Question about Panasonic KX-FPG175 Plain Paper Thermal transfer Fax
Handset will not charge even with new battery
Cordless phone will not charge. I replaced the battery twice, still won't charge. When I place the phone in the holder the screen on the fax machine says charging for about 3 seconds then returns to the normal screen.
2 Suggested Answers
  • 186 Answers
SOURCE: brother fax 930 machine
I would try sending to another source. If the document goes threw the machine and you get a confirmation report saying it was sent, then it was sent. The person on the other end may be having trouble with their machine as well.
Posted on Aug 03, 2007
SOURCE: Panafax uf-550
Hi! The battery pack is easy to find; Remove the small cover in the middle of the back of the fax where your line in is plugged in. When the cover is removed, you should se a print-board, and on the lower part there, you see a light green battery pack. Don't know if it's easy to find replacement... I'm don't know much about ussage of the fax, so not much help there...
Posted on Sep 14, 2007
0 characters
1 Points
Very weak voice on cordless handset.
All speakers have a magnet in them, over time magnets lose the ability to create magnetic waves.
Jul 06, 2010 | Panasonic KX-FPC141 Plain Paper Thermal...
People on other end of connection cannot hear me, although I can
Check the volume...
Ringer volume
3 levels (high/low/off) are available.
Make sure the handset is idle.
2 Scroll to “Ringer volume” by pressing {down} or {up} repeatedly, and press {right arrow}.
3 Press {down} or {up} repeatedly to select the desired volume.
4 Press {right arrow}.
This is the handset volume
To turn the ringer OFF:
Press {down} repeatedly until “Ringer off” is displayed in step 3.
Mar 28, 2009 | Panasonic KX-FPG376 Plain Paper Thermal...
Fax replacement parts
The jacks generally used for handsets on fax machines are a smaller (fewer contact positions) version of the one that are used for the wall-mounted outlets.
Unless the Brother handset jack looks totally different than the one in which the fax machine is currently plugged at the wall, then the handset jack should look pretty much the same but smaller.
A friend or relative may have a retired corded phone that they haven't tossed out yet so check with them before poking around to look for a replacement as described below.
If you are in the US, check the dollar stores and chain drugstores for corded telephones. Coming from China, they shouldn't cost more than $10 US and may have the exact same connector attaching the handset to the base of the phone. Check them if possible before hitting the cash-register since it is becoming more common to have the handsets on these cheap phones permanently wired to the base which, of course, makes them useless for your needs. Most stores though will let you return the item for a refund.
Checking a couple of stores, you may even find it possible to match the color of the fax machine with your substitute handset.
Nov 13, 2008 | Brother IntelliFAX 560 Plain Paper Fax
My Magic 5 Fax/phone machine is no longer recognising the cordless phone that came with it and while I can get the cordless handset into registration mode, the device (base station) will not register it...
See if your cordless phone will work when plugged directly into the wall jack.If it does then plug a regular phone into the faxes phone connector, EXT jack. See if you can make a call. If you can plug the cordless in again to the EXT jack on the fax machine. In order for the fax switch to function, the machine must
be first in the series if multiple devices are connected to the
same telephone socket. Follow the correct order
If you have multiple telephone sockets for the same
telephone line, the machine must be connected to
the first telephone socket.
If you still get the error I recommend a servicecall to the manufractorer
Jun 16, 2008 | Philips Fax Machines
Phillips magic5 problem
Hi, I had this problem and spoke to sagem at
the solution is simple, turn off your fax machine at the wall, take out your batteries from the handset and leave both off for 15 minutes. then turn on the fax machine and replace the batteries back in to your handset, at it will work.....
Jun 15, 2008 | Philips Magic5 Voice DECT Duo - Fax /...
System is 5 years old. It's a fax, answer phone & cordless telephone.
my dear
the microphone of your handset is not working
Everything elseis fine
if problem exist email on
Feb 06, 2008 | Panasonic KX-FPG175 Plain Paper Thermal...
Handset volume
Unfortunately I have the same set and it appears to be the panasonic- sorry!
Nov 08, 2007 | Panasonic KX-FPC95 Plain Paper Thermal...
Not able to phone out from extension phone
Try plugging the phone in the handset jack of the fax
Aug 11, 2007 | Philips IPF-174 Plain Paper Inkjet Fax
Panasonic kx-fpc141
Try Ths on the handset Be sure the TALK indicator is off.Press LOUD/RINGER button on the handset, the curreent ringerwill sound. To change the Volume press the LOUD/RINGERagain within 5 secs , and the new ringer will sound, you must press LOUD/RINGER within 5 secs or the volume will not change.
May 08, 2007 | Panasonic KX-FPC141 Plain Paper Thermal...
Panasonic KX-FPG175 Plain Paper Thermal transfer Fax Logo
23 people viewed this question
Top Panasonic Fax Machines Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Michel Smith
Are you a Panasonic Fax Machine Expert? Answer questions, earn points and help others
