Question about Electrical Supplies
Kohler 3cms21 gen manual - Electrical Supplies
Gen set blows fuse
no
a fuse is there to protect the circuit and the genset
check why the de-icer is pulling so many amps as the problem may be in that unit
a 10 amp outlet has a maximum current capacity of 10 amps as that is the current allowable from the gen set and wire capacity
even if you had an outlet with 15 amp rating , it would still be blowing fuses as the 16 amps is above the allowable current draw
you would need a 20 amp outlet ( difficult to get unless it is in a house power board and are normally reserved for hot water systems , stoves and other high current usage units and are normally then not outlets but hard wired in to a circuit breaker
Aug 10, 2016 | Kohler Electrical Supplies
How do you seperate a kohler motor from generator on a miller welder?
if by asking this im assuming the generator is face bolted to motor , if this is so , to save from having another front bearing , the gen stator is directed attached to motor shaft , on the far end under end bell cover is the end of shaft , a long bolt goes thru gen shaft to screw into motor shaft , MARK/photograph all the wires you unhook helps a lot when puting back together
Aug 05, 2014 | Kohler Replacement Engine Part Pa-64711...
GEN SET WILL NOT START /MAIN POWER OVERLOAD
I have a Generator Kohler Res14 and its not crancking, and error of invald shutdown
Jul 30, 2013 | Kohler 20resa 20kw Home Emergency Backup...
Kohler gen starts runs 3 or 5 to 6 seconds then stops. its a 4000 R. V. mycro
Check oil and pressure switch, then stator for AC output, rinhs and brushes.
Feb 15, 2013 | Kohler Electrical Supplies
Kohler RXT won,t start Kohler 20resa
Did you check the remote terminals and relay in the ATS, disconnect gen remote wires, kill the ATS brealer and ohm across the start terminals, they should close, if not a relay/control board issue, if they do fault is in wiring or gen control, or incorrect wiring
Jan 03, 2013 | Kohler RXT-JFNC-0200A-QS 200 Amp...
Kohler 10 runs only while holding start
Oil pressure, or no AC output from the stator, check stator and rotor for resisitances and shorts.
Nov 18, 2012 | Kohler Electrical Supplies
Kohler generator drains battery while running and then shuts down with error code oc
The rpm sensing in the control module is missing or bad.
Answer these questions for more details:
  1. Does your generator output normal voltage?
  2. Is the starter turning after the Gen is running?
  3. Is the charging of the battery connected?
Jun 20, 2010 | Kohler Electrical Supplies
UU undervoltage kohler 20kva
call koler but ui think is meant high heat as in the thermal circut is shuting you down or low oil
could be a couple of things best bet call kohler
Aug 06, 2009 | Kohler 12 kW Emergency Power System -...
Electrical Supplies Logo
41 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
