Question about Epson Stylus C46 InkJet Printer
No hardware installation
I have a USB cable with the printer when I put it in the computer detects the new hardware but it always says there was a problem installing the hardware insert a floppy or cd, but i never got one with the printer...
  • middhat Sep 21, 2008
    same problem as safeena, and because the printer i have got is quite old its not listed on the epson printers listed on the computer.
    Brigadier General:
  • 6,966 Answers
Hi, You can download the driver/installer for your printer from http://esupport.epson-europe.com/SupportHome.aspx?lng=en-GB&data=0ccCGROWIYM58zV3pqc84W2LhUcmWnHiUk31CNK52sUU003D The driver is OS specific. Hope this be of help. Post back should you need additional information. Good luck and kind regards.
Posted on Aug 29, 2007
    President:
  • 1,114 Answers
You can download the software & drivers from the link below: http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=dkmEK02SU002Fer6qudElZT5RHsMyD4iBT1M&tc=6#7 You can also use the troubleshooting guide on this page: http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=dkmEK02SU002Fer6qudElZT5RHsMyD4iBT1M Try & install with this driver and let us know how it goes. Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE:
HI , i couldn't install my printer , after software installation the driver ask me to plug the usb cable but unfortunatelly , the device is uknown even if the usb port work properly and the usb...
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . If not detected please contact service.
Thank you for using Fixya
Aug 09, 2011 | Office Equipment & Supplies
How to install canon lbp-800 using parallel to usb convertor
Connect the printer to your system using the USB cable, power on the printer the power on your computer. when the computer is fully booted and you login, the system should automatically detect the printer as a new hardware. Insert the CD that came with the printer into your systems CD-ROM drive and install the printer driver following the instruction on the screen.
Sep 17, 2010 | Canon LBP 800 Laser Printer
DOES ANYONE KNOWS HOW TO SOLVE MY PROBLEM?HERE IT IS..IT ALWAYS OFFLINE MY PRINTER EVERYTIME i print it,he goes offline and the print is unabale to print can anyone help me?to fix..thank you. im using HP...
when you hook up your printer to your pc via USB...can the computer detect your printer? does it prompt out any msg such as new device is installed and ready to use or did it ask you to install the printer driver?
if your pc can't detect your printer, replace the USB cable and try again.. and try to plug into a different USB port on your pc.. and if all fails, then most probably your printer main board is faulty...
May 28, 2010 | HP DeskJet F380 All-In-One Printer
I have a samsung printer ML1210.I have installed the driver that came with it but every time i reboot the computer or switch the printer on a bubble pops up in the corner saying new hardware detected it...
you may want to try switch to a next usb port or replace the usb cable. it just seems more like your pc is not getting the correct reading from the usb connection.
try to reinstall the driver again once you swap the usb cable to other port.
test by switching your printer on and off again to see if the same error pop up saying new hardware detected. if it does happen again. uninstall the driver & download it from www.samsung.com
May 19, 2010 | Samsung ML 1210 Laser Printer
Printer is not detected by the computer after connecting the printer to the computer.I have installed the printer driver but still there is no respond from either the computer or the copier
Please change the USB cable and plug it to another USB Port on your computer and restart the computer.
Make sure that printer is ON while re-starting computer.
Mar 21, 2010 | Toshiba E-Studio 160 All-In-One Laser...
Cannot print from computer. printer will print test pages, though
How the printer is connected to PC Via USB or using Network Cable. If it is connected Netwrok cable than printer configuration page and on netwrok configuration there will be IP Address if this is valid IP Address than reinstall drivers and upgrade the Firmware of the printer.
If Printer is connected USB than try different USB Cable and try different USB Port on the computer
If USB port on the computer is working fine and check in Device Manager if the printer has detected as unknown device or not detected at all.
If detected as unknown device than reinstall printer driver if not detected at all than USB Port on the printer is faulty you need to set up hardware repair of the printer.
Oct 16, 2009 | HP Color LaserJet 3500 Printer
How to connect my printer to computer
Connect the usb cable at the back of tower and turn on printer.. If printer software and driver is not installed than insert the disc and install it.
Oct 10, 2009 | Epson Printer
Computer won't recognize printer
Try each of the USB ports on your computer.
Assuming that you have a USB-cable between the computer and the printer, unplug the USB-cable from the computer, and connect some other USB device (iPod or memory-stick). Does Windows detect that other device? If not, then you need to install the correct software device-drivers for your USB ports.
Is the printer properly detected when connected to some other laptop/desktop computer?
Sep 18, 2009 | Lexmark X1270 All-In-One InkJet Printer
MFC-8669DN FAILURE
Did you check after installing the printer that you have the printer in 'installed printers' in 'control panel'?
Your printer may have been there, but not set as default printer.
Did you also notice a message popping up first time you connected the printer to usb saying new hardware detected?
Try to install and connect the printer on a different computer ( a laptop will be fine), intalling software first as usual.
If it works is either usb channels on original computer or a windows problem.
If Windows does not see the device when you connect usb (ensure cable is ok) to different computer, and you are sure you are doing everything ok, then it is probably usb printer socket that is faulty.
If Windows see that there is a new device detected, but it cannot install printer, even after doing disk setup procedure fine, then there is an issue either with the printer or with the drivers you are using (they may be for a different operative system for example).
An hardware problem of this kind is rather unfrequent, particularly on a new printer. Check that you are doing everything fine, that the printer is not in installed printer, even if not default one, and that you are using the right setup disk, and that this is performing the whole setup procedure.
Regards
Mar 29, 2008 | Brother MFC-8660DN 5-in-1 Laser...
Epson Stylus C46 InkJet Printer Logo
108 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
