Question about Alert Driveway Alarm System
Change frequency chamberlain
I replaced the 9v battery about two weeks ago. a couple of days ago the alarm started randomly going off when there is no activity near the sensor. brought the sensor in the house to fiddle with it and see if something was obviously wrong. it won't work at all now...only the learn button will make it sound off. any advice?
    Top Expert:
  • Alert Master
  • 10,875 Answers
YOU HAD IT IN THE SUN,it is burnt out now
Posted on Jun 23, 2015
Car is "dead" but battery/alternator/starter are all in working order. Hornet is causing this.
Sounds more like a faulty battery terminal to me from your description ,try cleaning and make sure its tight then smear with petroleum grease.Clean terminal with a kettle of hot water first
Jul 26, 2013 | Cars & Trucks
Phantom bell rings on Siemens wirreless door bell chime jsjs-204, I do not have instructions
You may need to change the frequency of the chime. In this model, you need to remove the batteries from the receiver unit and wait for a while. Then replace the batteries. The doorbell unit should automatically set itself to a different frequency once you press the button, which will(hopefully) solve the problem.
It seems impossible to find the instruction manual for the doorbell. But see http://oddsnsods.net/blog/?p=68 who had a similar problem with a different Siemens model, which works on the same principles. (I can't seem to be able to remove the battery from the door bell unit on the jsjs204, but it reset itself after changing the batteries in the receiver).
Nov 01, 2011 | Desa International White Wireless Plug In...
The alarms are hardwired together with battery back up. At random times they will sound with no obvious reason. Sometimes a couple times a day then may not sound again for a week.
They simply may need cleaning, due to a dust, lint or spider buildup in the sensors. You can accomplish this by using canned compressed air (like you clean your computer with) Attach the straw nozzle to the canned air, remove the detector cover(s) and with short bursts of air, clean the interior of the detector. When that's completed, blow out the detector cover. Before, your replace the cover, you should change the backup battery(s) in all the units, if it's been a year, since you last did it
Doing the above should solve your alarming problem..
Feb 18, 2011 | Kidde i12040 Hardwire Smoke Alarm with...
2007 Sonata car alarm(security alarm) randomly goes off--it's happened when it's locked and unlocked and all times of the day. The Keyfob stopped working about 3 weeks ago and then randomly worked now and...
over sensitive sensor in the car could set it off randomly... bonnet boot, door handles.. one of the motion sensor thingiis, if fitted. the beeper issue could be the position of the incoming sensor of the alarm it self.. if it is an imboliser as well then there is whole other range of issue.. turn it off or at least disconnect the siren.. or you could just pay some one way too money to fix the problem for ya... good luck
Sep 02, 2010 | 2007 Hyundai Sonata Limited Sedan
How to program garage opener
SORRY,
Chamberlain key pads won't work with a genie receiver.
You will need to echange it for a Genie brand.
Also be sure what frequency your Genie is - They have changed the frequency a couple of years ago.
Jun 30, 2010 | Chamberlain 740CB Wireless Keyless Entry...
Randomly won't start
Change the crank censer
May 30, 2009 | 1995 Subaru Legacy
2006 toyota solara, alarm keeps going off
Those cars have a frequency sensor that is attuned to the exact sound frequency of breaking glass. Are there any noises nearby that resemble glass shattering? Wind chimes? Any type of extraneous noise at the freq of glass breakage will set off the alarm.
Feb 27, 2009 | 2006 Toyota Solara
Chamberlain liftmaster keypad works when open but not when closed
try new code with 4 new numbers. maybe a key is worn and cold in morning is not helping,
Jan 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remotes won't work
Sounds like a frequency issue. A remote work like the radio in your where each station is on a different frequency. Some signal is interfering with you frequency (390Mhz) You could try another brand external receiver with new remotes or with that old of an operator you might just think about replacing the operator (don't go with "Wayne Dalton")
Nov 27, 2008 | Sears Craftsman LiftMaster Chamberlain...
My lift master garage opener opens randomly
change the security code in the opener and the remote.
seems like omeone in your are have the same frequency remote.
Nov 12, 2008 | liftmaster Chamberlain Garage Door Opener...
Alert Driveway Alarm System Logo
167 people viewed this question
Top Alert Home Security Experts
Paul Bade
Charles Ma
Charles Ma
Five sok
Five sok
Level 1 Expert
Are you an Alert Home Security Expert? Answer questions, earn points and help others
