Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Find a Solution
Most Common Problems for:
Zanussi Washing Machine
jaynemc on Aug 29, 2007
I have a Zanussi ZWF1421W washing machine which will not complete the wash cycle. The green end light flashes and the machine bleeps but it will not rinse or spin any ideas?
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Same Problem
Nov 21, 2008
-   Zanusi washer ZWF1421W.
i noticed that the end light was flashing and beeping never had this before! now it has stopped while washing and it is flashing again but the drum is full of water?
is there a blockage so it will not drain, do i need to open the front panel and inspect -   Guest
Jul 09, 2008
-   same as the others, 'end' green light flashes and beeps, cylce has not fully run, ie not drained or spun. I have done the following:-
1) Drain by using the hose at the bottom and when it has drained a large amount of water it will then start to drain automatically
2) I have stripped doen the drain pump, cleaned it out , cleaned out the waste hose. ( and still have problems)-   tim5
Mar 13, 2008
-   green light on end display keeps flashing. wont spin or drain. changed pump still wont work-   Guest
Mar 13, 2008
-   changed pump, but still flashing green end button-   Guest
Solution #1
posted on Aug 17, 2008
Not Rated)
CARL574
Rank: Apprentice
Rating: 0%, 0 votes
I HAVE A ZWF1421W,EVERYTIME I START THE MACHINE UP IT ENDS WITHIN THE FIRST 10SECS (PLEASE HELP)
Was this helpful?
Yes
No
Solution #2
posted on Jul 09, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
At bottom left of machine there is a small metal flap where you can drain off water. Next to that is a grey pipe you can keep pulling and pushing i have done this quite a few time and it has let out sludgey stuff put washing machine is now spinning and draining. Good Luck.
Related Problems
Whether I select wash, rinse or spin it jumps straight to...
i think the bearings have gone on my zanussi aquacycle fls...
Zanussi zwf1421w washing machine makes a rumbling/rattling...
Can you Help with these Washing Machine problems?
zanussi washer just keeps on trying...
Solve
when i switch it on to wash it starts draining and doesnt stop. i manually filled the drum up with... (More)
Drum paddles falling off
Solve
One of the drum paddles fell off last year. It looks like a screw fell out, but it's not clear what... (More)
Zanussi zwf1431w Turns off after 10...
Solve
Zanussi zwf1431w washing machine. When set on any programme irrespective of temp, speed of wash etc... (More)
Sponsored Links
Describe your Washer problem:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 2826
Experience: I have yrs of experience dealing with many situations.
Ask Me
Find more Washing Machine Experts
Top Washers & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 347-7500
Appliance Specialist We Sell New &...
Charland Appliance Service & Repair
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
