Airforce air conditioner manual wap 35dih
Trying to find details for outlet hose i.e size
  • 1122 Answers
SOURCE: air conditioner won' start
does the power cord have a reset button on it? if so reset it,if that does not work cut that off and go to lowes and buy a reg. 110 volt male plug,that should do the trick,let me know what's up-mike
Posted on Jun 12, 2008
  • 148 Answers
SOURCE: Our Air Condidition is not getting cold. Have no manual
check the wiring to thermostat sounds like the reversing valve is open letting hot gases through
Posted on May 17, 2009
  • 5 Answers
SOURCE: fan is working on inside unit and also on
you are most likly short or out of refrigerent which mean you have a leak somewhere find a refirgeration mechanic.. if need be fill it with nitro to find the leak
Posted on Jun 30, 2009
SOURCE: i need parts for everstar portable air conditioner
I have lost the exaust tube and the attachment that hooks up to the back of the unit to the tube. Where can I buy these parts?
Posted on Jul 19, 2009
  • 34 Answers
SOURCE: can't find a manual for air conditioner
BTU means "British thermal units" and is a measurment of cooling and heating capacity. Other units are Kw "Kilowatts", and HP "Horse Power".
To convert
Multiply by
To obtain
kW
1.341
hp
kW
3,413
Btu/hr
hp
2,545
Btu/hr
Posted on May 21, 2010
What size hose should I use for the continuous drain operation?
1/2 inch hose , --bit of garden hose or clear plastic from the hardware shop
if 1/2" is too big measure the outlet pipe and get plastic hose to suit
May 28, 2016 | Arctic King 50 Pint Dehumidifier
Poulan Woodshark 1950 14" Chainsaw Family: WPWES
Checked all the parts lists, they seem to use the same primer through all types no.s part no. 530047213.
Jun 24, 2011 | Poulan Garden
Purchased Model # EWDW6505GS from Lowes in Tigard, Oregon today. It was the floor model and did not come with a manual for use and care (I got online) or with a drain hose. Where do I find a drain...
the drain hose for your dishwasher needs to fit the plumbing in your home. Measure the size of the connection at the drain (under the sink) and possible use the old hose as a model for what you will need. Lowes sells a hook up kit but be careful to measure the size of the outlet on bottom of the dishwasher and size and distance to the drain connection. Sometimes addaptors are used to size down the outlet side of the hose. Also if you have the manual it may show the size of the outlet on the dishwasher.
May 01, 2011 | Electrolux Microwave Ovens
Chainsaw would try to start but not run pulled it down and found the fuel hose was deteriorated. I am not sure where the fuel hose original path was and how it goes into the tank. Also is the fuel hose a...
Details vary with brand and model, but in general the fuel line goes into the tank somewhere near the carburetor and connects to the fuel filter inside the tank. The other end connects to the carburetor inlet-- usually near the upper end of the carburetor. Lower down on the carburetor, there is another port that connects with fuel line to the primer inlet port. Another line goes from the primer outlet back into the tank. Usually, one just goes to a saw service shop and buys lengths of the proper size line. Much cheaper than buying as a service part from the manufacturer. Hope this helps!
Jan 08, 2011 | Garden
My LG LD25EL has an outlet nozzle that connects to a hose. Problem is, I can't find a hose that has the right size thread width to screw on it. Any advice?
you may be able to find a male to male pipe thread brass or copper or even reg. galvinised pipe or pcpvc or pvc anything that will fit in the hole ... or if the outlet is a male find a female union you can go to the hardware and ask for the pex pipe fittings, thats prob. the first place to look they have many sized pex fittings and next what you would then do is find a flexable vinal tube larger than the outlet threads and rap the threads with teflon tape a few times. then next use a hose clamp slide the larger tube over the threads and tighten the hose clamp and check for leaks jason
Oct 01, 2010 | LG LD25EL Dehumidifier
Where can I find a drain hose for Vulcan Dishlex 550 Hydrapulse dishwasher
Contact the pneumatic dealership / hardware shops where a variety of hose sizes will be available. Take the sample size hose and measure the length required for the drain.
try this link for an universal type hose
http://cgi.ebay.com.au/Universal-2-5metre-Dishwasher-Outlet-Hose-W063B-/140229403478?pt=AU_Home_Appliances&hash=item20a652e356
Sep 14, 2010 | Dishwashers
Where can I get solid/detailed instructions for changing out the water pump on my 2001 Yukon SLE 4.8? Something that would include torque specs. and any must does and don'ts would be nice.
Escalade, Suburban, Tahoe, Yukon, Denali, DenaliXL, YukonXL 1999-2005 Water Pump - Removal & Installation 4.8L, 5.3L & 6.0L Engines
  1. Remove or disconnect the following:
    Air outlet duct Coolant Inlet radiator hose from the water pump Upper fan shroud Cooling fan and clutch assembly Drive belt Radiator outlet hose from the coolant pump Surge tank hose Heater hose Water pump
    Fig. Exploded view of the water pump assembly-4.8L, 5.3L and 6.0L engines
To install:
NOTE DO NOT use cooling system seal tabs (or similar compounds) unless otherwise instructed. The use of cooling system seal tabs (or similar compounds) may restrict coolant flow through the passages of the cooling system or the engine components. Restricted coolant flow may cause engine overheating and/or damage to the cooling system or the engine components/assembly.
  1. Install or connect the following:
    Water pump. Install the water pump bolts. Tighten the water pump bolts first pass to 11 ft. lbs. (15 Nm); tighten the bolts final pass to 22 ft. lbs. (30 Nm). Water pump drive belt pulley and bolts (if applicable). Tighten the pulley bolts first pass to 89 inch lbs. (10 Nm); tighten the bolts final pass to 18 ft. lbs. (25 Nm). Surge tank hose Heater hose Outlet radiator hose to the coolant pump Drive belt Cooling fan and clutch assembly Upper fan shroud Inlet radiator hose to the water pump Air inlet duct Coolant
    Air inlet and outlet duct Coolant Inlet radiator hose from the water pump Upper fan shroud Cooling fan and clutch assembly Drive belt Radiator outlet hose from the coolant pump Surge tank hose Heater hose Water pump
To install:
    Water pump. Install the water pump bolts. Tighten the bolts to 11 ft. lbs. (15 Nm) for the first pass; then tighten to 22 ft. lbs. (30 Nm) for the final pass. Water pump drive belt pulley and bolts (if applicable). Tighten the bolts to 89 inch lbs. (10 Nm) for the first pass; then tighten to 18 ft. lbs. (25 Nm) for the final pass. Surge tank hose Heater hose Outlet radiator hose to the coolant pump Drive belt Cooling fan and clutch assembly Upper fan shroud Inlet radiator hose to the water pump Air inlet and outlet duct Coolant
Hope this help to solve it (remember comment and rated this).
Apr 26, 2010 | 2001 GMC Yukon
How to replace a water pump on a 2003 yukon
Water Pump Replacement (4.8L, 5.3L and 6.0L Engines)
Removal Procedure
1. Drain the cooling system.
2. Loosen the air cleaner outlet duct clamps at these locations:
 Throttle body
 Mass Airflow/Intake Air Temperature (MAF/IAT) sensor
3. Remove the radiator inlet hose clip from the outlet duct.
4. Remove the air cleaner outlet duct.
5. If necessary, remove the engine sight shield.
6. Remove the radiator vent inlet hose from the radiator hose clips.
7. Reposition the inlet hose clamp at the water pump.
8. Remove the inlet hose from the water pump.
9. Remove the fan blade.
11. Reposition the outlet hose clamp at the water pump.
12. Remove the outlet hose from the water pump.
13. Reposition the surge tank outlet hose clamp at the water pump.
14. Remove the surge tank outlet hose from the water pump.
15. Reposition the heater inlet hose clamp at the water pump.
16. Remove the heater inlet hose from the water pump.
17. Remove the water pump bolts.
18. Remove the water pump and gaskets.
19. Discard the water pump gaskets
Installation Procedure Important: All gaskets surfaces are to be free of oil or other foreign material
during assembly.
1. Install the water pump and NEW gaskets
2. Install the water pump bolts.
3. Install the heater inlet hose to the water pump.
Zoom Sized for Print
Notice: Refer to Fastener Notice in Service and Precautions.
2.1. Tighten the bolts a first pass to 15 Nm (11 ft. lbs.).
2.2. Tighten the bolts a final pass to 30 Nm (22 ft. lbs.).
4. Position the heater inlet hose clamp at the water pump.
5. Install the surge tank outlet hose to the water pump.
6. Position the surge tank outlet hose clamp at the water pump.
7. Install the outlet hose to the water pump.
8. Position the outlet hose clamp at the water pump.
9. Install the accessory drive belt.
10. Install the fan blade.
11. Install the inlet hose to the water pump.
12. Position the inlet hose clamp at the water pump.
13. Install the engine vent inlet hose to the radiator hose clips.
14. If necessary, install the engine sight shield.
Important: Align the arrow at the throttle body end of the duct with the throttle
body attaching stud.
15. Install the air cleaner outlet duct
16. Install the radiator inlet hose clip to the outlet duct.
17. Tighten the air cleaner outlet duct clamps at these locations:
 Throttle body
 MAF/IAT sensor Tighten the clamps to 7 Nm (62 inch lbs.).
18. Fill the cooling system.
I hope this helps. The numbering is incorrect in the sequence but the instructions are correct.
Roy
Nov 06, 2009 | 2003 GMC Yukon
Exhaust Hose
No, they have different fittings.
Aug 25, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Heating & Cooling Logo
155 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
