Question about KitchenAid KHMS145KSS Microwave Oven
Dimensions for kitchenaid KHMS 145 - KitchenAid KHMS145KSS Microwave Oven
2 Suggested Answers
  • 794 Answers
SOURCE: KitchenAid KHMS 2050 SSS, doesn't
Hi asoleyma,
This error code F7 from a Ktchenaid oven means that the function key is stuck on ERC. This can be fixed by having the control board (also called ERC or clock) be replaced.You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model number ready when you call.
Hope this helps.
Thank you for using FixYa.
Posted on Jun 09, 2011
KitchenAid KHMS 2050 SSS, doesn't heat up and indicates "Error Code F7, VH SMPS feedback, call for service"
Hi asoleyma,
Hope this helps.
Jan 30, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Model KHMS 145J Is giving a code -F3H- when you try any sensor features.
You have a failed humidity sensor.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
It will be
KHMS145JBL0, KHMS145JBS0, KHMS145JBT0, or KHMS145JWH0.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Jan 27, 2011 | KitchenAid KHMS145J Microwave Oven
Lightbulb burned out for microwave model # KHMS 1850SSS-0 Kitchen Aid Where can I purchase a replacement? Thank you, Carrie
Most home improvement stores and even some Walmarts/Chain grocery stores/Ace Hardware carry replacements. You will need to remove the cover from the microwave oven on most models unless your bulb is inside a protective cover inside the actual oven. Take the bulb with you when you go to make certain of a proper match. Be certain to unplug the oven if you need to remove the cover in any case.
Oct 13, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
Kitchen aid microwave model# khms 147 hss-1 runs but doesnt heat
Your problem is your mag tube (Magnatron) you can go to www.partsselect.com and your part number is PS2352604. Their price is $123.44. I work on micro waves myself and have found that if one isn't a built in over the stove like yours, they are not worth repairing because you can buy one cheaper. If this unit is not real old and you can replace this parts yourself it might be worth fixing bit if you are going to have it repaired, it might be cheaper to replace it. Good luck.
P.S. If you open this unit up. Make sure you bleed the capacitor off, this is one that will knock the _ _ _ out of you if you ground it by touching it. Bleed it by using screw driver to short capacitor to ground or case.
Please rate this solution
Sep 03, 2009 | KitchenAid Microwave Ovens
My Kitchenaid KHMS 155LSS-4 makes a clicking noise upon starting for about three seconds, then will act like its heating but will not heat. The noise repeats itself every 20 seconds. It did this when I...
Is there any fault code displayed on the display, such as F6?
I would first suggest checking the door switches and mounts.
If they are good, I would suspect the control board. We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jun 21, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave no power
How can you take the fuse out on this model KHMS 155LSS-4 of kitchenaid
Jan 06, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
KHMS 147KWH-0 TURNTABLE DOESN'T WORK
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can download Kitchenaid / Maytag / Whirlpool owner's manuals and installation instructions here.
Nov 20, 2008 | KitchenAid Microwave Ovens
Oven dont warm food
Kitchenaid KHMS 147 HBL-1 unit does not heat. All other functions are working and it worked this morning but as of this evening it will not heat. I was thinking the fuse but would like some advice
Oct 09, 2008 | GE Microwave Ovens
NO POWER
I have answered this is via e-mail.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 23, 2008 | KitchenAid KHMS155L Microwave Oven
KitchenAid KHMS145KSS Microwave Oven Logo
79 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
