Question about Northwest Territory 14X14 Instant Canopy
I need a replacement bracket - Northwest Territory 14X14 Instant Canopy
Idler pulley bracket where can I buy one or is there an alternative to it
you need to post year, make, model and what engine?
also which idler pulley? I'm guessing you're probably looking at the accessories drive belt ("fan belt") idler pulley bracket.
Is this a serpentine belt.
a lot of cars use Idler and or tensioner pulleys on the timing belt/chain. the Idlers often don't have brackets
why are you replacing the bracket? did you break it? or do you just need the pulley? I normally replace both pulleys (idler and tensioner) when replacing either one.
anyways.. need a lot more info to answer your question
Dec 24, 2016 | Cars & Trucks
What model would be equal to a sharp microwave model R1490
Chances are only an identical model will fit the brackets. Any new unit will come with new brackets. Just swap the brackets out and install the new unit
Oct 16, 2016 | Sharp Microwave Ovens
Bottom bracket need replaced. needs a new crank set. what size if the bottom bracket and what size crank set is recommended, or does the bottom bracket need to come out to find the size. bought the...
impossible to tell you without knowing the bike brand and model and year, although you have provided that 1999.
If you take into a bike shop, which is the usual place to purchase the parts you need, they will be able to tell you what size Bottom Bracket will fit your bike, also what options you will have for replacement cranks and bottom bracket. This could be a very complicated issue when replacing with parts that are 11-12 years newer, the shop will be best equipped to give you all your options.
Apr 07, 2011 | Cycling
How to replace headlight on a 1997 chevey camaro
You will need a torx wrench to be able to replace your headlights. There is bracket that hold your headlights on. Unscrew the 4 screws (2 on the bottom and 2 on the top) of the bracket and pull the bracket off. Disconnect the wires from the old bulb.
Once you get the new bulb screwed in make sure to check the level located on the bracket is at it's optimal position.
Nov 06, 2010 | 1997 Chevrolet Camaro
How do you replace the alternator?
there are 2 locking bolts underneath and 2 bolts on the front belt adjuster bracket,undo the 2 bottom bolts and the bolt in the alt/bracket,loosen the block bolt/adjuster bracket,that will release the belt tension,then pull out of the engine bay,replacement is the 2 bottom bolts finger tight then the belt over the pulley then finger tight for the bracket,tension the belt be levering the alt away from the block and tighten up the alt/bracket first then the other 3.check belt tightness (1/2"movement/slack on longest run)then recheck all bolts tight.....you will need to recode your radio after.and dont forget to note what wires came off what terminals.......draw a picture if needed...
Jun 24, 2010 | 2004 Volkswagen Jetta
Need part numbers to replace eyeshields on Dayton bench grinder
Your grinder is listed on page 3085 of the Grainger catalogue. The part number for the eyeshield is 00281.00 and the number for the lower eyeshield bracket is 00280.00. The right hand upper eyeshield bracket is number 25188.00 and the upper left hand bracket number is 25177.00. All of this can be ordered through Grainger at 1-800-323-0620. Marvin T.
Jan 13, 2010 | Grinders
How to replace the assembly of headlight on ford escort 1998?
Take a #10 metric wrench, disconnect the electrical fitting from the lamp, and loosen the nuts on the bracket which carries the lamp assembly...
you'll need to pull the bracket, then take the headlight assembly off the bracket, then replace the headlight assembly, then put the bracket back onto the car.
This is the easiest way if you're a novice---
Dec 26, 2009 | 1998 Ford Escort
Need to replace starter on a 1986 Camaro, but cannot get the old starter past the exhaust pipe.
Removing the starter
  1. Disconnect the negative battery cable.
  2. Raise and safely support the vehicle.
  3. Disconnect all wiring from the starter solenoid. Replace each nut as the connector is removed (as thread sizes differ from connector to connector). Note or tag the wiring positions for installation.
  4. Remove the bracket from the starter and the two mounting bolts. On engines with a solenoid heat shield, remove the front bracket upper bolt and detach the bracket from the starter.
  5. Remove the front bracket bolt or nut. Lower the starter front end first, and then remove the unit from the car.
These are the steps for removing the starter on the Camaro. Did you remove the bracket? Hope this helped and best wishes.
Aug 01, 2009 | 1986 Chevrolet Camaro
Lee spring bracket for a Ford F150
You are going to have to go to Ford for this part.Shouldn't be to expensive. They will probably have to order the part for you.
Mar 18, 2009 | 1992 Ford F150 SuperCab
Northwest Territory 14X14 Instant Canopy Logo
23 people viewed this question
Top Northwest Territory Garden Experts
Dennis Key
Dennis Key
john h
Are you a Northwest Territory Garden Expert? Answer questions, earn points and help others
