Question about Watches
Bench watch I have bc0169bk how do you get back off
Bench gents watch BC0045SL INSTRUCTIONS
Try Googling (bench)(BC0045SL)(manual) without parens.
Sep 13, 2017 | Watches
Battery for relic wet or 15478 and how to remove back of watch
Watch back will almost certainly need a dedicated wrench to loosen and unscrew it. Sometimes considerable force is needed and in that case a watch repairer would remove the strap and fit the watch into a bench-mounted holder.
Once the back has been disturbed the water resistance cannot be guaranteed unless it is pressure tested after refitting.
Jan 23, 2017 | Relic Watches
Dont know how to set my son bench watch
sorry but if you post a picture of it perhaps some one can guess . the web shows too many to guess at which one or type you have
Mar 28, 2016 | Watches
How do I set the time and date on my bench digital watch
hold the light button until it flash's 12 or 24, then press mode which will change you on to the time, date, ect then fiddle around with the start and reset button to toggle with the time and date. when your done with the time press light again.
Nov 26, 2015 | Watches
How to set time on Bench Gents LCD Strap Watch
How to set the time on a bench digital watch Bench BC0013BR
Oct 26, 2009 | Watches
Reset time on bench watch bc0013br
I have a Bench Watch BC0013BR and do not know how to set it up any help would be appreciated
Oct 05, 2009 | Watches
Bench Watch BC0013BR display problem
There may be two batteries in your watch - one for backlight and another for movement. Check this out at your nearest watch repair shop and replace if needed. Alternatively you can do it yourself if you have knowledge and skills.
Rate, please.
Jul 21, 2009 | Watches
Watch battery cover
You will need a special tool to pop it back on. Any other way will result in the crystal breaking.
Aug 04, 2008 | Kenneth Cole 1213 Wrist Watch
Bench Watch BC0088 set up manual
Hold down the bottom left button for 5 seconds. It goes to set mode.
Apr 26, 2008 | Watches
Watch cover
1)put a little silicon grease around the case cover 2)put cover back on the case 3)lay the watch on a hard surface spicifically on the edge of a wooden chair or bench and the face of the watch on your palm, the case cover is under and paded on the chair or bench. 4) now gently press the watch and it will snap.
Mar 17, 2008 | Watches
Watches Logo
43 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
