Question about Garden
Emak fl136 trying find out the degree on the motor side of the sharpener the blades get sharpened at a 30 degree but not sure of the other angle
3 Suggested Answers
VtToolMan
  • 704 Answers
SOURCE: i need to know the right angle to sharpen my chainsaw
If your saw still has the original bar and chain, it was supplied with a .325" pitch chain and you'll need a 3/8" round file with a sharpening guide to properly sharpen it.
Here's a link to the Husqvarna site to the Rancher 455 models so you can select the correct manual to download, that matches your particular saw, based on the year of manufacture, etc.
There is some excellent information about maintaining your saw, along with a really good guide with step-by-step instructions for proper sharpening.
http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=455&types=O
If you're having trouble figuring out the right manual for your saw, use the online Customer Support page and they'll reply.
Hope you find this Very Helpful - Best regards!
Posted on Aug 19, 2009
nedkelly900
  • 345 Answers
SOURCE: which angle to sharpen Poulan chainsaw #2375 18
30 degrees
Posted on Apr 28, 2010
What angle to sharpen a Lenox Chain Saw?
Typical sharpening angle is 30 to 35 degrees.
There is a handy little file holder available with these degrees marked on it. If you can get one, you should be able to determine what angle was on your chain to begin with.
My personal preference is 35 degrees.
Jun 18, 2015 | Garden
Chain saw sharpening angle
For cross cutting is 30 degrees and if you only do ripping it is 10 degrees.
Apr 22, 2015 | Poulan 16" 38cc Gas Chain Saw P3816
HOW DO YOU SHARPPEN BLADES ON ELECTRIC HEDGE TRIMMER BUSHWACKER?
proper method is to use what is referred to as a "lapping table" professional sharpening shops have these , look in your yellow pages for scissor sharpening , but if your a skilled hand and have some time then a simple fine file will work as well , keep same angles on cutting edges ,approx. 30 degree angle
Jun 17, 2014 | Craftsman Bushwacker Bush/hedge Trimmer...
Hi I am after sharpening my MS290 Stihl Chainsaw blade, but don't know what angle the sharpener should be set at. Kind regards Peter Hopkisnson
Hi, there are different angles for different chain types but 30 degrees across and 10 degrees down are good general purpose angles. Hope this helps, regards Phil.
May 08, 2011 | Garden
What is the chain saw blade angle?
This is the angle that you cut each tooth. if you have a chain sharpener you will see numbers on it with a line directly below it. A good standard is 25 degrees, if you want it for ripping purposes you can modify the angle.
moz-screenshot-2.pngmoz-screenshot-3.pngYou really want to match the angle that the blade or chain as been set for.
I would also recommend this website. http://www.wikihow.com/Sharpen-a-Chainsaw
good luck
Apr 18, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Does anyone know where i can get parts for a emak type fl136lr36941 chain saw sharpener?
emak home page
http://www.emakgroup.com/
I suspect it is actually tecomec (both owned by the Yama Group)
http://www2.tecomec.it/database/tecomec/tecomec.nsf/prcat/AD47E80A73B834FBC1256E670057DEDA?OpenDocument
PDFs for each model are at the bottom of the model page.
The Tilton Equipment Company handles Tecomec in the United States.
http://www.tiltonequipment.com/html/totaltecomec.htm
I suggest you contact Tilton or tecomec for parts availability. Oregon sharpeners are subcontracted to tecomec Italy. It's possible Oregon parts may fit your unit. HTH
Lou
Where did you buy the sharpener? They sould also have parts information.
Nov 20, 2009 | Garden
Mcculloch pro mac 5700-20 what is the angel to sharpen chain
The angle to sharpen most chains is 60 degrees for the top angle and 30 degrees on the tooth of the cutter.
Aug 27, 2009 | Saws
Black and Decker 16 in Hedge Trimmer
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
Oct 28, 2008 | Black & Decker Hedge Trimmer
Add on hedge trimmer ryobi weed eater
Sep 14, 2008 | Ryobi 26CC, 22 In. Hedge Trimmer
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
