Question about Panasonic SC-HT930 System
Fornt speakers does not have any sound.
Last year i bought Panasonic SC-HT930 System and all worked correctly. Two days ago when i was listening to music i noticed that the fornt speakers ( Left & Right) does not have any sound. I checked the cables and there is no loos connection. all seakers working except front speakers.
  • 682 Answers
Remove the front speakers cables from the rear-remove surround speaker cables from the rear and put them in the place of front speaker-run a music if you get good sound the problem in your front speakers(speaker or its cable)-if you got nothing you will have a problem in your system itself and need to fix in service center.
Posted on Jun 02, 2008
Panasonic f61 output
If what you identify as the output IC has failed, one or more speakers would be affected.
Nov 23, 2013 | Panasonic sa-ht930 Home Theater Audio...
The other day I came home from work and my Panasonic SC-PT770 would not turn on. I made sure everything was plugged in, all wires were connected, and flipped the circuit breaker. The manual said to plug it...
Did you check the outlet that it's plugged into? Sometimes we see defective outlets in surge protectors. Check the end that plugs into the receiver also, unplug it, then reconnect it.
Feb 25, 2011 | Panasonic SC-PT770 Theater System with...
I have a panasonic dvd home theater sound system SA-HT930, and the dvd player, is broke can do nothing with it, need a new one but the plug between the ampli and the dvd wont fit on any new dvd theater...
Believe it or not there is a seller on eBay who offers a one-price fixit solution for your unit for $100.
http://cgi.ebay.com/Panasonic-SA-HT930-SA-HT940-Repair-Service-/360178573162?pt=LH_DefaultDomain_0&hash=item53dc50df6a
That aside, these types of systems are designed as a package to be used as a unit. Otherwise they might have standard connectors. Another closely-related Panasonic SA-HT system might work for you but I doubt anyone manufactures anyhting to adapt non-standard speakers to standard electronics.
They actually say on page 9 of the manual:
"Use only supplied speakers
Using other speakers can damage the unit, and sound quality will
be negatively affected.
I would interpret that to mean 'use these speakers only with similar Panasonic electronics'.
Jan 15, 2011 | Panasonic sa-ht930 Home Theater Audio...
My parents are getting rid of their Panasonic SC-HT700. The receiver is shot. The speakers and sub work perfectly fine. I was wondering if I could purchase a used receiver (found the SC-HT930 on ebay) to...
the speakers are 6 ohms, and it will be very difficult to find a receiver that is 6 ohm compatible. most home amps are 8 ohm, and will overheat and burn up when used with 6 ohm speakers.
the subowoofer is 4 ohms, but i am unsure as to whether it is self-powered, or if it is powered by the receiver.
4 ohms is the standard for car audio, and 8 ohms for home audio.
Oct 27, 2010 | Panasonic sa-ht930 Home Theater Audio...
Panasonic SC-660 speaker problems
The center and rear speakers are off if the PLII is disabled, make sure it is enabled by pressing the PLII button in the remote, you should see it on the display
Jan 22, 2009 | Panasonic SC-PT660 Theater System
Reciver shuts off
Check your speaker and sub connections. When they are not imputed correctly the system will shut off.
Jan 10, 2009 | Panasonic sa-ht930 Home Theater Audio...
Panasonic SA-HT690 speakers
Actually I gave the speakers and sub away to someone who had the dvd player but did not have the speakers.
Nov 03, 2008 | Panasonic sa-ht930 Home Theater Audio...
No sound through Panasonic SA-HT930 surround system
I've had similar problems in the past. With audio problems trace the problem from the source to the amp.
1. What output is the cable box using for audio, digital or analog?
2. Is there a setting in the cable box to switch between digital and analog?
3. Once you have determined the output of the cable box check to make sure that it's going into the right output on the panasonic
4. This is where the problem usually is...what is the receiver expecting for sound, analog or digital?
5. Switching between the sources...the sound should be on one of them.
Mar 17, 2008 | Panasonic sa-ht930 Home Theater Audio...
Panasonic SC-HT930 System Logo
419 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Joaquim Martins
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
