Question about Boating
I have a johnson outboard 7.5 horsepower .i dont know the year of manufacture .i have a number from the engine .390232-1
captainjeffq
  • 52 Answers
SOURCE: 1974 60hp johnson outboard won't run on full throttle.
Carbs probably need to be cleaned and re-built. Common problem in outboards that havent been run in a while
Posted on Apr 13, 2009
  • 6 Answers
SOURCE: 35hp Johnson evinrude outboard not running at full potential
Hi, did you buy your engine used? Sounds like your gonna have to get the carb or carbs cleaned. Its possible you could have a stopped up fuel filter, or not enough spark but i am guessing its gonna be the carbs. They got some gunk in em i bet. Probably old fuel turned to gunk from setting up. I had the same problem on my 40 horse.
Posted on Aug 22, 2009
Testimonial: "Hi, thank you very much for your help, I will strip the carb down and have a look. Once again, many thanks, I am very greatful"
  • 6 Answers
SOURCE: I can't find a vin number on a johnson outboard
model and serial numbers are located on small plate rivited to the transom mnt on the outside tiller side verticle surface. if not there, consider if perhaps has been removed. if you find evidence of this, mtr probably hot, or stolen.
Posted on Oct 24, 2009
Testimonial: "I was able to lift the cover off the motor and locate it. Thanks for the respnse!"
  • 677 Answers
SOURCE: I have 1987 Johnson 20 hp outboard motor and need
The g/box in your motor holds about 1/2 litre of oil.It comes in usually 1 litre bottles.Squeeze it in the bottom hole with the spout fitted to the bottle untill it comes out the upper hole and then quickly put the screw plugs back in.Hope this helps
Posted on Dec 03, 2009
SOURCE: how to remove the lower unit on a 35hp Johnson outboard yr 2000.
if you haven't fixed this already, take the pastic water pick up covers off there are two joiner nuts in there undo them, there is a plastic cone on each end take them off and it will slip through. I own the same model and year outboard.
Posted on Jan 13, 2010
I need to know the specs on an evinrude outboard motor serial # 3030-07926
Everything in marine outboard engines is tied to MAKE and Horsepower. From that, you can find the year using the serial number. Once you have those, you can Google
year make model specs
or
year make model manual
Evinrude Outboard Motor Model Numbers
Jul 30, 2017 | Boating
Year of manufacture of Johnson 40Hp outboard Model No AJ40BALE1A Serial No. G02651879
Ed,
Near as I can tell, it's a 1979. As of 1980, Johnson/Evinrude used two LETTERS at the end of the model number to designate the year. (See attached) Your model number ends in a number and letter (1A) which leads me to believe it's earlier than 1980. Prior to 1980, the last two numbers of the serial number were the year. That's how I surmised yours is a 1979, by the last two of the serial. G02651879
Hope this helps.
Fred-
Outboard Engine Serial Number Year Match up
Dec 05, 2016 | Boating
What year is a evinrude outboard with serial number 1451821
The motor HP is critical in such searches. Here are all the resources you need to find the information yourself.
About this result
How To: Outboard Engine Serial Number Year Match, iboats.com How ...
www.iboats.com/basics/serial_number_year.html
  1. Cached
  2. Similar
For engines prior to 1969 refer the the Johnson 1960-1979 serial number year chart located here. If you have a commercial model refer to the Johnson commercial serial number year chart located here. Evinrude changed how they indicate year in the model number in 1980.Mercury Outboard · ‎Evinrude Outboards 1950-1979 · ‎Johnson Evinrude Commercial
[PDF]5006145_Model Number Reference.fm - Evinrude
shop.evinrude.com/media/document/ModelNumberReference.pdf
  1. Similar
MODEL NUMBER DESIGNATION - OUTBOARDS. Model Years 1980-1998. V E 70 T L ED A. MODEL VARIATION. A = Australia. B = Belgium. C = Canada.
Evinrude Outboard Motor Model Numbers & Codes - Marine Engine
www.marineengine.com/manuals/evinrude/
  1. Cached
  2. Similar
The nameplate should contain a model number and a serial number. The model number will identify the year and certain details of that motor. 1980-Present: Evinrude outboards from 1980 to the present use a model number that can help determine the year and features of the motor. See the model number code here.0.5HP · ‎0.9HP · ‎1HP · ‎1.1HP
Marine Motor Look-Up Guide - Auto Repair Manuals
www.autorepairmanuals.biz/page/599222
  1. Cached
  2. Similar
keywords: Find year, serial, number, model, number, #, outboard, motor, marine, motor, look-up, Johnson, Evinrude, Mariner, Mercury, Force, OMC, Yamaha, ...
EVINRUDE OUTBOARD MOTOR MODEL YEAR LOOKUP GUIDE ...
www.maxrules.com/models/OMC_models_files/EVthru79/ev_index_79.html
  1. Cached
  2. Similar
WHAT YEAR IS THAT OLD EVINRUDE? FIND OUT HERE ON OUR MODEL YEAR LOOKUP CHART! evinrude outboard with serial number Google Search
Nov 29, 2016 | Boating
Johnson V4 outboard #C0020325 I'd like to know the year and hp of this engine
call your local outboard dealer . they will help you figure it out
Sep 12, 2016 | Boating
What year is my Evenrude 5.1 outboard
provide a model number and perhaps someone can assist you .
May 10, 2016 | OMC Johnson Evenrude 9 1/4" X 9" Stainless...
Need to rewire 1977 35 horsepower johnson outboard
If it's an electric start you need to get it from an after market supplier, Johnson Motors is gone. Go online to CDI Electrical and put in the specific information and it will give you the correct part number for what you need. Here's their part number.Johnson / Evinrude Wiring Harness: 413-9914
Sep 25, 2014 | Boating
What year is a johnson 4 hp outboard serial number b 7643180 model number bj4brccs
To get the year of Johnson and Evinrude outboards use the word "INTRODUCES". Each letter corresponds to "1234567890" respectfully. It's best to check with a model year reference book, but this motor's model number contains "CC" which would indicate it's a '88.
Sep 21, 2014 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
What year is my outboard motor
It appears you have a Johnson, 40 horsepower, electric start, long shaft (20 inch transom) 1973.
May 14, 2014 | Light Outboard Motor Boat Bass Fishing...
Can i find the year of of manufacture of my old johnson 25 hp outboard motor by its serial number?
yes if yuo go to iboats.com the forum will allow you to search by serial number and give info on your outboard.
Aug 17, 2013 | Sierra International 18-4310 Marine...
Boating Logo
41 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
