Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I need a wiring diagram for a Liftmaster 1245R GARAGE DOOR OPENER
  • 11 Answers
SOURCE: Sears Craftsman Garage Door Opener Wireless Keypad Model and a LiftMaster Chamberlain Professional Garage Door
I had the same frustrating dilemma with my Craftsman LiftMaster garage door and Keypad, Model 139.53754-01 (dated 10/06; and has the # 315 MHz).
To resolve “the dilemma”, grab your keypad, climb up on a ladder to access the garage door opener’s motor unit. On the right side of the motor unit, remove the white plastic casing by pressing buttons on each side and pulling down. This will expose the programming area, and for our purposes, the “Learn” button.
1. On the motor unit, press and release the “Learn” button. The Learn indicator light will glow steadily for 30 seconds.
2. Within 30 seconds, enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold the ENTER button.
3. Release the ENTER button when the motor unit lights blink. The code has been “learned”/stored/activated.
Good Luck, and I Hope this Helps!
Gail
For possible future reference:
How to change an existing, known PIN
(Changing an existing PIN can be done with the wireless remote keypad, and does not require access of the motor unit.)
From the keypad:
1. Enter the four digits of the present PIN, then press and hold the # button. The opener light will blink twice. Release the # button.
2. Enter your new 4-digit PIN and press Enter. The motor unit lights will blink once when the PIN has been “learned”/stored/activated. Test by entering the new PIN, and pressing Enter.
Posted on Jun 24, 2008
SOURCE: Chamberlain Liftmaster Professional 1/2 HP
Okay...upon further inspection, my left spring has broken in two. Going to call around for some quotes to replace the spring. Thanks for the suggestions.
Posted on Jul 25, 2008
SOURCE: Replace liftmaster 1245R drive/worm gear
I have a 1265 and took the cover off (unplug first).
There are screws securing the cover: 2 on each side at top, 2 at either end bottom.
Then I disconnected the chain.
There are 3 hex head screws securing the drive gear assembly (of course they thread from the inside out which makes taking them out a bit time consuming). Take care not to damage the circuit board or other electronic connections.
Then at the bottom of the shaft is the "limit switch assembly" that is clipped into the metal housing. Squeeze the 2 on the outside and it should swing free.
Then at the very end of the shaft there is another plastic gear. It is secured by a 3 prong plastic clip. Pull the outside clips away from the shaft while pushing the center piece back through the shaft. The gear should come off and you can now remove the gear and sprocket assembly up through the assembly.
call 800 528 2817 and order the "Gear and Sprocket Assembly".
I am waiting for the part and assume we reverse the order above to reinstall.
Posted on Dec 26, 2008
  • 3197 Answers
SOURCE: I have LiftMaster garage door model 41A3039 and
To program the keypad, first unplug the garage door opener from the electrical outlet. Next remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Posted on Jul 13, 2009
  • 3197 Answers
SOURCE: my garage door opener (liftmaster 1265) buzzes
Remove the cover from the motor unit and check the drive gear. It is white nylon and is just in front of the motor. Most likely stripped.
Posted on Apr 05, 2010
Testimonial: "Don0930 - Yes, gear is stripped. Will be purchasing replacement gear instead of new unit. Thx!"
All my door openers r craftsmans with the orange smart buttons at the sears store they sold me one that on the package will work with green or gray does not say orange i wanted to find out before i open...
Compatible with Chamberlain LiftMaster Security+ 390MHz garage door openers with redish orange learn button manufactured from 1997-2005.
Temporary password option to let you give friends, relatives or maintenance people limited access. Program code directly from keypad.
Compatible with garage door opener operator model numbers 1240R, 1245R, 1246R, 1255R, 1256R, 1265, 1280R, 1000SDR, 2000SDR, 1245 GMR, 1255GMR
The 977LM is new version of 976LM.
Taken from Garage repair information
Jul 17, 2011 | Sears Craftsman LiftMaster Chamberlain...
We have a Model 1245R Lift_master Professional Line 1/3 H.P. Security+ garage opener. We need to reprogram our wireless keypad but the instructions refer to an ENTER button when our keypad has NO ENTER...
If your keypad doesn't have the enter button it is an earlier model and will not work with what you have now. You will need to call your Liftmaster dealer to get the latest model.
Sep 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
I need a wiring diagram for a Chamberlain Liftmaster 1245LM Garage Door Opener. One that shows where all the wires inside hook up.
I would suggest you call around the Chamberlain dealers in the yellow pages. They may have something you can use.
Sep 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 1265LM garage door opener control wiring diagram
If you are looking for a schematic diagram they are not available.
Mar 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster mod 1245R (1999) has indicator light blinks 5 times. Door will not operate from hardwire button. Tried unplugging unit to reset but same 5 blink sequence returned. Held button in to reset but no...
The trolley is most likely jammed against the bolt just in front of the motor unit. Remove the bolt and then run the door until it is closed. Now locate the 'up limit' control on the side of the motor unit. Turn this 2 complete turns in the opposite direction of the arrow printed on the cover. Be sure to replace the bolt.
Dec 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster mod 1245R (1999) has indicator lightLiftmaster mod 1245R (1999) has indicator light blinks 5 times. Door will not operate from hardwire button. Tried unplugging unit to reset but same 5 blink...
The LED flashing 5 times is the code for "RPM sensor or motor overload". Usually if it is the RPM sensor - which is a small printed circuit board just in front of the motor - it will run a few inches and then reverse. I doubt very much it is the motor. I would pull the logic board and check for loose or missing traces on the printed circuit. Especially if you have had any electrical storms or power surges.
Nov 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
If your door is in the open position and the trolley is jammed against the bolt just in front of the motor unit you need to remove the bolt and then run the opener until the door closes. While the door is closed locate the 'up limit control' on the side of the motor unit and turn the control a couple complete turns in the opposite direction of the arrow printed on the cover.
Nov 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
I can get the door opner to porgram? on a chamberlain md 1245r
On the rear of the motor unit just to the left of all those white wires you will find the smart/learn button. Press and hold the button on your remote and then press and immediately release the smart/learn button. Do this for each of your remotes.
Jul 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Oct 23, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
77 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
