Question about Rock & Ice Climbing
How old do you need to be for paintball - Rock & Ice Climbing
If a player gets hit with a paintball that doesn't break, is he still out?
In most paintball games and tournament play, a paintball impact but non-break is non-elimination. It is good sportsmanship to call out "bounced" or "didn't break" if he/she is hit but does not receive paintball splatter.
Jan 17, 2013 | Sport & Outdoor - Others
Does the paint come out of you clothes when paintballing?
Paintballing bullets are made with water soluble paint, which means it should come out of your clothes; however I suggest that you wear old clothes and not your best designer gear to ensure that you don't ruin anything.
This a genesis lethal threat paintball gun I just got it and I am new to paintball what size paintball do I get for my gun please get back to me as soon as possible thank you
First off do you have a hopper and an air tank or co2 tank with air or co2 in it. If no get those things and fill your tank at a local paintball field. If yes your gun takes a .68 caliber paintball. That's really any paintball that you can buy at Walmart or sports authority.
Dec 01, 2012 | Toys
Inconsistent velocity, and my velocity adjuster doesn't seem to be working
This is caused when a gun needs cleaning and-or O-rings are worn.
Tear down the gun and clean the lube with the special paintball gun oils
and reassemble. See if it is better. CO2 is terrible for paintball guns.
Go with HPA (High Pressure Air, aka Nitrogen) and this will help.
Feb 16, 2011 | Tippmann 98 Custom Act Paintball Gun
When i put my paintballs in the gun and i aim down they fall out the top where they shoot from
Sound like your ball detent is gone or broken.
The detent is a tiny piece of rubber that keeps the paintballs in the chamber and from rolling out the barrel. It's a cheap part, but you will need basic knowledge of disassembling a Tippmann 98 to replace it.
You can find ball detents here!
Feb 12, 2011 | Tippmann 98 Custom Act Paintball Gun
When i screw my tank on the CO2 goes right through the gun and out the barrel
**** it and that should stop.
If that persists make sure you have cleaned the marker and used a good paintball oil to lubricate the internals.
At the next level you could have a o-ring that's old, brittle, broken and now is leaking by. Your local airsmith should be able to provide the necessary part(s) or fix it in short order for you.
Play hard, play safe, play with honor!
8^)
Nov 07, 2010 | Tippmann 98 Custom Act Paintball Gun
I bought a tippman stock for my carver one but im not sure how to put it on?
In order to use you gun you will need 3 basic things. First, you need to have your hopper with paintballs in it, second you will need a CO2 bottle to propel the paintballs, and finally **** the gun on the side have the gun in the ready position. There are some security measures to be followed like having a paintball mask for facial protection and to handle it as loaded weapon at all times since it can harm a person if not handled carefully.
Oct 21, 2010 | Tippmann 98 Custom Act Paintball Gun
Paintball gun is rapid firing when trigger is pressed. CO2bottle is full and i have tried other bottles but stillth same.
Tippmanns are known for their reliability and are very simple markers making them very easy to repair. you need oil from a local paintball shop or regular sewing machine oil will do.
On one side of the marker there is a little "handle" for cocking the gun, pull that handle as far back as you can and you will see 1 o-ring. put 2 drops of oil on it and fire it a couple times without paintballs to test it. This solves the problem 9/10 for tippmanns, if not..
Sometimes paintballs can break inside your gun. Look and feel inside your breech (where the paintballs go into the gun) and check for paint. If its dirty this can be causing your problem, strip it down and clean it (refer to your manual if you have difficulty)
on one side of the marker there is a little "handle" for cocking the gun, pull that handle as far back as you can and you will see 1 o-ring. put 2 drops of oil on it and fire it a couple times without paintballs to test it. This solves the problem 9/10 for tippmanns
Jan 08, 2010 | Tippmann 98 Custom Act Paintball Gun
I need to find the parts for the tippmann a5 urban warrior paintball gun
Home page | Special Ops Paintball SPECIAL OPS - A-5-A2 COMMANDO EZ-KIT. Regular Price: $ 79.95 ... Special OpsPaintball is a proud sponsor of the Living Legends scenario paintball game. ...
shop.specialopspaintball.com/ - Cached - Similar
Forum Brigade Tippmann A-5 Upgrades Gear Vests Articles Sick Deal Tippmann X7 Upgrades MarkersThey got it everything for an A-5 and they are inexpensive and ship quick!!!! ---WETWORK_SAT-SILVERBACKS ASSAULT TEAM
Oct 03, 2009 | Tippmann A 5 Standard Paintball Gun
Rock & Ice Climbing Logo
90 people viewed this question
Top Rock & Ice Climbing Experts
Makenzie Floyd
Level 1 Expert
ray gallant
Betty L Kidd
Betty L Kidd
Are you a Rock and Ice Climbing Expert? Answer questions, earn points and help others
