Question about EliteGroup K7SEM Motherboard
Upgrading processor (K7SEM v3.0 Motherboard)
I recently performed a BIOS upgrade (new chip) and planned to install an Athlon XP 2600+ processor, which the v3.0 mobo is supposed to support. The problem is, the present AMD Duron processor (1GB clock speed) appears to be permanently attached (soldered??) to the board, and the heatsink can't be removed after the hold down clip is released. There is no socket and locking lever visible underneath the heatsink. All of the pictures I've seen on the Internet clearly show the socket (A/462). The edges of the socket should be visible even with the processor installed. On my board, the heatsink overlaps the processor, and even using a bright light and a mirror, the socket isn't visible underneath the heatsink. While browsing other forums, I read a posting that said the K7SEM v3.0 board and processor must be replaced as an assembly since the processor can't be removed. Yet other forums list various processors which the very same board will support. The company that supplied my BIOS upgrade chip (eSupport) also stated the upgrade would allow support for faster processors. What's the deal?? If I have to replace the mobo to use a faster processor, can you suggest one that will bolt right in and utilize my present power supply (namely the power connection to the board), IDE cables, current SDRAM, etc.
  • Cobracon Aug 30, 2007
    I came up with my own solution. DON'T use FixYa to look for help, DO use CPU World. Thanks anyway............
  • 21 Answers
Unfortunately, you have not provided any details regarding current specs (PSU, type of SDRAM, etc.) to enable anyone to suggest a replacement motherboard. For freeform discussion, I would agree that FixYa is probably not the best medium, e.g. in discussing potential replacements. Rather, if you have a specific question which has a specific answer, then this site would be better suited to your needs. As to your original question, the best answer I can offer (personally) is that if your CPU is soldered to the board, you should complain to the vendor who sold it that way (that's crap), and replace the board with something suitable (provide more details). If there's a belief it may not be soldered, the heatsink is probably attached via thermal paste, and is going to be a PITA to remove. Sometimes it will pull off with some force, though on at least one occasion, the solder joints beneath the socket gave before the thermal paste did, causing the heatsink, CPU, and socket to all come off the motherboard.
Posted on Oct 02, 2007
6ya staff
SOURCE:
Like to replace my processor which is AMD Duron 900MHz to Motherboard Gigabyte 7VM333M-RZ. Which current processors are compatible with this board? Please advise. I want a current fast processor.
Hi, As far as I can see, this motherboard is very old, and the faster processor you could get would be around 1.8 ghz, single core. Here's the list of supported processors:
http://www.cpu-upgrade.com/mb-Gigabyte/7VM333M-RZ.html
What I would suggest is that you buy a motherboard/cpu combo, then you could get a quad core with a recent motherboard for less than 150-200$. Of course you'd have to be willing to change your motherboard, but unfortunately, you're not gonna get a good processor with your current motherboard, and computer parts (like Ram, hard drives, video cards) are going to cost more and more for their rarety, while they are less performant.
Best of luck to you!
Mar 14, 2011 | Computers & Internet
What is the upgrade cpu for this motherboard
The following processor are currently supported by this mainboard.
Athlon XP: 1500+ up to 2000+; FSB: 266 MHz
Athlon: 650 MHz up to1.4 GHz, FSB: 200 MHz or 266 MHz. Socket A CPU. See page 10 in you're manual (If you still have one). After going to Elitegroup and checking for the latest bios version;
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=67&CategoryID=1&MenuID=50&LanID=9
BIOS for K7VMM(PCB:1.2A). Release date, 2003/03/28
The MB will support, AMD Athlon XP 2400+ and 2600+ CPU If you're bios is flashed to the above. You can buy and use this CPU; http://www.sjkksales.com/servlet/the-461/AMD-ATHLON-MP-2600/Detail
Never flashed a bios? Instruction are listed on ECS web site.
Mike
Jun 13, 2010 | VIA ECS K7VMM+ KM266 Chipset Ultra ATA 100...
Changing processor results in windows xp pro failing to install
I'd try upgrading the bios with the working cpu and then try again.
Let me know what happens. I like the weird ones like this.
Feb 26, 2009 | Abit KT7A Motherboard
What max speed processor i can use in my elitegroup k7sem motherb
Your manual says:
Accommodates AMD Athlon Duron, Athlon, and Athlon XP processors.
If you would like to see a fulll list, go to this site:
http://forums.techguy.org/hardware/494450-max-cpu-ecs-k7sem-motherboard.html
Hope this helps.
Dec 09, 2008 | EliteGroup K7SEM Motherboard
Upgrading processor
Sorry, the Motherboard is made by Micro-Star International Co., Ltd.
Model: MS-6734
Chipset: VIA KM400
Southbridge: VIA VT8235
LPCIO: Winbond VV83697HF
Hope this is what you need
May 27, 2008 | Computers & Internet
Pc upgrade !
IAN.S
Where you need to be is on Asus web site. Your board can handle ONLY; Athlon XP 3200+(400 MHz FSB)(Model 10)(Barton), AXDA3200BOX
With that CPU you must also have bios version 1004.
Check PCB and BIOS versions before flashing BIOS!
asus A7N8X supported CPU click here; http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=A7N8X
Since you seem to need your manual. Click the link:
http://dlsvr01.asus.com/pub/ASUS/mb/socka/nforce2/a7n8x/e1859_a7n8x.pdf
You do not have an intergrated video card. You have a 1.5v 8x
AGP video slot.
I suggest you call Asus & make sure your CPU model AXDA3200DKV4E will be supported over model AXDA3200BOX.
You can call Asus tech M-F EST at 812-282-2787.
Good luck & Have a great day!
Mar 16, 2008 | ASUS A7V8X Motherboard
PROCESSOR
Unless you can upgrade your bios chip, you can only go to
(Socket 462) AMD® Athlon/Athlon XP/Duron processor up to 2000+MHz.
If you upgrade your bios to version 1.1
You can run the XP 2200+ , Socket A.
Dec 19, 2007 | MSI 745 Ultra (MS-6561-010) Motherboard
Issues in Upgrading BIOS
Actually, your motherboard is a GA-7ZMMH, which we were lucky enough to see in the BIOS ID string. You can find the latest BIOS's from Gigabyte's website at: http://www.giga-byte.com/Support/Motherboard/BIOS_Model.aspx?ProductID=1315 It looks like you're on the F5 rev. I would suggest the F10 rev, and only go to the F11b rev if you need the support for the Athlon XP 2600+. If you are not upgrading your BIOS for CPU support, or you do not need to support a CPU faster than the Athlon XP 2200+, then go with the F10 rev.
Sep 03, 2007 | MSI AMD ATHLON-64 939 PIN MOTHER BOARD...
EliteGroup K7SEM Motherboard Logo
542 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Ekse
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
