Pioneer pdp 434pu - can't turn on tv. 7 flashing red lights where power button is. 3 years ago it has 6 flashing red lights and it was a power supply issue, I found one and repalced it for under $200, now again, it maybe on it's last leg. Does anyone know what 7 blinking lights mean?
circuitcity
  • 137 Answers
SOURCE: power button
This is a very simply fix. Your problem is you have a bad thermal fuse. This fuse can be found in the Lamp housing. You need to take the back off in order to fix this problem. Replacing the thermal is not hard, but you need to be a little handy. Part number 1-910-023-93 Average cost $9.00
Posted on Dec 07, 2007
  • 3 Answers
SOURCE: Pioneer PDP 5030 power supply problem
Ok here's how I manage solve the problem... Having the back removed opens the contacts on the interlock switch so I guess if it powers up in this state it senses the high voltages are exposed and for safety shuts down... After this the unit will not power up and the power led flashes red continuously as described before…
After some thought it occurred to me that there may not be a problem at all, just be a simple reset function for this condition… I managed to find an easy solution to this… Just call up the hidden engineer’s service menu – On 3rd generation Pioneer Plasmas it’s as follows > Power down the screen > Hold down the “Input” and “Vol +” buttons on the front > Power the screen up and the Service menu comes up on the screen > You don't need to change anything just simply power off and from then the screen should operate as normal…It did for me so I’m well happy now!!
I hope this information will help someone else one day – Good Luck!!…Rob UK…
Posted on Jan 04, 2008
  • 93 Answers
SOURCE: Pioneer PDP-503PU
Very possible,but yet,this might be the manufacturer defect power supply which they will fix it for you free;but before we jump to this conclusion,you need to test it first:
-Unplug the power cords.
-Unplug the media video cable from the box to the tv.
-Check all the pins on the video cable are in place as well as the connectors both behind the TV and the media box.
-Reconnect the media box and TV with the video cable(DVI+VGA in one) and have at least a video component hook up to it(ex. dvd player/VCR or comcast box) be sure this video player is turn on and running,at the same time,be sure it is under the right video input.
If you have tried the above steps but still doesn't work,call 1-800-pioneer Tuesday-Thursday at7amPST and address your issue to them.
Let me know if you have any additional questions!
solutiondoct
Posted on Nov 05, 2008
  • 2318 Answers
SOURCE: Blinking red light
It appears in all cases that the power supply needs to be service. The blinking light might indicate that there are shorted parts or the voltage is low or a combination of both.
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Posted on Nov 27, 2008
ginko
  • 19396 Answers
SOURCE: HITATCHI ULTRAVISION P50S601...POWER LIGHT BLINKING...WONT COME O
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
Pdp 434pu speaker connectors???
I have a pioneer plasma pdp 434pu tv with no cables or speakers that came with it.My aunt gave me her used one but im having trouble trying to get a picture.I have a hdmi cable only.Please help!!!!!!!
Sep 10, 2013 | Televison & Video
I have a pioneer pdp-r05XE, on the plasma, the light flashes green and red alternately whilst on the receiver it flashes green 6 times. I can't get the tv to turn on...
Unplug if you have not done so BOTH units from power for several minutes (any cable or satellite box also connected.
wait several minutes and restore power to all units which may allow them to reboot.
Cannot hurt and may help.
Dec 06, 2012 | Televison & Video
Green flashing light on receiver of pioneer elite 434pu tv won't turn on
most likely a bad power supply and boards or service info for these sets is hard to come by. Not a do it yourself fix for most people.
Apr 22, 2012 | Televison & Video
Pioneer PDP 4330HD display flashes red LED 4 times
Just seeing if you had resolved the problem as my mum's Pioneer PDP-433HDE which she bought back 2002 has developed this same fault.
It has been a perfect TV and done very well with plenty of good use, but I have a feeling the cost of repair - even if it is possibale will be costly.
Cheers
Nigel
Mar 13, 2010 | Pioneer PureVision PDP-4330HD 43 in....
Pioneer plasma tv pdp-503pu 50"
I HAD THE SAME PROBLEM AND I CALLED PIONEER AND IT TURNED OUT TO BE A POWER SUPPLY, PIONEER IS FIXING SOME MODELS WITH THE DEFECTIVE POWER SUPPLIES FOR FREE LOOK ON THEIR WEBSITE
Jul 31, 2008 | Pioneer PureVision PDP-4340HD 43 in....
Pioneer pdp 502mx goes to standby no picture after power on
Contact Pioneer at 1-800-421-1404 about getting an in-home power supply replacement. This is a known issue with some plasma displays. Some of you would experience a loud pop and then the power supply fails. You get a red light below the ON button, when you press on, the red light will turn green for a second and then back to red. The plasma display will not turn on after the power supply fails. Call Pioneer at 1-800-421-1404.
Brought to you by http://abstravel.com and http://reservaciones.com
May 23, 2008 | Pioneer PureVision PDP-502 50 in. Plasma...
Pioneer PDP 436XDE
hi there, you have to send if for repair, tech people knows the prob., there a defective part to replaced. do some test and check up at the horizontal and power supply section. ty
Feb 18, 2008 | Pioneer PureVision PDP-4300 43 in. Plasma...
TV Flikers and StandBy Light Flickers
Your pdp panel sounds faulty - Count the red flashes this is an error code.
Nov 13, 2007 | Sony PFM-42B1 42 in. HD-Ready Plasma...
PDP-4330HD
This exact same problem happened to me 2 weeks ago on my Pioneer PDP-4330HD, and it did indeed turn out to be the power supply. The good news is, you can get it fixed for free, because Pioneer actually recalled the power supply in this plasma and others a couple of years ago.
Here is a link to the announcement on their website concerning the recall. They say that they will do a free in home replacement of your power supply, but when I called the local pioneer repair place, I was told I would have to wait three weeks for an in-home appointment. I ended up taking it in myself, and it was fixed for free 2 days later. Now it works perfectly.
Here's the number to call Pioneer in case the link goes down:
1-800-421-1404
Nov 10, 2005 | Pioneer PureVision PDP-4330HD 43 in....
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
