Lexmark x7576 I just installed this printer and it's not printing but it says that it's ready
SOURCE: lexmark z705 printer
vista printer install
Posted on Dec 09, 2007
Ajkill
  • 2035 Answers
SOURCE: Printer stays offline on Vista
To help you resolve this problem, try the suggestions below.
The Basics:
1. Check your cables and their connections. Reconnect the parallel or USB cable to the computer and to the printer. Make sure there is a direct connection, with no scanners, switchboxes, or hubs inline. Other devices can sometimes cause communication problems between the computer and printer. For more information on this issue, see 'Scanners and Other Devices' below.
2. Remove the power supply cord and reattach it to the printer. The printer should make a noise soon after the power cord is reattached. Note: This is a general diagnostic that seems to fix minor communication issues.
3. If you are using a parallel port, verify that your computer is set up for bi-directional communications. If bi-directional communication is not enabled on your computer, the parallel port mode setting in the computer CMOS setup will need to be set to either bi-directional or ECP. Do the following:
1. Right click on My Computer and select Properties.
2. Click Device Manager. You should see a section called Ports (COM & LPT). There should be a (+) sign to the left of that section.
3. Click on it, and look for ECP Printer Port (LPT1). You may need to contact your PC manufacturer if any of the following are true at this point:
* It does NOT say ECP in the description.
* There is no listing for Printer Port or any variation of'LPT.
* There are question marks or exclamation points next to the LPT1 port listing.
Let your PC manufacturer know what you are trying to accomplish and what you have done up to this point.
4. Go to Start, Settings, Printers. Right click on the Lexmark object and select Properties.
5. Click the Details tab.
6. Under Print to the following port, it should say LPT1 for parallel cables and USB Lexmark or USB00x (<x> = 1-9) for USB cables. You can change these values by clicking on the arrow and selecting a new value from the list. Click Apply, and OK.
If you are using a USB cable and the USB value is not in the list, try uninstalling and reinstalling the driver as detailed in your manual.
If you are using a parallel cable and do not see LPT1, you will need to ask your PC manufacturer to walk you through the process of turning your parallel port on. You will also need to make sure the Lexmark printer is set as default. If not, right click on it and select the default option.
7. If the printer does not work when connected directly to the computer's port and you have complied with the steps above, there may be a hardware problem. In this case you should perform a self-test on the printer. (Click Start a New Search above this solution and enter self test in the search field.)
Scanners or other sharing devices could cause communication problems.
* If you are using a parallel connection, please verify that your cables, scanner, or other sharing devices are IEEE-1284 compliant .
If you are using an USB connection, they need to be at least USB 1.0 compliant.
* If the printer prints normally without the scanner/sharing device and its cables, there might be a problem with the scanner/sharing device. Please contact the manufacturer for information on how to fix such issues.
Note: Although connecting devices through a scanner (or other sharing device) may work, we do not recommend or support the use of such devices as they can interfere with the signal strength that is sent to the printer. Please contact the manufacturer of the scanner/sharing device regarding communication issues for that specific device.
USB Issues:
2. Click Device Manager. Click on the plus (+) sign next to Universal Serial Bus Controllers. The host controller listed here is the software that runs your USB ports. It is linked to a chipset on the motherboard that requires frequent updates to satisfy the needs of newer products such as your printer.
3. Look at the name of the host controller. Some of the more common names are Ali, Intel, AMD, Via, and SIS. You will need to contact your PC manufacturer to get help updating these specific controllers to the newest driver set.
If YOU are the PC manufacturer, check the manual for your motherboard to find out who makes the chipset for the motherboard. Again, Ali, Intel, AMD, Via, and SIS are some of the more common manufacturers of chipsets.
4. Look for either Lexmark USB Printer or Other Devices in the Device Manager.
5. If you see anything with Lexmark..., click on the plus (+) sign to its left and look for Inkjet Color Printer below it.
6. If it is present, double-click on it. Tje next screen should report that the device is working properly.
7. If you see any question or exclamation marks listed in the Device Manager (small yellow icons next to the listings), double-click on those items to obtain information on what's wrong with the items. This information is useful for troubleshooting the system.
8. If not or there is nothing present, you will need to uninstall and reinstall the printer driver software, or download a newer version from our web site. Click here and follow the link to our Drivers & Downloads center.
It is also recommended that you connect your printer to a USB port that is hardwired or "part" of the motherboard. USB ports that are located in the front of the PC and those that are located in the expansion card slots may cause communication issues if used for printing. You should always try to use the USB slot that is located near your peripheral slots, i.e., your mouse, keyboard, parallel and serial ports.
Multiple PCs:
The printer cannot be connected to multiple PCs at the same time. This includes, but is not limited to, using both the USB and parallel ports of the printer and the use of switchboxes. The system board on the printer will get confused at multiple requests for status, even if one computer is off and the other is on.
Docking Stations:
If you are using a docking station, try using the printer with a different, standard computer with parallel equipment as a test. You may want to contact the manufacturer of your other device for information on the correct functioning of a pass-through device. If the printer does not function correctly when directly hooked to a computer, the hardware may be at fault and the printer will need to be run through the self-test.
Converters/Adapters:
Lexmark printers do not support USB/parallel adapters and will probably not work. Nor will any USB/Parallel constructed cables. Our printers require either an IEEE 1284 bi-directional parallel cable, or a USB v.1.0 or 2.0 A/B style cable. Some printers can only use the parallel cable, some can use only the USB, and some can use either one. However, Lexmark cannot support printers hooked up to computers with a cable that attempts to cross between parallel and USB platforms, as this will cause communication issues.
Software Interference:
A piece of software may be interfering with the printer's communication ability, or your computer may be experiencing a system resource problem. We can try to alleviate these issues by putting your computer into Selective Startup mode. This will prevent any software applications other than Windows from loading when the system starts. To do this:
1. Click Start, Run.
2. Type MSCONFIG on the Open line, then click OK.
3. When the System Configuration Utility opens, place the marker dot beside Selective Startup. Below that, deselect Load Startup Group Items. Then click Apply and OK. You will be prompted to restart the system.
4. When your system restarts, only the Windows operating system should be running. You should not see any icons in the lower right-hand corner of the screen, beside the clock.
5. Try your action again. If it works, the source of the problem was one (or more) of the applications that were loaded into memory.
6. You can return your system to its original configuration by clicking Start, Run, typing MSCONFIG and clicking OK. This time, select Normal Startup, click Apply and OK, and restart the computer.
Posted on Mar 15, 2008
  • 905 Answers
SOURCE: lexmark x1150 keeps going offline
unplug it for a little while
Posted on Oct 09, 2008
mdsaeed67
  • 849 Answers
SOURCE: Lexmark Z705 Printer
re-install the printer with take care of communication port,
PS. keep turn on your printer while installing
Posted on Nov 08, 2008
SOURCE: printer ot ready device is busy
i've downloaded the install disc twice, when attempting to print, i get the "busy at this time" and after troubleshooting on my own, i get a message that reads "no spooling".
Posted on Nov 20, 2008
I have the cd but can't install and icon to access the program for use does not install
It could be due to your computer's Print Spooler service not running. Go to Start menu > run > type "services.msc" (without the quotations) > hit Enter. In the Services window, scroll and look for Print Spooler. Right-click and select Properties. Set the service as shown below:
Startup type: AutomaticService status: Started
Try to run the installation software CD again.
If that doesn't help, please visit the Lexmark website to download and install the Lexmark P4350 Printer Driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation.
Feb 26, 2012 | Lexmark P4350 All-In-One InkJet Printer
Blue and yellow not printing
Just make sure you are inserting genuine Lexmark cartridges. Lexmark does not recommend the use of refilled, remanufactured or clone cartridges, you might not get the print quality you expect from ink that is specially formulated by Lexmark.
Try cleaning the cartridge nozzles using the Lexmark software installed on your computer instead:1. On your computer, go to Start menu.2. Go to Programs.3. Go to Lexmark 2600 Series folder.4. Select Lexmark Solution Center.5. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean it from dirt and possible clogs.
Should the problem continue, please contact Lexmark Technical Support Center to have your genuine cartridge replaced. They might ask for your receipt so have them ready. If you're not using genuine supplies, please replace your cartridges with original supplies.
Dec 27, 2011 | Lexmark X2670 All-In-One Printer
I have an older Lexmark X2470 printer. I just got a new computer with Windows 7 and I can't get it to work. I have installed the new drivers and it show ready to go but I can't print. When I try is...
Make sure you have the correct driver. Windows 7 comes in 32 bit and 64 bit versions. Also, you should uninstall the current driver for the printer before re-installing any other drivers.
See this link for the driver (select your system) and additional information.
http://support.lexmark.com/index?locale=en&page=product&productCode=LEXMARK_X2470&segment=SUPPORT&userlocale=EN_US&frompage=null#1
Oct 20, 2011 | Lexmark X2470 All-In-One InkJet Printer
Keeps saying printer is "offline", but still
Contact the printer customer service, they may need to install an updated driver (especially if the printer is a Lexmark).
Aug 24, 2011 | Apple MacBook Pro MB991LL/A 13.3-Inch...
Why won't my printer print after I installed the software? It says its ready but nothing will print
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 18, 2011 | Lexmark PhotoJet Z705 InkJet Printer
I have a lexmark x2350 (all-in-one,2300 Series).In the troubleshoot ,said printer status ready.But when i try print,or take a print page text,i hear:printing started,printing complete,but the machine don`t...
Try to update your printer driver. Please visit the Lexmark website at http://bit.ly/qQJd8g. Select your operating system to download the file.
If that doesn't help, follow the steps below: 1. Disconnect the printer from your computer. 2. On your computer, go to Control Panel > Printers and Faxes. Delete the Lexmark X2350 print object. 3. Reboot your pc. 4. Once the pc completely boots up, reconnect the printer into the pc. Wait until your pc fully recognizes the USB connection. 5. To ensure the print object has been successfully created automatically. Go to Control Panel > Printers and Faxes. You should see a new Lexmark X2350 print object in the list. 6. Try to print again.
Jul 28, 2011 | Lexmark X2350 All-In-One InkJet Printer
After setting as default printer Lexmark X2250 just stopped printing and showing up in printer section
Uninstall the driver , and install again.
The problem will be resolved.
Uninstall the driver: Start\Control Panel\ Programs and Features\Remove all the lexmark items there.
Mar 06, 2008 | Lexmark X2250 All-In-One InkJet Printer
Cannot print
First check your printer in printers and faxes menu if it is online.
When printing documents when you are ready to print, at the upper art of the tab choose the printer you install in your computer that is Lexmark X5300.
Jan 24, 2008 | Lexmark X2350 All-In-One InkJet Printer
27 people viewed this question
k24674
jasbo
jasbo
