Question about Car Audio Receivers
Clarion M255 no sound??
When I turned my Clarion M255 off two weeks ago it was working perfectly. Yesterday when I turned it on there was no sound. I can turn the volume up to 33 and not a trace of sound. I put a CD in to test it and the CD ran but no sound. The speakers are connected and the connection to the unit from the speakers is fine. Why no sound?
I have a XMD3 with Sirius on a Larson boat. Had same problem - everything seemed to be fine on unit (everything lit up and CD showed different tracks and time changing), but no sound. I suspected a ground problem and checked wires I could see. Found one speaker wire that had been frayed due to faulty installation. As soon as I wiggled that wire I got sound on all speakers. Not sure why one faulty speaker would kill all sound, but it did for me.
Posted on Jul 08, 2008
SOURCE: connecting clarion radio cassette arb1170e
error 6
Posted on Aug 01, 2008
SOURCE: Volume turned up, kenwood shuts off briefly...
does it keep cutting in and out?
if so i think you have your polarities crossed
make sure you have negative to negative positive to positive
Posted on Jan 28, 2009
  • 5 Answers
SOURCE: cd player plays, but no sound comes out of speakers.
first off the amp gets power straight from the battery. the amp is used to power the subs. the subs are suppose to be connected to the amp only( never the speakers).
for the second part you mostlikely killed the wires. you should get some one to look at it and check the wires. thee speakers might need to be re-wired
Posted on Feb 01, 2009
  • 8197 Answers
SOURCE: whete do I send the unit to get it repaired
Here is for the USA. i do noy know wher you are located though. If you live some where else let me know where and will get you the right link. befor you rate
Good Luck and please rate Fixya! for free help
Posted on Apr 07, 2009
  • 655 Answers
SOURCE: Volume issues with clarion M309 installed on a boat
Hello jcox7704,
Your head unit is 50 watts X 4 channel maximum power and 21 watts RMS so it's possible that all you need is more power to the speakers. But even 21 watts RMS should be enough for normal speakers. Before investing in an amp, I'd check the speakers and their wiring. Measure the impedance (resistance) at the head unit side to see if they match up.
Hope this helps.
Posted on Jul 02, 2009
0 characters
1 Points
Why does the yellow wire for the radio on my 2006 185 sea ray sport have no power
The yellow wire should have permanent power for the memory. Check the inline fuse.
Aug 04, 2014 | Clarion M255 AM/FM Marine CD Player
Disconnect all the speaker leads and then hook one speaker (a new, known to work speaker) up directly to the radio using a short (6"-12") piece of speaker wire. Does that speaker work then?
Jan 03, 2011 | Clarion M255 AM/FM Marine CD Player
Set clock on m2455 radio/cd
since i don;t know which version you have of that unit here is a link with manuals just pick the version and it will tlel you how to set your clock.
Mar 26, 2010 | Clarion M255 AM/FM Marine CD Player
Clarion radio sound flickers
make sure your wirings are rated to handle the current needed by your radio. You might have a large voltage drop when it is at high volume level because it will draw lots of current. You might need to change the size of your wires to your Clarion. Check the voltage near the radio when it starts to flicker if it goes below the source voltage of 12V. hope this helps
Aug 17, 2009 | Clarion M475 CD Player
Can i connect ipod adaptor to rca output jacks?
With out an input jack you cannot connect straight to your head unit. The RCA out puts only send a signal out. Your best bet is use an FM transmitter for your Ipod. The sound wont be as good but I can't think of another way with buying a new head unit.
Jun 05, 2009 | Clarion M255 AM/FM Marine CD Player
Coils corroded on the curcuit board.
Accele electronics may carry those.
Give it a try
Jun 04, 2009 | Clarion DB245 CD Player
Whete do I send the unit to get it repaired
Apr 07, 2009 | Clarion M255
When volume is turned up the radio shuts off
Have you checked all of the connections on the speakers, stereo, etc. Being a marine CD player, the wires and connectors are exposed to more elements than a car CD unit. Check for corrosion and make sure that all the speakers are hooked up to the correct "+" and "-" terminals. Not sure if this will help, but thought I'd try. It does sound like a speaker connection problem.
Aug 30, 2008 | Clarion M255 AM/FM Marine CD Player
Unti shuts off at high volumes
You might have a damaged speaker which shorts out at high volume. Disconnect one speaker at a time and crank it to find the one that causes the problem.
Sep 09, 2007 | Clarion M255
Open Questions:
Car Audio Receivers Logo
Top Car Audio Receivers Experts
xxxxxx xxx
Are you a Car Audio Receiver Expert? Answer questions, earn points and help others
