Question about John Deere Garden
Diagram 513 John Deere brush hog gear box
John Deere 513 gearbox manual
SOURCE: how to replace belt on john deere 425
take a sharpy and outline it before removing
Posted on Jul 19, 2009
mowerman1857
  • 389 Answers
SOURCE: v-belt route installed on 48" deck of John Deere LA130
http://jdpc.deere.com/pimages/PU00/PU00859________UN28APR08.gif
Copy and paste this in your address bar and it should take you to a picture of how to route the belt
Posted on Sep 18, 2009
wireguy212
  • 1627 Answers
SOURCE: ELECTRICAL PROBLEM
Can't get you a diagram but i can tell you most electical problems on these tractors can be solved by replaceing the key switch/modual or cleaning corrosion from fuse holders.
Posted on Nov 10, 2009
nova2nv
  • 197 Answers
SOURCE: our john deere sabre 17.542 hs ride on mower will
If traction drive belt is turning you should check the input drive shaft on top of trans to see if it is turning as well,Traction drive belt is suspect but could be a stripped out input shaft pulley.Make sure the machine tow lever is not pulled out,rear of machine by tow hitch.Also pull rubber caps off of both axle ends to see if one the axles is turning free inside of rim,if so remove wheel and replace axle key.
Posted on Nov 15, 2009
6ylucy
  • 742 Answers
SOURCE: manual for john deere sx95
ask manualfox.com - they have it.
Posted on Apr 19, 2010
4440 john Deere tractor won't move in reverse
hi
insure that the external lever are not jammed over debris if this is clear more likely the reverse gear box/ shaft charring reverse gear is stiff due to internal seized parts of the gearbox
Jan 04, 2018 | John Deere Garden
Gears
remove the black hub caps, then pull off the metal push nuts, then pull the wheels off, this will give you access to the motors and gear boxes, you'll then have to remove the two screws that hold the gearbox in, then you should be able to finagle the gearboxes out
Jul 25, 2013 | Peg Perego John Deere Turf Tractor
Peg perego gator makes clicking noise
most likely need a new gearbox, identify which side its coming from then remove the motor from gear box and run motor by itself and see if it clicks, if not its the gear box
Jun 24, 2012 | Peg Perego John Deere Gator HPX Ride on...
I have an old John Deere 1209 hay cutter and I cannot get the gearbox to stop leaking oil. I have replaced the seals once and plan to replace them again tomorrow. If they do not hold this time would...
you can fill the gear boxes with grease but also have some oil in there to so they lube till they get warm and grease breaks down reason the seal wont hold is that the seal has wore into shaft
Aug 06, 2010 | John Deere 6300,6300l,6400,6400l Tractor...
Garden Logo
51 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
