Question about Canon PC150 Personal Copier (PC 150, PC-150) Printer
Canon pc150 disassembly
How do i disassemble canon pc150 copier, keeping a grinding noise.
SOURCE: Disassembly instructions for Canon printer model i860
The are two slots on each side of the printer. Insert a flat blade screwdriver and push. It should release the catch. Do it for both sides of the printer. You may also have to ubscrew the two (2) screws that hold the unit that holds on/off paper switches.
Do your work and then press top unit down and it will rengage with the catches.
I have 3 units and one won't return the ink carridge to the center position to replace ink cart. So I remove top replace carts and all is well.
Works for me!
Jerry
catco@sbcglobal.net
Posted on May 04, 2008
checkitright
  • 1362 Answers
SOURCE: Canon copier PC 420 making grinding noise during copying cycles
only two possibilities
1- fuser
2-gear stripped most likely with the scanning part
Posted on Oct 15, 2008
SHOGUN125
  • 58 Answers
SOURCE: Canon IR3100 CN making grinding noise
hi..there...you may visit canon website at internet..chose product support/dowlnload----find your product here and finally you can get and download manual book as pdf for free....good luck..
Posted on Feb 03, 2009
  • 1602 Answers
SOURCE: darker copies
GO ON LINE AND TYPE THE FOLLOWING INFORMATION.
CANON PC-150 GRAYSCALE COPIER SERVICE MANUAL AND DRIVERS
OR
CANON PC150 COPIER DRIVERS SERVICE GUIDE
CANONUSA.COM
IF A USERS GROUP FOR CANON FORUM
TRY TYPEING THE FOLLOWING:
CANON PRINTER USERS GROUP FORUM
ENTER
PICK FROM THE BEST OF WHAT YOU NEED IF ANYTHING.
ROD
Posted on Feb 09, 2009
domotek
  • 591 Answers
SOURCE: CANON COPIER PC150 IS MAKING NOISES THAT SOUND
sounds like a worn fuser drive gear you need to replace the gear by a good tech. (NOT A DIY JOB)
Posted on Jan 03, 2011
My Dell 2135cn printer all the sudden started making crazy loud grinding noises. Then I got a paper jam. I fixed the paper jam and tried to print again, but got the loud grinding noises and paper jam...
Refer to the service manual in disassembling the device.. Clean it thoroughly then try it again.. If, you have no experience in doing so, hire a qualified tech to do so.
Jun 17, 2011 | Dell 2135cn All-In-One Laser Printer
Doesn't want to keep running and some grinding noise when startin
From what you describe I would suspect that the starter is not fully engaging. I'm assuming that the grinding noise you hear when you try to engage the starter is INSTEAD of the engine cranking. If I assumed wrong, ignore the following:
Pull the starter, check the flywheel for excessively worn areas. Most of the time the flywheel is ok, it's just the starter. Any time you disassemble a starter you should replace the bushings and brushes. Never remove the starter with the battery still connected. Remove the negative terminal from the battery before you attempt to remove the starter.
Jun 06, 2010 | 1986 Jeep Cherokee
Loud grinding noise and doesn't take paper.
sounds like the shaft has slipped off the bearing end support.
disassemble and make sure end plates/bearings and shafts are in proper position, and try again
Mar 31, 2010 | Office Depot Ativa DQ60M Shredder
I need a technical manual for a Canon Copier PC720
Scroll Down put in the 4 digit code, click download
http://www.devicemanuals.com/guide/Copier/Canon/Canon-Personal-Copier-PC720-User-Guide-TkRBNU9UYz.html
Oct 20, 2009 | Canon PC150 Personal Copier (PC 150,...
Loud noise
Check for bones/glass/ceramic from chipped plates in the food chopper (for lack of a better term). You'll need to disassemble the entire lower arm unit.
Sep 06, 2009 | Maytag 24 in. MDB7600A Jetclean® II...
Darker copies
OR
CANONUSA.COM
ENTER
ROD
Feb 09, 2009 | Canon PC-150 Grayscale Copier
Maytag pye2300ay dryer grinding noise from front
You generally have to open up the cabinet from the back by unscrewing the fasteners.
Feb 06, 2009 | Maytag PYE2300AY Electric Dryer
How to disassemble printer
hi milo
just seen this post have you tried the help / support from canon here Canon PIXMA MP210
riz.
May 28, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Problem with canon pc150
Change  drum or fuser.
Take out drum is there a black ring on the sides? change
take out fuser is it worn on the sides? change.
Oct 29, 2007 | Office Equipment & Supplies
Canon PC150 Personal Copier (PC 150, PC-150) Printer Logo
15 people viewed this question
old marine
old marine
