Toshiba 20v300 LCD TV. How do I unlock the front panel without remote?
5 Suggested Answers
  • 5 Answers
SOURCE: magnavox tv not responding to remotes
I came accross this question, because I've been looking for the remote code for my cable remote. I had originally put the TV remote somewhere in a box when I was moving years ago, Since my cable remote changes the channel, I've been doing the same as you all this time. Therefore, I totally understand your frustration on trying to understanding how to navigate within the menu: It's not what you would think would be a standard or logical way....
Anyway, in my research, I did come accross the TV manual, and I found the instruction on how to reset the TV. I tried the steps, and THEY"RE STILL confusing, so I've added my own hints....hope this helps:
Your TV can be reset to the factory settings in case you forget your Smart Lock password, or want to change the picture, sound, or features settings.
1 Press the MENU button on the remote control to see the onscreen menu.
In the left panel, you will see four icons (from top to bottom)
  • TV INSTALL (a tv)
  • PICTURE (icon of film)
  • SOUND (a piano)
  • FEATURES (icon of pliers and a hammer)
When the Menu screen is showing the left panel as highlighted light grey, the Chanel buttons have Page up/Page down Functionality
2 Press the the (CH UP) or_(CH DN) buttons to highlight the FEATURES menu.
Navigate to the FEAUTRES menu (icon of pliers and a hammer - bottom of left panel) and you should make sure it is highlighted in blue
3 Press the (VOL+) button to enter into the FEATURES menu.
The right panel should now be highlighted in a light grey
4 Press the (CH UP) or (CH DN) buttons to highlight the FACTORY SETTINGS control.
This will select items in the right panel, FACTORY SETTINGS in on the bottom
5 Press the the _(VOL+) or _(VOL-) buttons to reset the TV to the original factory settings.
6 Press the MENU button repeatedly to clear the menu from the screen.
The entire manual is found at this link: http://www.m4c.magnavox.com/files/1/15mf200v_37/15mf200v_37_dfu_aen.pdf
BTW, of any one know how I can program or get an RCN remote to use on this TV, please let me know!!!!
Posted on Feb 26, 2009
gopakumarg43
  • 75462 Answers
SOURCE: How do I unlock the 'panel lock' of my Toshiba
Hello
To unlock the panel lock of Toshiba TV, follow this.
Press the "Menu" button on the remote control, and scroll until you come to the "Preferences" menu. Select "Parental Control and Locks," then press "OK." If your TV does not have a "Preferences" menu, go directly to the "Locks" menu.
Enter the four-digit PIN that you selected when you turned the Panel Lock feature on. You may have to scroll up or down to access this area
Press the "Up" or "Down" buttons on the remote until you reach the Panel Lock feature. Move the cursor to select "Off," and press "OK."
Posted on Mar 24, 2011
  • 121 Answers
SOURCE: lost remote want to use
On the TV itself, MENU, SET-UP, INPUT, VIDEO then go to Channel lock and de-select it.
Hope this helps. If you post a model number, I can probably get you a manual.
Good luck, R.J.
Posted on May 13, 2011
  • 360 Answers
SOURCE: I have a Metz LCD
Check electronics spare part market for remote control of your TV. Remote controls are available at nominal cost.
sonsunny
Posted on Jun 17, 2011
Can I turn on a Toshiba 32L4200U without the remote?
Yes! As you face the TV screen on the left hand side panel, the top button is the power button.......it will either turn on or to standby......if it goes to standby press one of the next 2 buttons which are the channel up and down buttons!
Oct 23, 2014 | Toshiba 32L4200U - 32in Class 31.5in...
Tip
Toshiba 42HP95 Front Panel Lock Reset
Toshiba 42HP95 Plasma TV Front Panel Lock Reset
Would you like to bypass, defeat or reset your Toshiba 42HP95 Plasma TV Front Panel Lock?
Have you forgotten your Front Panel Lock PIN, passcode or password?
If you forget your Front Panel Lock passcode, you can unlock the front panel without entering your password:
  • When your PIN is requested, simply press RECALL four times withing five seconds.
  • The Front Panel Lock passcode will be reset and you can enter a new PIN if desired.
I hope that helps.
________________________________________
Download Toshiba 42HP95 Plasma TV Manual
on Jul 03, 2010 | Televison & Video
Tip
Toshiba 50HP95 Front Panel Lock Reset
Toshiba 50HP95 Plasma TV Front Panel Lock Reset
Would you like to bypass, defeat or reset your Toshiba 50HP95 Plasma TV Front Panel Lock?
I hope that helps.
Download Toshiba 50HP95 Plasma TV Manual
I REGZA 32 lcd tv, will not work for me function.when channel and press the button on the tv, it says panel lock.what problem?
read the owner manual, the book that came with the set--it is telling you the panel or front controls for the set (maybe the remote also) are locked to prevent them being used, there will be a method to unlock them in the owner manual
Nov 04, 2012 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Toshiba LCD TV 19Av505DG how to unlock the side menu
Hello
To unlock the TV do the following:
Disconnect the AC power for at least one minute to reset the clock.
Adjust the volume to the minimum using the Volume down button on the front of the unit.
Press and hold the Volume down button on the front of the unit and the 0 button on the remote control at the same time, holding them down for at least 10 seconds.
The user menu will appear with the V-Chip cursor blinking.
Press the ENTER key on the remote control and the NEW PASSWORD menu will appear.
Enter your new password.
The V-Chip is bypassed by holding the zero key on the original remote hand unit, and at the sane time holding down the volume down on the front of the TV set. This should reset the oide so you can enter a new one.
OK.
Aug 21, 2011 | Toshiba 26AV52R LCD TV
Tip
I hope that helps.
on Jul 03, 2010 | Toshiba 42HP95 Television
Tip
I hope that helps.
on Jul 03, 2010 | Toshiba 50HP95 50 in. Plasma Television
How do I unlock the 'panel lock' of my Toshiba Regza without remote control?
Hello
Mar 24, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
How do you change picture size without the remote control
I have a 47 inch Toshiba lcd tv. I lost my remote control and am unable to change the picture size on the screen. Is there a way to change the hd settings from 480i to higher definition through my digital cable box?
Feb 28, 2010 | Toshiba 37WLT58 37 in. LCD TV
Toshiba Regza tv was in storage we took it out and can't find remote is there a way to tune without it? Thanks
Yes,must use the manual control on the tv itself.Very trouble some.Buy a new exact remote on website 1-800-Remotes Factory Original.
Jan 16, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
