Question about Canon Rebel Cameras
Eos rebel xti not recognized windows
Me aparece el error 99, sigo instrucciones y se repite
  • 62 Answers
SOURCE: EOS Utility does not recoganize Canon Rebel Xti
I believe there are 2 modes of usb transfer that you can pick in the camera. They are set somewhere in the menu in the options. If you go through the menus thoroughly you'll find it. One option is for connecting the camera directly to a printer and the other is for computer transfer (there might also be an Auto setting but I don't remember for sure). Make sure that setting is set for computer transfer. If that doesn't fix your problem, re-install or update EOS Utility / ZoomBrowser.
Posted on Aug 28, 2008
marked
  • 6487 Answers
SOURCE: Canon EOS Digital Rebel XTI
Normally it can be an assortment of things:
Dirty contacts between lens and mount causing a glitch in the communication.
Use of outdated or obsolete chipsets on certain lenses
Jam in the motor
I/O error on the cf card
Mechanical failure
Most of the time its a bad contact with the lens and the mount. Try cleaning it with a q-tip to wipe residue off the metal contacts.
Hope that helps.........
Posted on Aug 31, 2008
cpt100
  • 154 Answers
SOURCE: canon rebel xti digital camera
Error 99 is shutter error. Best solution is to replace it ASAP if the camera is still under warranty. We go through many replacement of shutters for many Digital Rebel series. There is no simple answer without replacing it to good shutter part. The problem will keep coming back. Out of warranty repair charges may run from $150 to $250 depending repair facility. -James. For further assistance by email, go to www.camerarepair.com
Posted on Mar 27, 2009
  • 11967 Answers
SOURCE: my canon eos rebel xti keeps showing error code 99
To isolate the cause of the issue, we suggest that you do the
following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
Does the "ERR 99" message appear? If it does, then the camera should
be serviced. If it does not, then please proceed to the next set of
steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99" message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99" message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the
camera should be serviced.
Posted on Sep 22, 2009
  • 11967 Answers
SOURCE: Canon Rebel XTi not recognized when plugged into usb
Vista is your problem. Solution...buy an inexpensive card reader to download your pics to a folder you create on your desktop. From there, you can send the pics to your photo editing software.
Posted on Oct 23, 2009
Al encender la maquina aparece la leyenda de que "windows no se ha iniciado correctamente " y al seleccionar alguna opcion modo seguro , modo seguro con red , se apaga la maquina y vuelve ...
repare instalaci?n:
1. Cuando la Prensa cualquier llave inicialice del mensaje de CD es demostrado en su pantalla, aprieta una llave para comenzar su ordenador del Windows XP CD.
2. Prensa ENTRA cuando ve el mensaje Al arreglo Windows XP ahora, y entonces prensa ENTRA demostrado en el bienvenido a pantalla de Arreglo.
3. No escoja la opci?n para apretar R para utilizar la Consola de Recuperaci?n.
4. En el Windows XP que Licencia Acuerdo, prensa F8 para aceptar el acuerdo de la licencia.
5. As?gurese de que su instalaci?n actual de Windows XP es seleccionada en la caja, y entonces aprieta R para reparar Windows XP.
6. Siga las instrucciones en la pantalla para completar Arreglo.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 20, 2011 | Computers & Internet
1000d error code 1
user manual say its a communication problem between the camera and lens. The suggested solution is to clean the contacts.
Jan 18, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
It says error 99 its a rebel xti
problem in lens repair it a F PCB IS BROKEN
Nov 02, 2009 | Canon EOS 400D / Rebel XTi Digital Camera...
Oct 23, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Error 99! Wont' take picture, the message states
Go to the www.canon.com website and find out what Error 99 means. ted10
Apr 18, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Error 99 comes while taking photographs
This could well be a serious issue, which you'd need to send to your manufacturer to fix, however there are a few things you could try first:
Take your lens off and with a clean rubber (like on the end of a pencil), clean the contacts of both the camera and the lens.
Apr 11, 2009 | Canon EOS 400D / Rebel XTi Digital Camera...
I have a Cannon Rebel XTI and i keep getting err 99
Make sure your firmware is up to date. The current version is 1.09 which did address a problem with live view that could cause error 99.
Here's the link http://web.canon.jp/imaging/eosd/firm-e/eosdigital4/firmware.html
Also try removing your lens and putting it back on. Sometimes it is a bad connections between the body and lens that can cause this error.
Jan 27, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
ERROR 99
Contact
http://www.canon.co.uk/For_Home/Warranty_Registration/index.asp
Aug 28, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Error 99
WHAT IS THE SOLUION OF ERROR 99
Aug 05, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Cameras Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
