Question about Frigidaire Heating & Cooling
B3bv-042k-B to replace filter - Frigidaire Heating & Cooling
2 Suggested Answers
pierre1811
  • 144 Answers
SOURCE: air handler
yes and that's dangerous as fumes and exhaust may enter the house
Posted on Mar 11, 2009
What year was this model made?
Your unit (B3BV-036K-BB) is a Westinghouse / Nordyne Unit.
Vertical Flow only, 36,000 BTU, 208/230 volts.
You cannot tell the manufacture date from a model number, only from the serial number. Try contacting manufacture with the serial number...
(nordyne.com)
Sep 13, 2014 | Frigidaire Heating & Cooling
Intertherm q3rd-042k compressor not coming on
Try to replace capacitor with 50MF
Apr 20, 2012 | Heating & Cooling
My split air unit is running inside and out but is NOT blowing any air at all?
Either the blower motor is not working or there is a blockage in the airflow. If you have no air movement in your vents then the blower is the most likely cause. If there is a small amount of air flow then a blockage is more common the cause.
If you suspect the blower motor then you will need to have the motor and the capacitor checked to see if either one or both of them need replaced.
If you suspect a blockage then cut power to the unit and remove the top. Check for a blockage at bother the evaporator coil and the condenser coil. Also check your blower wheel to see if it is in proper working condition. Hows your filter?
Jun 12, 2011 | Intertherm P3RC-042K Air Conditioner
Evaporator coil needs to be replace again. Installed w new manufactured home; 09/2005. Replaced 05/30/08. Needs to be replaced again 09/17/09. All due to leaks. Freon was added. Currently has small leak;...
the manufacture is only required to supply the part free of charge thru its warranty period. the installing company probably would only give a 1year labor warranty and honor the pparts thru the manufacture for 5 years but unless you paid additinal for an extended labor warranty i dont think you are going to have much luck. Make sure you change your air filters every 30 days a dirty filter is one of the biggest causes of evap coils prematurely leaking. Sorry wish i could be more help.
Sep 17, 2009 | Intertherm P3RA-042K Air Conditioner
Froze on the cooling cycle and will now not even turn on
If your AC froze up that is usually a dirty filter or coil, blower not running at proper speed or at all, or low on refrigerant. Since you say it won't come on at all now, that's probably an indication that you are low on charge and now you don't have enough pressure or refrigerant to close the low pressure switch. You will need to have the refrigerant charge checked.
May 07, 2009 | Intertherm P3RA-042K Air Conditioner
The Intertherm AC Model B3BV-030K-A is blowing warm air
If you don’t see any frost on the suction line or big line on the furnace
(that goes from the furnace to the outdoor unit) and the filter and coil are clean then you are probably low on refrigerant.
Apr 14, 2009 | Heating & Cooling
Fan motor to loud is there a quiet replacement intertherm P3RA-042A
No, but has the unit always been loud? If not, then you may need to replace the motor before it goes bad. They will usually go out at the most inconvienient time! I'm a dealer for this product so I am extremely familiar with them. Hopefully this answers your question.
Apr 09, 2009 | Intertherm P3RA-042K Air Conditioner
Air handler
Mar 11, 2009 | Heating & Cooling
Heating & Cooling Logo
49 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Donni Steen
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
