse of such triangle is the slant height. One leg is the altitude (to be found), the measure of the second leg is (1/3) the altitude of the equilateral triangle that forms the base. You should find (1/3) m MH= (1/3)* (11/2)*SQRT(3)
1. Calculate the area of the base (use a formula for the equilateral triangle or the general formula for a triangle: you have its height MH ).
2. Lateral area = 3 times the area of triangle Triangle ECD (in yellow above).
3. Total area = area of base + lateral area.
4. Volume= (1/3)(Area of base)* (height of pyramid)
If you can see the details on the screen capture below, fine, Press CTRL + in your browser to increase the size.
Mar 29, 2014 | Office Equipment & Supplies
How do you make a pyramid shape out of paper?
Wrap paper around your "Pyramid Car Amplifier". It will then be the shape of at least your "pyramid"! :)
Dec 11, 2013 | Pyramid Car Audio & Video
Why triangle looks like a pyramid?
A pyramid is made of triangles, and the number of triangles for a particular pyramid base. For a square base pyramid - 4 triangles; pentagonal base - 5 triangles
Sep 26, 2011 | Riverdeep Mighty Math Cosmic Geometry...
Where can i get pyramid-9 PCB No BA41-00167A manual book for setting up power switch,hdd led,reset etc connection setting ???????????
Then, i guide you
2 8
1 9
HDD Led + in pin 1
HDD Led - in pin 3
Jan 07, 2011 | EPoX EP-3PTA Motherboard
How tall is the average pyramid
The first Egyptian pyramid was 204 feet or 62 meters high, built at the direction on Pharoah Djoser in around 2630 B.C. The tallest was the Great Pyramid at Giza, standing at an impressive 481 feet or 147 meters. The smallest was the Pyramid of Pepi II, which stood at a paltry 172 feet or 52 meters. Just based on Egyptian pyramids, the average height is about 316.5 feet or 96.375 meters. Considering the technology of the day, the pyramid builders were quite impressive to say the least. Hope this helped and best wishes.
Sep 24, 2009 | Sport & Outdoor - Others
Can I call by phone..?
You can go directly to pyramid's website at:
http://www.air-purifier-direct.com/air-purifier/brand--pyramid?utm_source=Google_AdWords&utm_medium=Keywords&utm_term=Pyramid+Air+Purifier&utm_campaign=3098370
Aug 03, 2009 | Pyramid TRACS Air Air Purifier
EPoX EP-3PTA Motherboard Logo
18 people viewed this question
Top EPoX Computers & Internet Experts
Steven Burn
Steven Burn
David
David
Are you an EPoX Computer and Internet Expert? Answer questions, earn points and help others
