Question about Frigidaire Refrigerators
Ice Dispensing Paddle is Broken
The ice dispensing paddle on our Frigidaire Gallery is broken - not sure how to get at it to replace. Does the entire front panel need to come off?
    New Friend:
Not sure about the frigidaire,but most front panels can be removed from front. If you look around outer edge of trim piece there might be little screwdriver slot. Carefully pry off trim piece(faceplate),disconnect electrical plug on back,set aside.Once removed you should see you solution for removing paddle.
Posted on Jul 23, 2013
Frigidaire Gallery series ice dispencer does not dispence ice. Also, what is proper freezer setting?
Thank you for your inquiry, friend!
Based off what you have described you are having trouble with your ice dispenser not dispensing inside of your Frigidaire refrigerator and you would like to know the proper temperature setting. You may want to open the door of your freezer and check your chute to assure that there are no ice chunks or frost causing issues with your ice dispensing. When you push on the paddle do you hear a noise? If you do not hear a noise your auger could be bas inside of your icemaker. If you hear a noise and no pushing it could be a possible problem with the motor. It is recommended to have your freezer on a zero degrees for a factory setting. I hope this information is helpful. If you need any further assistance please feel free to reconnect. -Matt
Feb 21, 2015 | Frigidaire Refrigerators
How do I repair/replace the ice dispensing paddle? Mine broke in half! I have a Frigidaire FRS26H5ASB4
The panel comes off some snap off others have a couple screws hidden under the drip tray. After removing the outer panel, you will see some screws holding the paddle in place.
Sep 24, 2014 | Frigidaire FRS26H5AS Side by Side...
Samsung model rf4287hars only dispenses water when ice lever depressed
3b662ccb-018c-4390-ab7a-74a2025960df.jpg 3d562c7f-18a6-4fa7-9993-373c8c5d3c7f.jpg 763378c4-5f13-435a-aac3-b67d9041b031.jpg
First photo shows paddle assembly that can be purchased you need to got to Sears web site to find part # other wise you will have to buy the whole circuit board assembly hundreds more than the paddle assembly. The circuit board and paddle assembly is removed buy removing screw on inside of door and pulling it out be careful it seems strange but it just pops out. The paddle assembly slides on to the circuit board assembly look close and take your time to slide it off I thought I was going to break mine but did not and save me big money.
Second photo shows tab for water dispensing still there.
Third photo show ice dispensing tab broken and missing.
If you leave the assembly plugged in press the micro switch for the ice dispenser and see if it works most likely the tab has broken and is what hits the switch telling the door to open and ice dispensing screw to push ice to the door. Hope this helps
Mar 04, 2014 | Samsung RF4287HARS - 28 cu. ft. French...
When the paddle is released water /ice keep coming out until the freezer door is opened GE GSL25JFPBS Side by Side Refrigerator
the return spring on the paddle has probably broken keeping the micro switch on and dispensing,or the dispenser board is defective causing this
Apr 07, 2013 | GE GSL25JFPBS Side by Side Refrigerator
Refrigerator not dispensing water or ice
repairs should be performed by a qualified technician. if there isn't ice in the ice bucket located in the freezer you have a water flow problem. if there is water going to the filter and nothing out of the freezer then you have a clogged freezer replace it. if these things are ok then yes it could be the electronic control. filter failure is a common problem.
Apr 29, 2017 | Maytag Freezers
Ice dispensing paddle gets stuck
The inlet valve which automatically fills the water for ice maker & water dispenser is achieved with a solenoid valve. This is the valve which needs replacement to correct the problem you are currently facing......sodeep
Oct 20, 2009 | Refrigerators
The arm on the ice cube maker is broken.
how to replace water dispensing paddle on a side by side
Apr 06, 2009 | Refrigerators
Water Dispensing Paddle
My water dispensing paddle also snapped off. Where to get replacement part and how to replace? what's the cost?
Jul 05, 2008 | Frigidaire FRS23R4A Side by Side...
In door ice and water dispensing
sounds like the paddle is hanging up or the micro switch that the paddle actuates is sticking if you can see the micro switch spray some wd 40 on it open the door and work the paddle a few times
Feb 15, 2008 | Frigidaire FSC23F7D Side by Side...
Refrigerators Logo
194 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
