Ariston amd 129 f02 - Washing Machines
2 Suggested Answers
  • 53 Answers
SOURCE: I have an ariston amd 129 washer dryer. F-10 keeps
F10 - Pressure switch not sensing correctly. blow in to switch gently it should click. blow into pipe should be clear.
Posted on Oct 14, 2009
What does the error code 07 in an ariston amd 129 ?
the led flashes seven times? then pauses for 8seconds? this is how you determine the service code on a 129 there isn't a F7 code on a 129 on a 125 it's a heater relay stuck.... hope this helps~~
http://appliancejunk.com/forums/index.php?action=dlattach;topic=8959.0;...
Jul 15, 2014 | Washing Machines
Ariston artxf 129 error f02
F02: Blocked Motor, Short-circuited/Open Tachometry
Overhaul CNE
Overhaul Motor connector
Control CNE Continuity/Motor Connector
Control Motor Windings
Control Tachometry Windings
Replace Card
Dado
Jun 04, 2014 | Ariston Technologies AW 129 NA Washer With...
WHAT IS F12 IN A WASHING MASHINE ARISTON AQUALTIS AQXXF 129 H?HOW CAN I FIX IT?
F12 SPECIFIC FOR LVB2000 INDESIT EVOLUTION / DIALOGIC.
F12: Lack of Display card-Main Card Communication
1. Check the effectiveness of contacts on CNC Connector Card
2. Overhaul 8-way connector on Display card
3. Check continuity of CNC-CN 8 way connector
4. Replace Main Card
5. Replace Display Card
Dado
Apr 24, 2014 | Ariston Technologies AWD 129 NA Washer/...
How to remove front of Ariston washing machine AVD 129 SK
take the top off,remove the soap bucket,take the screws off on the pc board/front cover. the top screws of the front pannel are usualy behind the display cover. the botom screws are behind the bottom plastic cover which you have to prey off with a screwdriver from the top side.
Mar 18, 2014 | Ariston Technologies Washing Machines
It displays F-12 error and I don't now what is it? I heve made a repair on the machine that is a Ariston AMD 129 model. The conecctions on the main board whith AC current was burned. I repair it but it has...
i am not familiar with the particular brand, but f-12 is typicly a fill error. didd your technicial turn off the water source? be sure the water supply is turned on properly at both the hot and cold lines leading to the washer.
Mar 24, 2010 | Washing Machines
F02 error code on ariston 1400
code F02 means motor jammed or motor tacho detached.
Check connections on motor, motor plug, and module.
Hope this helps.
Jan 15, 2010 | Ariston Technologies Washing Machines
I have an ariston amd 129 washer dryer. F-10 keeps coming up on diplay
Oct 14, 2009 | Ariston Technologies Washing Machines
The Ariston ATVF 129 wash machine do not work and post F-02
F02 is a indication that the motor has jammed, and or the tacho has come loose or broken.
The tacho is the magnet at the end of the motor away from the pulley., check this first, you may have to have a new motor fitted.
Plz rate my solution.
Thanks.
Jan 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
