Question about Miele Novotronic Premier 500 Front Load Washer
Miele Novotronic W1926 Front Load Washer
The washer is not draining, nor spinning: according to the manual the blinking red light indicates that the there is drain blockage. I have cleaned the outlet hose thoroughly as well as the area infornt of the drain pump but still have the same error message (blinking red light) M Ner, Ottawa
  • 105 Answers
SOURCE: Miele W1903 washer skipping steps (not fully draining?)
check the motor brushes could be worn out
Posted on Mar 15, 2008
marked
  • 6487 Answers
SOURCE: How to fix a Miele
Below is how error codes are deciphered by the cycle lights and water level light. This should help diagnose the failure. I recommend to have service technician diagnose and repair your washer.
LONG DRAIN error code will cause the NORMAL, PERM PRESS, and HANDWASH cycle led lights to come on and the WATER LEVEL light to blink.
If the drain time exceeds 6 minutes, the wash cycle will stop. Push the START/OFF button to reset the mode, a drain task is executed and the previously selected cycle resumes.
POTENTIAL CAUSES:
  • Drain pump failure.
  • Drain hose: check for proper connection, kinks or clogs.
  • Pressure switch contact failure.
INCORRECT FILL WATER LEVEL error code will cause the HEAVY DUTY, PERM PRESS, and HANDWASH cycle led lights to come on and the WATER LEVEL light to blink.
Wash cycle stops. Press START/OFF button to enter Standby mode. Execute a Diagnostic Test to drain the water.
POTENTIAL CAUSES:
  • Incorrect electrical connection to pressure switch.
  • Pressure switch is defective.
  • Pressure switch hose is damaged or loose.
  • Air dome is clogged.
  • Drain hose: check for proper height, kinks or clogs.
UNEXPECTED FILL DURING AGITATION OR SOAK error code will cause the HEAVY DUTY, NORMAL, and the HANDWASH cycle lights to to come on and the WATER LEVEL light to blink.
The pressure switch contact selected has opened during agitation task. The wash cycle stops and a Drain task is executed. Once the Drain is complete, the cycle stops.
Push the START/OFF button to reset the operation mode, a Fill task is executed and the previously selected cycle resumes.
POTENTIAL CAUSES:
  • Water or clothes were removed from basket after Fill task was complete.
  • Drain hose is improperly connected.
  • Water leaking from washer tub.
SLOW FILL error code will cause the HEAVY DUTY,NORMAL, and PERM PRESS cycle lights to come on and the WATER LEVEL light to blink.
If the Fill task exceeds 20 minutes, the wash cycle stops. Push the START/OFF button to reset the operation mode, a Fill task is executed according to previous Wash Temp selection and the previously selected cycle resumes.
POTENTIAL CAUSES:
  • Water inlet valve is clogged or damaged.
  • Water pressure is too low.
  • Water hose is closed/clogged.
  • Water supply faucet(s) turned off.
Hope that helps..........
Posted on Jul 12, 2008
  • 4 Answers
SOURCE: Miele W1926 water light flashes
That happened to me too. If the machine is a few years old and the hoses are not kinked it's possible the water inlet valve needs to be replaced. On this machine there is a triple cold water valve and a single hot water valve. Mine needed the triple valve and it is about $300 if I remember. Check to see if it's the cold or hot water valve by looking at the water filling through the soap drawer for cold or hot water cycles. When the valves go bad they run but the output is very low which causes the light to flash because it can't fill to the correct level.
You can get to the valves by taking off the top. If you don't feel comfortable working on your own machine have a professional do it.
Posted on Aug 06, 2009
Mark Harmer
  • 8 Answers
SOURCE: Inlet blockage red light flashing
Try turning the machine on its side, undo the bottom and check that the polystyrene float (attached to a switch) is not somehow jammed. This float cuts off the water if the machine leaks internally, and produces the symptoms you describe. It's a really good machine so don't throw it away!!
If that still doesn't help then it might also be the motor brushes, which produce similar symptoms - if your machine starts to fill but then flashes and just drains again, it's almost certainly the brushes. This might be the case after you check the float problem.
Posted on Sep 21, 2009
  • 82 Answers
SOURCE: water leaking
deafenatly sounds like a blockage or remove soap dispensor and check that there is no damage below it
ie a crack in the plastic allowing water to escape
Posted on Jan 16, 2010
Miele 500 washing machine inlet light comes on and machine wont pump water out or spin
try leaning against door when pressing start . if it runs get the switch replaced
Jan 24, 2016 | Miele Novotronic Premier 500 Front Load...
Miele W1926. The red light over the faucet icon is on at the end of the cycle and the final spin cycle doesn't go on.
Check the screen filter where the cold water line attaches to the machine. Clean both hot and cold.
May 02, 2015 | Miele W1926A Front Load Washer
Miele w1918
Link to user manual. Code listed on page 32 indicates internal error Call service department.
Miele 1918 Operating Instructions Manual Page 32
Aug 03, 2014 | Miele Novotronic W1918A Front Load Washer
How to put top back on miele w1926
1 Remove stacking kit from top of unit.
2 Reatach the two plastic clips to the back of washer.
3 engage the two slots on the washer top into the clips , pull forward drop lid down on top of washer then secure with two screws on either side of lid.
Dec 29, 2013 | Miele W1926A Front Load Washer
Hi there, my Miele W 1903 Novotronic is not draining nor spinning and the drain indicator light is flashing. I have cleaned the filter and the pump seems to be turning freely. Help, please!
Please ensure you have used the proper procedure on page 26 of the manual for cleaning the lint trap.
MANUAL - LINK
Unplug the unit for 20 minutes if turning the Dial back to Start/Finish does not reset the lamp.
Thanks!!
Aug 03, 2011 | Miele W1903A Front Load Washer
Miele W1926 check inlet light flashes at the end of rinse fill. When the fill ends, the light goes off. I cleaned all 4 filters at the intake hoses. The problem still exists. What does it mean?
Hi dear.According to what you're saying,It has faulty water inlet valve.Machine unable to get enough water to do it's cycle in given parameters in time period & starts giving error but before the cycle complates,however it takes enough water,that's why error lights goes off.If you can,you need to change the valve or call service department.I hope that helps.Thanks.
Jul 25, 2010 | Miele Novotronic Premier 500 Front Load...
Apr 25, 2009 | Miele Novotronic W1918A Front Load Washer
How to fix a Miele W1213 Touchtronics washer when the intake and drain light is blinking? power for drain motor is only 20V drain motor not working,but I am tested with 220V end is o.k.
Unfortunately you need a Service Rep out there to check the electronics - how old is the machine? - Warranty? the drain pump should be 220 or 120 depending on the model.
Jul 06, 2008 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic Premier 500 Front Load Washer Logo
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
