Question about Ricoh Aficio Mp -161 Spf Copier
Sc 995 mp 3351 - Ricoh Aficio Mp -161 Spf Copier
3 Suggested Answers
M2Tech1
  • 313 Answers
SOURCE: mpc 1500s sc 202 and af 1075 sc 995
are you sure the codes SC202 is ink related and you need to check the covers on the cartridges as the ink has run out...or the head is not recognising the cartridge..
the sc995 is due to a NVRAMM missmatch or failure.. the serial numbers are not recognised.. if you have replaced the controller board it is not correct or faulty. you can get a sd card and do SP5825 to download new details to the new NVRAMM
Posted on Jul 14, 2010
santosj27
  • 263 Answers
SOURCE: setting the duplex printing for RICOH Aficio MP
You just need to go to printing preferences and set the tab duplex. (Opens a tab and you chose which one you want.)
If you want to put duplex by default, go to:
Start - printers - click on the right on your mouse - properties - Printer preferences - and Change the duplex. In the end just click on "apply".
Posted on Feb 24, 2011
Ricoh mp 2550b sc 995 solution
SC995 Serial Number Setting Incorrect The 11-digit serial number is printed on the data plate. This information is compared with the installed components to detect mismatches. Did you remove any of the machine parts or components? Reinstall anything you removed and see if the error is resolved. If it's a problem with the NVRam, you'll need to contact an expert.
Dec 02, 2014 | Ricoh RICMP2550B Aficio Mp2550B - Digital...
Ricoh MP 3351 shows messege SC798 , problems with finisher
Three possible cause:
- Poor connection between the finisher and mainframe.
- Finisher harness damaged or defective.
- Finisher unit defective.
For number 1 you can check the connection to make sure the connection is proper.
For number two and three, I am afraid you have to buy a new replacement unit.
Nov 09, 2013 | Ricoh Aficio MP3351
Ricoh aficio mo 3351 reads messege functional problem detected . SC819
unplug the hard drive and switch on machine, if the problem goes away, then plug the hard drive back in and format it with service code 5-832-001, normally works
Nov 03, 2013 | Ricoh Aficio MP 2000 Black and White...
Setting the duplex printing for RICOH Aficio MP 3351
Feb 24, 2011 | Ricoh Aficio MP 161 Black and White Copier
Sir, My copier model RICOH MP 2000Le shows error . ADD TONER & some time it shows SC 302
sc 302 - charge roller current leak. strip the drum unit (dmu) and clean the unit
Sep 04, 2010 | Ricoh Aficio MP 2000 Black and White...
Sc990
sc 990 relates to the nv ram chip on the main board also check the values of the lazer unit are correct and not changed
Jun 16, 2010 | Ricoh Aficio 450 Copier
PROBLEM SC 995
Information Type 995 machine • Wrong
After switching on the machine, was detected with the controller card
mismatch CPM correct information sent by the Engine Controller.
Solution: Replace the controller card with the correct tab.
Jun 08, 2010 | Ricoh Aficio 3025P Black and White Copier
Ricoh Aficio Mp -161 Spf Copier Logo
147 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
