Question about Saws
Elektra beckum KGT 501 table saw
I need the wiring diagram for the Start/Stop switch on the KGT 501
rowdy45176
  • 2176 Answers
SOURCE: Table saw won't turn on.
that reset is breaker and I would think that it should click when reset. I looked at a breakdown and the part number for the breaker is OLSL list 2.16 and they are in stock at Searspartsdirect.com If you have a volt ohms meter I would check the electrical starting at plug end of cord thru the breaker. Make sure you unplug tool before attempting. I would also take a look at the brushes for excessive wear and sawdust buildup. Let me know if I can help more
Posted on Jan 19, 2009
SOURCE: makita table saw switch wiring
After much trial and error, a little smoke, and wrecking one replacement switch, I solved a similar problem with my Craftsman Cmpd Mitre saw. Different saw, but likely the same principles are involved.
If the switch is a double pole single throw switch, with one side normally open (N0) and the other normally closed (NC), and the saw has a separate wire for the brake, this will probably work.
One side of the switch should have contacts that are normally open (NO) and only connect when the switch is ON. The Hot (Black) wire from the plug connects to the wire on the machine side (red or maybe black) through this NO side. So, connect these two wires via this NO side and the saw will run when the switch is ON but will have no brake; so far so good.
There should be another wire (Not the neutral white) which is the brake wire. This gets connected to one of the connection sites of the Normally Closed (NC) side of the switch. From the other connection site of this NC side run a short "jumper" wire (of the same guage as the other wires) to the Machine Side of the NO side of the switch (same place as that Red or Black? wire above) .
What seems to happen is this:
There's no power to the machine or the brake when the switch is OFF. Turn it ON and power goes from Hot through the NO (now closed) side and the saw runs. The brake doesn't run when the saw runs because the NC switch is now open. Turn the switch OFF and the NC switch is in fact closed and power is transfered to the brake via the jumper wire from the still spinning armature which now acts as a generator (alternator?). Once the brake has done its job and the armature stops spinning there's no power anywhere until you turn the switch ON again.
Or at least that's the theory, and in my case it works; no more smoke.
Posted on Feb 04, 2009
  • 12 Answers
SOURCE: on/off switch table saw
It sounds like you are wiring the switch wrong. Give me the model # and I will look for a wiring diagram for you.
Posted on Feb 25, 2009
  • 86 Answers
SOURCE: ryobi bt 3000 table saw belt installation diagram
The BT3000 actually has TWO v-belts! Here's a link at the end of this solution to an exploded diagram. Basically you have a major disassembly, but it really isnt that complicated.
More great info on the BT3000 is available from the web site http://bt3000.com/
I have a BT3100 saw, and it is a good tool, but does require attention in maintenance procedures, but Ryobi did outline the necessary steps in their manuals. The above website also has the owner manual if you need one.
  1. Unplug saw
  2. Remove the blade
  3. Lower mechanism all the way to the bottom
  4. Flip over saw and lay on it's top
  5. Remove the blade guard panel opposite the motor
  6. Unbolt the motor assembly and remove the belt cover
  7. Replace the broken belts
  8. Re-assemble (be careful not to cross-thread the bolts in the aluminum housings!)
http://bt3000.com/Manuals/BT3000-Parts-Manual.pdf
Posted on Mar 22, 2009
efs_perpends
  • 1996 Answers
SOURCE: I need a wiring diagram for a Delta xl-10 table saw.
Unfortunately, the manual for the XL-10 saw is no longer available online. Here is a link to the parts list and diagram.
If that is not helpful, please consult a qualified electrician, who should be able to guide you in the wiring of the switch and motor for that saw.
Without access to the schematic, I'm afraid the best solution to your wiring question is for some capable electrician to take a look at your saw in person.
Posted on Mar 31, 2009
Model 36-979. Where can I get a wiring diagram for the power switch?
images for Delta Table Saws wiring diagram for power ...
Replacing a Table Saw Power Box and Switch. Rocket ...
? 7:45
https://www.youtube.com/watch?v=8A25b9BjkmY
Feb 12, 2014 - Uploaded by AdventuresInDIY
See how an in the way power box on a 10 inch Delta table sawwas switched out ... Would you happen to have a wiring diagramfor your saw.
Oct 28, 2015 | Delta Saws
Switch wiring
Did you manage to get in contact with the manufacturer of your saw? They would surely help you with your problem.
May 03, 2013 | Makita MLT100 TABLE SAW FOR 220 VOLTS
DeWalt DW708 switch
http://c.searspartsdirect.com/lis_png/PLDM/P0201024-00003.png
This is the newer 744 series, white cord to white motor and black cord wire to black motor.
If your motor needs the mag starter that 5th loose wire, usually red, goes to the start terminal on the mag starter.
Feb 14, 2012 | Dewalt DW744S 10" Portable Table Saw with...
My craftsman 10" table saw will not start. i flip the switch and recently it would "ping"...blade would spin briefly then stop. I could find "the spot" when turning on the switch to get it started but it...
No, it is more likely the motor. To check it tho, bypass the switch and see if it kicks right in when direct wired. That way you kno if it is the switch or the motor. J.
Jun 28, 2010 | Skil 10" Table Saw
Could any body tell me why has my copasitor has blown on my elektra beckum tkhs 315 E/P
If the saw is overloaded when cutting, it will be in 'start' mode which causes current draw through the capacitor. Capacitors are meant to do so only when starting. You may need to use a heavier gauge extension cord so that the saw has full power. Hope this helps!
Jan 25, 2010 | Saws
My Elektra beckum TKHS 315 EP Table saw keeps blowing fuses. When I turn it on it tries to go backwards then blows the fuse. The blade is securely fixed and spins freely. There are no obstructions. It is...
Hi I have the same problem - I think it may be the capacitor by the motor which has failed - I have just ordered a spare which I hope will fix the problem. Check the capacitor for any signs of damage ie. explosion!!
Jan 16, 2010 | Saws
Mar 28, 2009 | Saws
Hitachi c10fr table saw wiring diagram
Here is a hand drawn diagram
Please rate this a fixya
Feb 13, 2009 | Hitachi 10", Table Saw with Stand,...
Saws Logo
110 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
