Question about StorCase 9 Bays Data Silo DS550 Storage Cabinet
Flashing "F" on front of drive slot
There is a flashing "F" on the front of one of the drive slots. Yes, normally, I would think that this would signify a failed drive. But, I just replaced this drive. Before I replaced the drive there was an audible alarm and our adaptec storage software indicating that it was a failed drive. This time there is no audible alarm and the adaptec storage software gives no indication that the drive has failed. What does the flashing "F" on the front of the drive slot mean? Thanks!
Yup, it's the right model number. I got a hold of a support person at storcase. They said the flashing "F" usually indicates a bad fan. They also said that the flashing "F" could indicate a bad drive but since there are no audible alarms, my Adaptec Storage Manager did not detec a bad drive, and I just replaced the drive it is unlikely it is another bad drive. I just have to pull the drive out to give them the model # of the drive carrier and they said they would know for sure. Thanks!
Posted on Aug 30, 2007
    Problem Solver:
  • 11 Answers
The front panel display contains seven (7) lights which provide the following information: ? Power-On - Steady green glow indicates that power is being supplied to the Data Silo chassis. ? Temperature Warning - Flashing red indicates that internal operating temperature has reached 43? C (109° F). ? Blower 1 or 2 Failure - Flashing red indicates a blower has failed. ? Power Supply 2 Failure - Flashing red indicates second power supply has failed. ? Power Supply 1 Failure - Flashing red indicates first power supply has failed. ? Mute - When switch is depressed, a steady yellow glow indicates the audible warning sounds have been disabled. Depress switch again to enable sounds. ? Reset - Depress switch to reset chassis and clear any error conditions. The specs on the DS550 do not say anything about an F at all? Did you put the correct model number?
SOURCE:
Flashing code f 28
duet washer flashes F20 and stops. Any help?
Oct 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Checksum error, pc clock returning at jan 1, 2004
flashing BIOS is not needed in your case. The only way to solve your issue is to make the mobo work. When working, thats the time you can use utilities to flash your BIOS.
For now, visit your CMOS Setup by pressing DEL or F2 at startup. Then choose LOAD SETUP Defaults.
Oct 09, 2009 | Foxconn 661FX4MR-ES Motherboard
All the lights on front panel on my frigidaire FEQBB30DS0 dryer
Sounds like one of the buttons is stuck. You may have to replace the touch keys panel
Sep 04, 2009 | Dryers
My computer does not recognize my SD 2GB SD Flash Card which I insert into my camera and take pictures. I have a slot on my computer for SD cards. Can I just put the card in the slot and access the...
yes you can directly use the SD card slot, make sure you unlock the write protection before inserting it into the slot if you wish to modify or copy the contents from or to the card.
Jun 24, 2009 | SanDisk 2GB microSD Memory Card
Hp wont turn on flashing green light in back an flashing blue light in front.
open your cpu remove the ram clean it put it back your problem will be sloves
Jul 16, 2008 | HP Pavilion a1250n (EG194AA) PC Desktop
It doesn't start up, only beeps and red light flashes
pls try to use another compatible memory stick.
then confirm the status of your micro processor
Apr 21, 2008 | HP Compaq dc7100 Ultra-slim PC Desktop
Flashing lights
I had the same problem. 1 of four way's can fix it. #1 Put a batt. that has a little charge in that flashing spot 1st. and see if that works. #2 put the batt. in that flashing slot first and then in the 1st slot, If that did'nt work, #3 Put Batt. in backwards for 1 sec. in and out fast. and I do say very fast, In that flashing spot. #4 buy a new one. The one that fixed mine was #1 and it stoppppped flashing, The order I put them in was - 3-1-2-4 I put in #3 batt. first, it was the one flashing And it worked, You may have a bad batt. or it's on it's way out, but try It. worked for me!
Mar 30, 2008 | Duracell AAA NiMH Battery Charger with 4...
Keeps saying disk protect
These old electronics tend to be tempermental, just like my old 1988 Nintendo....when the problem persisted, I held the disk slot open and went Nintendo-style on it (blow the dust out of the disk slot). That cleaned off the disk reader. I put the disk in, and it started reading the disk instantly.
Jan 21, 2008 | Sony Mavica MVC-FD90 Digital Camera
Cameras & photography
Yes, if the picture frames supports Sandisk or has a slots for that..
Dec 17, 2007 | Cameras
Open Questions:
See all StorCase 9 Bays Data Silo DS550 Storage Cabinet Questions
StorCase 9 Bays Data Silo DS550 Storage Cabinet Logo
99 people viewed this question
Top StorCase Computers & Internet Experts
Ekse
Alun Cox
Are you a StorCase Computer and Internet Expert? Answer questions, earn points and help others
