Zanussi button hi I have zunussi jetsystem turbo dry zed 12191. all it does is power light turn,s orange then door locks in thats it nothing else
SOURCE: Zanussi jetsystem Turbodry 1200
Hi, Ive moved into a new flat, and I have a zanussi jet stream 1400 turbo dry front loader. Of course, no instructions were left on how to use it. I cant seem to get anything but soaking wet clothes, no spin cycle, and certainly no turbo dry.
Can you tell me where I could download a users manual?
Posted on Feb 10, 2008
SOURCE: zanussi jetsystem 1400 door seal
IF YOU REMOVE THE SEAL UNLESS YOU ARE AN ENGINEER YOU WILL FIND IT EXTREMELY DIFFICULT TO REFIT IT, TO CLEAN OUT THE SLUDGE USE A PLASTIC SCOURING PAD LIKE THE ONES USED FOR CLEANING DISHES. IFTHE SEAL IS BLACK THIS CANNOT BE CLEANED IT IS A CHEMICAL REACTION TO DETERGENTS ETC BUT IS NOT HARMFUL TO ITEMS BEING WASHED HOPE THIS WILL HELP.
Posted on Oct 09, 2008
SOURCE: How to clean a Zanussi Jetsystem 1400
on my mums zanussi,, after opening door, machine had not drained and spined, closed door again could not get machine to go,, this time could not get door opened..there is power to machine.
Posted on May 19, 2009
  • 57 Answers
SOURCE: zanussi jetsystem turbodry 1200 door wont open
its the doorcatch,turn power off, remove lid and put hand in machine where doorlock is situated feel about and try open catch, repair or replace?
Posted on Jun 24, 2009
caroldon
  • 17129 Answers
SOURCE: hotpoint aquaris wml 560, 1) all lights flashing
Possible that the inlet valve is not working or the ccontrol unit is faulty.
Please switch off and when switched on check for the voltage to the inlet valve, if water flows, if not the control panel is faulty.
If voltage is present and valve does not work then the valve is faulty.
Also check the DOOR switch( a safety switch) because if the switch is not working the control panel will not allow the control panel to proceed to switch on motor.
Also check and tighten all the connectors to the control panel.
Posted on Aug 31, 2010
How to reset zanussi jetsystem programme function board with error E40
E40 is a door lock fault code, you need to replace the door lock,
you cannot reset the fault code, this happens automatically when the fault is rectified. nice easy job though.
Sep 30, 2016 | Zanussi Washing Machines
I have a Zanussi Jetsystem 1400 7kg washing machine it keeps coming up with a lock on the error screen and won't start for me
have you checked to see if child lock is enabled? does the door lock when start button is pressed?
Apr 10, 2014 | Washing Machines
Power button seems to be broken
the trigger has been damage you have to replace it .if you want i can fix it im a technician
Jul 18, 2009 | Washing Machines
May 19, 2009 | Zanussi Washing Machines
Zanussi zwf1430s error codes - E40 / E41 & ELE
hi
ele means the pcb is in factory settings . all you need to do is turn back off the on again then will be back to normal use. but e41 usally means the door lock has failed. does it click alot when you start it up and not do anything? if so this will be the lock
regards
Mar 19, 2009 | Zanussi ZWF1430W Front Load Washer
Zanussi zwf 1432 w washing machine
pcb as the signs were that the pcb was stuck in a programme and unable to change. Anyway, long story short, to fix it:
Take the lid off the washing machine (2 screws at the back) *unplug first
Locate the pcb, unscrew and lift above the washing machine with all wires in tact.
Locate the wires that are coming out of the back of the "program" board, it should be 2 blue wires.
Follow these back to the pcb and unplug
plug in washing machine
Turn on washing machine
Only the on/off light should come on
Whilst on, and being careful, plug back in the wires you unplugged
VOILA, fixed washing machine!!
Right, have to go, got a weeks worth of washing to do!!!!
Feb 24, 2008 | Zanussi ZWF1430W Front Load Washer
It appears that you may have a faulty door interlock or a faulty PCB. pcb is not really a DIY job as some boards require proramming on certain versions. Regards Advisor
Oct 30, 2006 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
