Question about Yamaha RX-770
Input selector My old RX-770 input selector has developed electrically and mechanically noisy and sloppy switch contact connections across all the input channels resulting is a lot of static and disruption to listening. otherwise unit works perfectly! Does anyone know if this can be fixed in place or if the selector can be replaced economically if parts are available? thanks in advance
  • 395 Answers
SOURCE: RX-V661 Receiver
your receiver has zone 2 output which is operated independently of the main reciever. so you can have a dvd playing inthe main reciever and the tuner playing over the intercom. read about it in your manual page 89. in will hook up to 2 RCA jacks in the back Zone 2 out.
Posted on Feb 03, 2008
robotek
  • 1512 Answers
SOURCE: Input selector on my Yamaha RX-V596 stuck
Hi Dush
Sounds like the processor has locked up in the unit. Try powering it right down from the wall socket for a day to reset, and then retry operation. If that does not work, leave it disconnected for about 10 days to erase backup memory completely and then try again. Good luck. Don't forget to give me a "FixYa" rating if this works. If it doesn't, get back to me in here and we can talk more about it.
regards
Graeme
Posted on Feb 16, 2008
  • 4234 Answers
SOURCE: right speaker goes off when using Rec out on the Phono input
The switch is contaminated. Pick up some electronic switch cleaner and spray into the switch. Move the switch back and forth a number of times and that should clear up the problem. Make sure that you get the cleaner that has a lubricant included.
Dan
Posted on Jul 08, 2008
  • 46 Answers
SOURCE: Subwoofer
Without being able to access the receiver in person, the best advice I can give you is to sit down with your user manual and follow the instructions. You'll find, starting on page 85, the necessary settings for hooking up a subwoofer to the receiver. If you don't have the manual, you can obtain a pdf file at Yamaha.com: http://www.yamaha.com/yamahavgn/Documents/YEC/AV_Receivers/Manual/RX-V663_U-1.pdf
Posted on May 16, 2010
gopakumarg43
  • 75404 Answers
SOURCE: I took my RX V3000
Hello
DSP boards are not repairable. We have to replace it as card basis itself. Used cards may always have some fault with them. Original replacement is always the best for this section, because this is the heart section of your Yamaha 6.1. $600 is a nominal rate I thinks. The DSP boards cost more than any other section boards. Make an agrement with them to get it seviced for this amount. OK.
Posted on Jul 03, 2011
RX-770 Input selector noisy - can this be fixed economically?
There are a number of ways to fix this, a quick fix is to rotate all the controls through their full range(with power on) this will give a quick clean to the contacts. The best thing would be to get the unit serviced at a Yamaha Audio dealers. They may have to replace the failed control switches, This will be cheaper than replacing the complete unit. You could do this yourself, if you feel confident to replace the switches, they should be available by part number on the internet.
Jul 22, 2013 | Yamaha Audio Players & Recorders
How to connect Niles #SSVC-6 Speaker Selector to Yamaha RX-V671
Greg, It pretty basic hookup,Just hook it up to your speaker terminal on the reciever or amp.To the input of the (Speaker) Selector.
Oct 04, 2012 | Yamaha RX-V671
I have a AV receiver RX-V440 Yamaha and........
The title of your question reads "I have a AV receiver RX-V440 Yamaha..." yet you say you are using the manual of an RX 1020L. I will try to provide a suitable answer for both receivers.
First, a "MON" connections on an amplifier or switching unit is normally used as a line level OUTPUT from the amplifier or switch. Line level outputs are sent to RCA connectors on other TVs or amplifiers (or switches).
"MON" should not be wired directly to the OUTPUT of anything trying to "playback". It should be connected only to things that can record or allow you to see or hear what the amplifier is outputing.
Now to answer your question:
The RX-V440 is a 6.1 channel Home Theater Receiver. If you stand behind the receiver and look at the left hand side, you will see 12 RCA connectors (2 L/R by 6 high). The top 2 connectors are labeled "CD". The next set of 2 connectors are labeled "IN/(PLAY)". The third set down from the top are labeled "OUT/(REC)".
You can connect the reel-to-reel output to either CD or IN. If the reel-to-reel has a selector switch, set it to "Output" and not "Monitor". If the reel-to-reel has volume controls, set them such that music causes can be heard when you select CD or IN on the RX-V440.
The RX 1020L is also a multi-channel receiver. If you stand behind the receiver and look at the left hand side near the center (top to bottom) of the receiver, you will see RCA connectors labeled "AUDIO 1" through "AUDIO 4".
You can connect the reel-to-reel output to either of these. The primary purpose for "AUDIO 3" and "AUDIO 4" is to allow you to hear component video input AV1 and AV2. If the reel-to-reel has a selector switch, set it to "Output" and not "Monitor". If the reel-to-reel has volume controls, set them such that music causes can be heard when you select one of the "AUDIO 1", "AUDIO 2" or whatever on the RX 1020L receiver.
Nov 21, 2017 | Audio Players & Recorders
Input selector does not work
How old? is touch or mechanic switch?
The switching circuit needs to be repaired or the power distribuition line. 5 or 12volts.
Aug 29, 2011 | Yamaha DSP-A1000 5-Channel Amplifier
Sometimes only one channel plays when playing CDs or DVDs. Jiggling the input knob will at times cause both channels to operate. This unit is a Yamaha RX-770 that I bought new. Thanks!
It sounds like you know what the problem is. Get it fixed.
Or try this temporary fix.
Or turn it off and manually operate the selector and all controls a thousand times to wipe the apparent oxides from their contacts.
Jul 06, 2011 | Yamaha RX-770
3090 input selector cuts in and out
My A3090 was purchased in 1996 and began to having problems with the input selector around 2006. The first symptom was difficulty finding the proper position for a input selected via the remote and bouncing back and forth many times before stopping-- sometimes in the correct position, other times not. Sometimes the selector would stop in between inputs and that would result in intermittent loss of sound, picture, flickering, etc. Once incorrectly positioned between inputs, even manually turning the knob will not fix the problem-- you must use the remote and select an input at one extreme or the other to reset the indexing.
Recently the problem worsened such that I was motivated to remove the cover and have a look. The selector and motor are soldered components on a small circuit board that appears to be dedicated to just that function. No rotary contacts are visible and the mechanical portion does not look like it can be disassembled without first removing it from the circuit board. The assembly is connected via a wire bundle and ribbon cable to two other circuit boards. I suspect the actual signal switching isn't even done inside the selector component-- it just reports the selector position via the ribbon cable to the main processing board. And it wouldn't surprise me if there aren't any contacts inside the selector that can be cleaned.
Seeing the ribbon cables immediately raised a warning flag because decades ago I saw similar cable connections cause many problems in personal computers. Back then they were very prone to corrosion and connection issues at each end. So I removed and reinserted the ribbon cable on both ends in hopes of improving the connections and that seems to have fixed the problems I was seeing. (Please note: This was done with the receiver power cord unplugged and *very* careful avoidance of any other components inside the receiver-- like the bank of capacitors adjacent to the input selector. I'm not a technician and don't know if any of them still held a charge. This is just an account of what I did and the results I saw, it's not a recommendation.)
Sep 04, 2009 | Yamaha DSP-A3090 7-Channel Amplifier
RX-V1600 when i turn on no sound or channels display on
If you are sure that the speaker wiring is correct and connections are good, then:
  • Check the input and output connections are correct for each source.
  • Check that the input mode is not set to DTS or Analog - rotate the input selector to the source and the press the input mode, set it to Auto.
  • Also check that the front speakers to be used are selected A or B (or A+B).
  • If there is an optimiser microphone supplied with this receiver, ensure that it is not still plugged in.
Hope one of these solutions work for you.
Jul 19, 2009 | Yamaha RX-V1800
I have a Yamaha Natural Sound Stereo Receiver RX-750 (purchased maybe around 1992-1993?). The input selector switch doesn't seem to be working properly. No matter which input I select, the sound is fuzzy...
Hi cfipp
You could fix this problem with a quick squirt of CRC 2-26 into the function selector switch connected to the knob you are wriggling. This will sort out the problem. If you need further advice, feel free to ask me. I will help you.
regards robotek
Mar 07, 2009 | Yamaha DSP-A1000 5-Channel Amplifier
Right speaker goes off when using Rec out on the Phono input
Dan
Jul 08, 2008 | Yamaha RX-595 Receiver
Noisy channel of receiver
Generally, crackling noises come from anyplace there is a mechancial connection for the sound signal. The volume control, main/remote speaker switch and possibly the headphone jack. That is where the contacts must be cleaned, but it requires dissassembly. Try operating the main/remote speaker switches, and plug/unplug a headphone several times. I am assuming there is still audio behind that crackling. Are you using both main and remote speakers simultaneously?
Apr 09, 2008 | Audio Players & Recorders
Yamaha RX-770 Logo
131 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
