Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Craftsman lawn tractor 11hp 36" cut model #944.615381
When depressing clutch & engaging into first forward gear machine will not move
  • 79 Answers
SOURCE: Craftsman DGS 6500 garden tractor won't engage
Hi
There is a pin in the back by the hitch - make sure it is pushed in. If it is pushed in then check to see if there are any oil leaks under it.
Posted on Apr 10, 2009
  • 376 Answers
SOURCE: gear of starter motor won't engage in flywheel to run the tractor
Look under 'My Profile' (Longhorn294 in the top right corner of this page)on page 5 at this post and solution. "craftsman riding mower starter will spin but not engage". Dwain
Posted on Jun 08, 2009
panilling9
  • 284 Answers
SOURCE: craftsman model 917.272950 lawn tractor won't start
OPERATOR PRESENCE SYSTEM
Be sure operator presence and interlock
systems are working properly, If your
tractor does not function as described,
repair the problem immediately.
• The engine should not start unless the
clutch/brake pedal is fully depressed
and attachement clutch control is in the
disengaged position.
• When the engine is running, any
attempt by the operator to leave the
seat without first setting the parking
brake should shut off the engine.
• When the engine is running and the
attachment clutch is engaged, any
seat should shut off the engine.
• The attachment clutch should never
operate unless the operator is in the
seat.
Check your seat switch and clutch switch wires be sure that the connection to each switch is making contact and the mechanism that activates the switch is actually activateing them in other words be sure the clutch is pushing the switch in and your seat switch is occupied and be sure all grounding wires a intack
especially from your battery negative to the frame.You also could have a neutral safety switch which requires your transmission to be in neural.
try these things and let us know how we can further help from more of your input.
SOURCE: Loss of drive in a Craftsman Lawn tractor
I also have a Craftsman tractor with the same problem. Sears repairman said it needed a new transmission and it would cost $1,400 to install. A new one is about $1,000. Anyway, if you remove the battery and the battery tray under the seat it will expose the transmission fill hole (hex). I opened the top and it looked empty. I had a bottle of 90 weight gear oil in my shop and filled the transmission to the top. I have not had any problems with it since. $4.00 bottle of oil verses a new tractor is worth a try.
Posted on Nov 30, 2009
  • 146 Answers
SOURCE: starter gear doesn't move up to engage flywheel gear when started
The solenoid does two things -- it closes an electrical contact to run the starter motor, and also pulls a lever to slide the motor gear up to engage the flywheel. Since the contact is closing, the solenoid itself must be OK, but the lever could be broken, or the sliding gear could be binding or stripped. Since you're looking at a probable replacement, try cleaning with compressed air, then squirting some WD-40 into the starter gear area - you could get lucky! Otherwise, you can replace the starter/solenoid assembly -- you can find replacements on eBay for about $80. Less expensive but more time consuming is to remove the assembly, disassemble, and replace just the defective parts if you can find them. Good luck! Please rate my answer if helpful, thanks.
Posted on Jul 15, 2010
How do I know when my clutch needs replacing
Hello Joseph....you will feel the clutch slipping. As your driving along at a low speed ...accelerate quickly...If the RPM's go up faster than the vehicles moves forward...your clutch is slipping and needs further attention. A clutch will also produce a rather strong odor when it slips as it will generate a lot of heat.
If your vehicle starts and will not move forward at all....make sure the vehicle moves. While not running, in neutral..push it a few feet...should glide easily...if it doesn't find the wheel(s) that are binding...Is the emergency brake applied or jammed? Are one of the vehicles brakes jammed? If everything is turning smoothly and the engine starts and allows you to depress the clutch pedal and select a gear without a grinding noise... but will not move the vehicle forward, make sure the clutch is actually engaging by observing the linkage and clutch arm.
May 07, 2016 | Cars & Trucks
The clutchpedal seems to work but does not engage and the fluid level reamains full
It is still a bit unclear what is going on here, when you say it seems to work, do you mean the clutch disengages? Can you change gears OK with the engine running and the clutch depressed?
When you say it does not engage the plate, do you mean the vehicle does not move? To change gears it must DISengage the plate, not the other way round.
Sorry if I seem picky, but I'm trying to get it all straight. If you can change gears OK with the engine running and the clutch depressed, but the vehicle does not move when you let the clutch pedal up, then the clutch is possibly worn out and needs replacing.
If the opposite and you cannot get it into gear with the clutch depressed, then the clutch throwout fork has possibly broken, which is not uncommon. Alternatively but less likely is that there is so much air in the clutch hydraulic line that it has become ineffective.
Apr 06, 2016 | 1990 Ford F150
I had a new clutch a year ago. a month ago a new clutch master cylinder was fitted.
Check the fluid in trans it might be bad could also be through out bearing
Oct 13, 2015 | Cars & Trucks
Why would a vehicle in reverse move forward
The question is a little vague but I think I know what your referring to. All modern automatic transmissions have torque converters. This is the device that connects the engine to the transmission. All vehicle manufacturers like the trans to be nice and smooth shifting. That's great but it does come with some minor drawbacks. If you are facing slightly down hill and you put your car in reverse but do not step on the gas slightly I can guarantee that you will indeed roll forward. You can eliminate that issue by holding your left foot on the brake while you shift into reverse. Then, as soon as you feel the trans engage, gently depress the gas pedal with your right foot and it will eliminate that forward roll problem.
Sep 25, 2014 | Cars & Trucks
Noise when shifting gears
transmission synchronizers most common cause of transmisson noise in certain gears, and not others, might want to check the gear oil level. Transmission rebuild required. To read about them and what they actually do, then here is a good read:
When you shift gears in your standard shift car, you move a rod that moves a fork that engages the gear. Depending which gear you're shifting to, a different fork does the job. The fork moves the collar to the desired gear, and dog teeth on the collar mesh up with holes on the gear in order to engage it. You engage reverse gear through a separate, small idler gear. The reverse gear always turns in the opposite direction of the other (forward) gears.
In years past, double-clutching was common in order to disengage a gear, allow the collar and next gear to reach the same speed, and then to engage the new gear. To double-clutch shift, you pushed the clutch pedal to free the engine from the transmission. Then the collar moved into neutral. You released the clutch and revved the engine to get it to the right rpm value for the next gear so the collar and the next gear spun at the same rate to allow the dog teeth to engage the gear. When the engine hit the right speed, you depressed the clutch again in order to lock the collar into place on the next gear.
Modern cars use synchronizers in order to avoid the need for double-clutching. A synchronizer, or "synchro," lets the collar and gear synchronize their speeds while they're already in contact but before the dog teeth engage. Each manufacturer's synchro is slightly different than the others, but the basic idea is the same. For instance, a cone on one gear will fit into a cone-shaped depression on the collar. The gear and collar synchronize their speeds thanks to the friction between the cone and collar. Then the outer part of the collar moves out of the way so that the gear can be engaged by the dog teeth.
Dec 16, 2013 | Chevrolet Silverado 2500HD Cars & Trucks
Transmission will not engage.
The transmission belt is probably loose or the clutch is faulty.
Apr 29, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
It starts but as soon as you turn on the blade or put it in gear it kills the engine
Keep your clutch pedal depressed when you engage blade3 or put in gear.Good Luck!
Aug 14, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine stops
Hello
Have a look at the saftey switches.theres one under the seat.and one under the blade engage lever.
There may also be one under the hood near the fuel tank.
May 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My craftsman lawn tractor 42" cut (2007 model) cuts off when i try to engage the cutting blades
You have a safety switch somewhere that is open, like the seat, you have to be in the seat or it will kill the engine, sometimes the clutch has to be in, not moving, sometimes the gear selector in neutral, You have a bunch of safety switches that prevent the mower from spinning if you are not in your seat, not ready, etc. Check them out. Hope this helps.
Apr 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
35 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
